Old 03-29-2014, 12:34 AM   #561
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
And it worked
Sent from my SM-N900W8 using Tapatalk
Young_makaveli is offline   Reply With Quote
Old 03-29-2014, 12:34 AM   #562
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Rear Deck "popping/clicking/tapping/ticking" noise.
Yep no more noise after a year... Is that clear?
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 03-29-2014, 12:38 AM   #563
husker741
Yesssss. You guys don't understand that I've already done your method. It is two distinctly different sounds from the welds and the latches. I know that mine is the latches because I already fixed the welds.
husker741 is offline   Reply With Quote
The Following User Says Thank You to husker741 For This Useful Post:
Young_makaveli (03-29-2014)
Old 03-29-2014, 12:39 AM   #564
Mikepage
Mikepage's Avatar
Ok then try tape or 3M. I have already saw a guy who had the sound coming from an airbag near to the rear side windows...also....
o= FR-S =o
Old 03-29-2014, 12:49 AM   #565
Mikepage
Mikepage's Avatar
See post #339 into this discussion.
o= FR-S =o
Old 04-11-2014, 08:58 PM   #566
SocalBurt
Mine stared doing this when i bought it over a year and a half ago but it went away on its own. I did spray some lithium grease in the trunk joints as shown in some pictures here on the forum. It helped but now its completely gone on its own. I suspect the parts that were clicking perhaps wore down and no longer rubbing on each other. 2 Dealerships would do nothing about it which frustrated me at the time but just my 2 cents. That clicking sound is gone.
SocalBurt is offline   Reply With Quote
The Following User Says Thank You to SocalBurt For This Useful Post:
Mikepage (04-11-2014)
Old 04-20-2014, 07:44 AM   #567
gzpermadi
gzpermadi's Avatar
Drives: Toyota 86 Silver
Thanks to your post and from other forum I managed to reduce my rattle.
At first I did the usual rear deck adjustments: spraying grease, cracking/opening space between panels, wrapping the rear seat latches but the metal tapping noise still there.
After asking my wife to sit at the back for few hours she said the noise is not coming from rear deck but instead coming from the roofline area.
So I finally open the side airbag panel, seatbelt panel, door weatherstrip and I pull the headline a bit to expose the metal bracket.
But instead of cracking the panels, I opened the bolt and slip some thick tape between the panels.
Finally the metal tapping sound is gone!!
Originally Posted by sieeegel View Post
This is how i fixed my issue. I discovered that the noise is coming from the passenger side rear airbag. To get at the rear passenger side airbag, refer to this tutorial http://www.ft86club.com/forums/showthread.php?t=10002
I will skip some steps here and get to the point.
Once you remove the outer plastic trim, you will see the following (See below)
The red outline is where the PRIMARY sound is coming from. Gently tapping the airbag device will reproduce the sound. The clamp (outlined in red) is not fully attached to the chassis and makes a clinking noise. I simply took a 3inch x 3inch piece of t-shirt and wrapped it around the clamp outlined in red to dampen the sound.
In addition, I sprayed from WD40 over the metal clamp outlined in blue.
After i did all that, the noise went away.
gzpermadi is offline   Reply With Quote
The Following 3 Users Say Thank You to gzpermadi For This Useful Post:
chaoskaze (04-30-2015), djdnz (04-21-2015), Mikepage (04-20-2014)
Old 04-21-2014, 10:34 PM   #568
Jayde
Jayde's Avatar
Thought I'd chime in and let you guys know how my situation is. I've pretty much gotten use to the rear deck rattle now. I have noticed that it tends to happen more in the winter then the summer, but now my driver's side has a similar sound to it. Whenever I get time I'm going to pop off the rear airbag covers and see if it is coming from that area.
Also doesn't help that I have a subtle one coming from behind my HVAC controls, but that's for a different day.
Jayde is offline   Reply With Quote
Old 05-05-2014, 02:18 PM   #569
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Attachment 75449
Does this sound like having a big drop of water hit the roof of the car?
If so, I think I have the same issue.
Was it easy to put the roof panels back together?
daiheadjai is offline   Reply With Quote
Old 05-13-2014, 05:31 PM   #570
johnnyfast11
Drives: none yet
Originally Posted by CJB View Post
several or 3-4 popping sounds are gone. but im skeptical. im gonna wait a day before i put things back.
I cracked every shitty spot weld around the deck frame possible.
then i drove to isolate one from the above pics.
now i dont hear anything.
we will wait and see what happens after a drive.
I am determined to own a crack pop rachet free ft86.
__________________________________________________ ____________
found more buggers.
i will re do all the 50+ shit weld cracks if i hear anything more.
my evo was the only rattle free evo that i know of.
my BRZ will also be rattle/crackling free.
this is bullshit. all that work for no money.
those spots in red had significant popping noises cause they also connect to the side/upper frame and sit right on top of the struts where the first impact of absorption happens.
BRZ, I own you. you dont own shit.
johnnyfast11 is offline   Reply With Quote
The Following 2 Users Say Thank You to johnnyfast11 For This Useful Post:
CJB (05-18-2014), Nu_era (05-18-2014)
Old 05-14-2014, 10:55 AM   #571
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
Originally Posted by supramkivtt2jz View Post
also wanted to add
IF YOURE STILL HAVING RATTLING BUZZING ISSUES, CHECK YOUR TRUNK LID
The inner structural member touches up against the outside shell. This can cause buzzing with anything other than a stock exhaust. My fix was using thick double sided 3M foam tape pieces every 2-3 inches.
Can you please post pics where this was?
jadewbj is offline   Reply With Quote
Old 05-18-2014, 02:03 PM   #572
CJB
Drives: 2013 BRZ Premium MT
Are you still having success with these fixes? My noise re-appeared about 6-months later, this time on the opposite (driver's) side. I have still been unable to find the source. I have my interior stripped again and am trying your ideas, but no luck yet. It seems to be coming from above the wheel well area for sure, but I just can't pin-point it.
CJB is offline   Reply With Quote
Old 05-18-2014, 11:38 PM   #573
johnnyfast11
Drives: none yet
Its impossible to pinpoint them. I just looked at all the connecting points and popped as many as I can reach with small and long flatheads. I did all sides and almost everywhere so that's your best bet. Go big or go home. Took me 2 days and revisiting it we several times night and day. I'm sure 50+ spots I cracked.
key is to use small skinny flat heads to open the small unseen cracks. When you hear them crack? You got them.
Old 05-20-2014, 07:10 AM   #574
gzpermadi
gzpermadi's Avatar
It was more like something is loose and tapping.
I did not remove the whole headliner, only pull the rear area and some side/front area.
The Following User Says Thank You to gzpermadi For This Useful Post:
daiheadjai (05-20-2014)
Search this Thread:
Advanced Search
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) -- General Topics 59 12-01-2013 01:28 AM
NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! Speed Element Wheels and Tires 19 07-19-2012 03:27 PM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) -- General Topics 67 11-09-2011 06:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 04:58 AM
