#85 | |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | bfrank1972 (12-09-2019), mrg666 (12-09-2019) |
#86 |
Drives: 2017 BRZ
#87 |
Drives: RX-7 / BRZ
A lot of it for oem's is how nicely and compact a roots blower sits nestled down in a V configured engine too...
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
| The Following User Says Thank You to Kiske For This Useful Post: | why? (12-11-2019) |
#88 | |
pessimistic skeptic
Where you put your money is your concern. I believe I can be smarter with my money. Can you argue with that? |
#89 | |
Drives: 2017 toyota 86
Better yet a comparison of all units sold of every supercharger for this platform, failure rate of every supercharger, average number of mileage before failure, and impact/cost to fix the failure. and then you could weigh this and factor it against the performance of the supercharger for your own individual decision. Having this information would be the smartest way to make a decision on spending your money. |
#90 | |
pessimistic skeptic
| The Following User Says Thank You to mrg666 For This Useful Post: | why? (12-11-2019) |
#91 |
Drives: 2013 FR-S Argento
Too many variables here - we're all using aftermarket kits for comparison, but even the best kits are no where near OEM levels of engineering and packaging (bay location, drive, lubrication, cooling, etc.) Turn key shops like Lingenfelter, Dinan etc. are better-ish for overall package completeness but it's really tough to make an apples to apples comparison. There may be also a supply thing going on, maybe Rotrex just can't supply large scale? (just a wild guess). Would be interesting to hear from an actual automotive engineer on this topic.
#92 | |
pessimistic skeptic
There are claims that we do not commonly agree. Many claim that Rotrex is unreliable. I agree that Rotrex is probably a more delicate and complicated design than PD blowers since it can operate without gears past 100,000 rpm that require tight tolerances. But this brings the efficiency advantage of Rotrex. And, there is no complete data to support this "unreliable" claim. My experience is just opposite and there is extensive track record as well. This "Roots is OEM choice" claim, I will just discount it as irrelevant since we are modifying an NA engine that was not designed for FI to begin with. My primary concern would be engine reliability than the reliability of supercharger. Rotrex is a safer application for our engines due to lower low-end torque. As a second priority, I would consider the supercharger reliability and Rotrex is a proven aftermarket product on many car brands. Honda had an OEM supercharger kit with Rotrex. Since PD blower applies a constant boost from low to top rpm, it is better to have lower top rpm power for engine reliability. Since Rotrex builds the boost linearly with rpm, it gives up some power at lower rpm but can provide more power at higher rpm. All I am saying is that the answer for that question in the first post is not as simple as calling Rotrex unreliable, Edelbrock very reliable. |
| The Following 3 Users Say Thank You to mrg666 For This Useful Post: |
#93 | ||||
Drives: 2017 BRZ
| The Following User Says Thank You to gtengr For This Useful Post: | 86TOYO2k17 (12-10-2019) |
#94 |
Drives: 14 BSP Edelbrock BRZ
This is incorrect. A PD blower does not apply constant boost. If you put 10 psi into this engine at 2000 rpm it would be dead quickly. The Eaton unit builds boost linearly.
| The Following User Says Thank You to toast For This Useful Post: | gtengr (12-11-2019) |
#95 |
pessimistic skeptic
I'm not sure where you got confused. Please read by yourself to figure out. Not interested in another back on forth.
#96 |
The level of condescending douchebaggery you convey borders on amazing. I have no interest in a back and forth with someone of your exceptional level of armchair engineering, but in this case it is not necessary, you are simply wrong.
The Edelbrock provides a fixed volume of air per revolution, not boost. When running WOT that volume creates a pressure in the manifold that is proportional to rpm. My boost scales linearly with engine speed; at 2k I get about 2 psi of boost, by redline it is 11 psi. I can provide logs if necessary. |
#97 |
The guy w/o an FRS or BRZ
Drives: '23 GR86 Premium 6MT Halo White
TorqAmp
#98 | |
| Edelbrock vs JRSC for track | Hades | Forced Induction | 21 | 02-21-2018 03:30 PM |
| Anyone of JRSC or Edelbrock? | tian105 | Mid-Atlantic | 11 | 10-02-2017 12:56 PM |
| Help me make a decision. Please! | HillCountryGuru | Electronics | Audio | NAV | Infotainment | 11 | 01-28-2013 12:07 PM |
| How did you make the decision to buy an 86/brz? | Dazza | AUSTRALIA | 30 | 09-06-2012 08:33 AM |
| How will you make your decision? | Jeris@CatoMoto | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 12-01-2011 12:13 AM |
