Old 05-28-2019, 11:52 AM   #15
RFB
RFB's Avatar
Drives: FRS
Originally Posted by Guru Woodman View Post
Has anybody deleted the 3rd brake light located on the parcel shelf and used the rear fog light located in the rear bumper as a 3rd brake light.
It looks to me that the parcel shelf brake light was a bit of an after thought. I'd prefer the cleaner look and the fog light cluster is not used in the US & Canada. I would just need to reroute the wiring to the bumper and fabricate a bulb.
Or is this just a stupid idea.
One of our members (www.facebook.com/Brzworld) makes them.
You can see how they look on our wed. night meets.
RFB is offline   Reply With Quote
The Following User Says Thank You to RFB For This Useful Post:
Guru Woodman (05-28-2019)
Old 06-01-2019, 03:54 AM   #16
tarzan_nojane
tarzan_nojane's Avatar
Drives: 2014 FR-S
The higher and brighter the CHMSL, the more effective it will be. The twins are small, low cars, and you would like this brake light to be visible to the driver of the vehicle BEHIND the vehicle behind you!
My thoughts on the CDC install would be to position it and mark edges on glass with painters tape or similar. Use those lines as guide to carefully install new 3M tape directly to glass and cure with heat gun. Tint should butt up against edges of this 3M tape and not interfere with adhesion of tape OR visibility of the LED strip.
Now install CDC unit (original tape removed) and cure again with heat gun - but at much lower temp, say 200F.
The tape joint against the glass is VERY obvious, and unless it is uniformly contacting the glass it will look Mickey mouse.
tarzan_nojane is offline   Reply With Quote
Old 06-01-2019, 04:11 PM   #17
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
Originally Posted by tarzan_nojane View Post
Attachment 178223
One of my favorite mods. Installed the $50 CDC Mustang part. Removed ET from the package shelf, fabricated some foam pieces to fill all recesses, then covered with one piece of black felt.
Any issues with heat causing the adhesive to come loose?
el-guapin is offline   Reply With Quote
Old 06-01-2019, 06:27 PM   #18
soundman98
ProCrastinationConsultant
soundman98's Avatar
None on my cdc. They appear to be use genuine 3M tape, which means it could be stuck to the side of a sand building the desert and not have a problem
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video continuecrushing DIY (Do-It-Yourself) Guides 44 11-23-2020 07:17 PM
Abs and traction light no tailights replaced brake light switch now what? Brzlimited661 Scion FR-S / Toyota 86 GT86 General Forum 5 01-28-2018 07:04 PM
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) BirdTRD DIY (Do-It-Yourself) Guides 17 11-06-2017 09:42 PM
For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! Vicious LED Exterior Parts (Aero, Lighting, Etc.) 9 08-25-2013 08:26 PM
relocating the 3rd brake light Basti Cosmetic Modification (Interior/Exterior/Lighting) 6 03-06-2013 07:08 PM
