Old 06-01-2019, 08:30 PM   #15
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
3psi difference = roasted
Also stay away from TRD radiator caps, they will totally ruin your coolant system.
Trueweltall is offline   Reply With Quote
Old 06-01-2019, 08:46 PM   #16
15limited
15limited's Avatar
But its TRD breh
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 06-01-2019, 08:47 PM   #17
Pat
Pat's Avatar
Drives: 2023 BRZ
I have a Jackson Racing rad cap for sale. Only $300.
#tunerlyfe #zomgpowers
Old 06-03-2019, 11:54 PM   #18
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I recently read an article on why the NASCAR teams run 290 degree water temps at very high pressures and that's because it allows them to run with the front grill mostly taped off for better aero. In qualifying they will entirely cover the grill, often blowing out water toward the end of qualifying.
For us plebeians... the only reason I could see wanting a high pressure cap is for the road race car where I could spend several laps in a tight draft. The tight draft take a LOT of air away from my cooling system and temps can spike - having a little extra wiggle room in terms of boiling point in that momentary condition is good. The water is hottest at the end of its loop as passes the last exhaust valve and if your system temp is below the boiling point but the water at that very localized exhaust valve area could still cavitate and lead to problems. On my inline 4 in the previous car I warped the head at Cyl 1 on several occasions and finally jumped to a more robust cooling system overall - however a high pressure cap may have also been a workable solution but ultimately I wanted to be able to run in a draft for 30 minutes if the race dictated the necessity.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post:
Tristor (06-05-2019)
Search this Thread:
Advanced Search
Resale higher than expected? Dr Speed Scion FR-S / Toyota 86 GT86 General Forum 22 11-11-2015 03:43 PM
BRZ has a higher perceived value ? irax BRZ First-Gen (2012+) -- General Topics 27 01-09-2015 01:20 PM
higher Boost? Scalzo Forced Induction 19 09-10-2014 06:20 PM
Anyone know where to get higher than 91 octane? 86main Northwest 37 03-01-2014 04:05 PM
Where can i get fuel higher than 91? XPR Small Block Northern California 22 03-24-2013 10:56 AM
