#15 | |
Drives: MT 2013 FR-S Blue
I've pretty much got it squared away now. I purchased 18x8.75 and I'll wrap them in 225/40 Firehawks. Should have some stretch in there, do you think that's too much? I'm a little worried because the firehawk doesn't have a rim guard, but whatever lol ![]() As for the others calling my car a rally car... lol I went off road to get that pic, and the ground was absolute slush. Rip me. It took a passing by tow truck two hours to get me out... he didn't charge me tho!!! Basically, that was a farm field, and there was a plastic bedding that had worked itself to the surface at the edge of that road. Unfortunately, that plastic bedding got wrapped up in my wheel between the brake and the axle. We worked on getting that tarp out for like 1.5 hours... Legendary tow truck driver.
#16 |
Drives: Toyota 86 2019
Wow, that's a tow job!!
You'll have a little bit of strecht but it'll be fine. I'm running 18x8.5 with 235/40 and they fit perfectly. You may consider that size since your wheels are a little wider than mine. I choose 235/40 mostly for the additional 4mm of ground clearance they give me, since I'm on TRD springs from the dealership and it's my daily driver. They also help closing the fender gap a little (another 4mm). Even if they have slightly bigger diameter than stock wheels, the speedo seems accurate enough. I was on cruise control last week and got a ticket for the exact speed showing on the speedo...so it's not an issue. |
#17 | |
Drives: '13 Scion FR-S & '17 Toyota 86
+1 to the Federals being LOUD, haha. Especially the RS-R/RS-RR. |
#18 | |
Less offset (ie +30 instead of +40) already has more poke. If you want the wheel tucked in more you need a higher offset. You can't increase offset with spacers, only reduce (and add more poke).
| Tags |
| 527, fr-s, xxr, xxr527 |
| FS: Avant Garde M310 Matte Black 18" x 9" and 18" x 8" w/ Michelin Pilot Super Sports | NvSnickers | Wheels and Tires | 2 | 04-04-2017 11:30 PM |
| WTT: Perrin 3" Catted Front Pipe + 3" Perrin Resonated Exhaust for 2.5" Setup | projek_01 | Canada Classifieds | 3 | 03-03-2016 02:45 PM |
| Why a balanced setup is better than a "understeery" setup. | CSG Mike | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 52 | 07-01-2015 05:36 PM |
| "My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) -- General Topics | 48 | 08-09-2013 07:34 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
