Old 08-10-2012, 03:34 PM   #57
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
I definitely have the rear deck issue. With the backseat down you can here the popping coming from the deck. Although when poking around in the trunk the deck seams solid. vOv
In my quoted post I was refering to taking apart the front dash to locate a different rattle btw. Sorry for the confusion.
Does anyone have a recomendation for the best way to contact Subaru on this?
blu_ is offline   Reply With Quote
Old 08-10-2012, 05:04 PM   #58
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
I would try and start with THIS.
I would use their form to submit instead of a verbal conversation over the phone because I get something in written.
I did so with Scion for mine.
But I don't know if this is the best way.
Sigh-on-Rice is offline   Reply With Quote
Old 08-11-2012, 08:39 AM   #59
skatery1989
Drives: BRZ Limited
So when The dealership fixed it. How many miles did they put on your car while try to find out what it was?
skatery1989 is offline   Reply With Quote
Old 08-15-2012, 02:24 PM   #60
Coultergeist
FReSh Mobile
Coultergeist's Avatar
UNCONFIRMED FIX!
I took my car into the dealership with the OP's post and they admit that it is a 6inch portion of the weld.
They have told me they looked into it, fixed it, had a Toyota rep come look at it, and verified that the issue is gone!
Sadly, I'm in Germany at the moment, but will update on Saturday when I'm home.
Good news, I think!
//Five Axis Kit//Eibach Springs//TRD Exhaust//Perrin Crank Pulley//aFe Takeda Intake//18x8.75 XXR//235/40/18 FK-452//HID Headlights
Coultergeist is offline   Reply With Quote
The Following 2 Users Say Thank You to Coultergeist For This Useful Post:
irxproductions (08-25-2012), Sigh-on-Rice (08-15-2012)
Old 08-15-2012, 02:27 PM   #61
Sigh-on-Rice
Originally Posted by Coultergeist View Post
UNCONFIRMED FIX!
Good news, I think!
That's such a good news!!!
I can't wait until your update.
Old 08-15-2012, 02:37 PM   #62
Gen
Drives: Scion FR-S
I have the same issue. Additionally, one of the child seat retention things is buzzing like a mofo on the underside of the trunk. There's a bolt and a little clip on the underside of the trunk that appears to hold it in place. If I squeeze those together quite hard the buzzing will stop. I've used a zip tie to apply tension to them for the time being that reduces the noise substantially for the time being.
Gen is offline   Reply With Quote
Old 08-15-2012, 02:40 PM   #63
Sigh-on-Rice
Have you taken a look at THIS?
Since the location you're describing sounds very similar to the pic on that post.
Old 08-15-2012, 02:42 PM   #64
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
This started on my white out FRS at 200 miles. Currently at 460 miles and it still does it when in 3rd gear around 30-40mph.
post_break is offline   Reply With Quote
Old 08-15-2012, 02:53 PM   #65
Gen
Drives: Scion FR-S
Nice find! Yes, that's the area. That clip and the bolt/nut seemed to be the culprit. I'll have to try plugging that hole...
Old 08-15-2012, 03:00 PM   #66
Sigh-on-Rice
Yours might not be the same issue.
1) 200 miles is kind of early for this issue to start. I'm not saying it's not possible, but it's unlikely.
2) It makes the noise regardless of the vehicle speed or the gear it's in. I.e., it makes the noise even in neutral at 10 mph.
I don't know how your noise sound like, but if it's anything like vibration (rattling, buzzing, and etc.), then that noise is something else. If you can describe the noise (how it sounds like, how often it happens, where it sounds like is from, and etc.), then I might be able to help.
Old 08-15-2012, 03:42 PM   #67
post_break
post_break's Avatar
It's a rattle, like the rear window is buzzing on metal. Something is vibrating the metal of that cross member. Similar to when a license plate is only secured by two bolts and it's resonating. That's not my issue since I have paper plates still.
It sounds like it's coming from the bottom portion of the rear window. Again it only happens when there is high engine speed and low road speed.
Old 08-15-2012, 04:06 PM   #68
Sigh-on-Rice
I see. That definitely is not the noise for this thread.
It sounds very much like the other noise #4 in my original post. An easy/temporary fix will be the post #18 in that thread.
If that's not the case, then it could be the other noise #1 in my original post, which probably sounds more like a plastic rattling. To find out if that's the case, you could stuff a towel between the rear window and the 3rd brake light housing with some pressure.
If that's not the case, then the last thing I'd try is the other noise #5 in my original post. Some people said the noise from this sounds like metal instead of plastic, so it's possible your noise is this.
Old 08-15-2012, 08:11 PM   #69
skatery1989
Drives: BRZ Limited
I had this same problem. took it to the dealer it was the left C pillar, and the door receiver control module that vibrates.
The Following User Says Thank You to skatery1989 For This Useful Post:
Old 08-16-2012, 06:06 PM   #70
Zadkiel
Drives: CBS BRZ Limited 6MT
I was thinking what I have might be one of these things. THe only problem is that it doesn't happen until plus 80 mph. I have no idea what it is. Definitely sounds as though it's on the drivers side somewhere, more like it was in the front and a plastic thump. When I parked and looked under the car, I saw the head of a grasshopper sticking out of one the the drain holes in the front part of the plastic underbody. It appeared stuck but it's quite possible that was it. Needless to say its head and body are no longer stuck there. Haven't been able to take it out again. We'll see if that was it.
In the mean time, anyone else have similair noises? Like something bouncing off of plastic, the noise starting at over 80mph?
Back in (Crystal) Black.
Zadkiel is offline   Reply With Quote
Search this Thread:
Advanced Search
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) -- General Topics 59 12-01-2013 01:28 AM
NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! Speed Element Wheels and Tires 19 07-19-2012 03:27 PM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) -- General Topics 67 11-09-2011 06:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 04:58 AM
