#211 |
drift
I also had this noise and was following the thread hoping for a solution. Then I had my roll bar installed and the sound is gone. Must be that it's not flexing as much now. Just thought I'd chime in, maybe others will notice this also if they install bracing like a rear strut bar?
I'll try the lube trick if the noise does return, but seems to be good for now
| The Following User Says Thank You to 03Z33 For This Useful Post: | Sigh-on-Rice (10-01-2012) |
#212 | |
Audio & Bacon Junkie
Drives: 2013 WRB BRZ Ltd
:happy0180: |
| The Following User Says Thank You to rupert For This Useful Post: | Sigh-on-Rice (10-01-2012) |
#213 |
Drives: 92 NSX, 08 Accord
The proper way to fix this is to install grease fittings into those two panels. That way grease can be added at regular maintenance intervals.
-J
1992 NSX Red/Blk 5 spd #0330
2005 Lotus Elise - (sold but reincarnated by BRZ) 2008 Honda Accord Cpe, Blk/Blk,V6,6 spd, Nav (sold) 2013 Subaru BRZ, Limited, 6 spd Auto, WR Blue |
| The Following User Says Thank You to Jimbo For This Useful Post: | Sigh-on-Rice (10-01-2012) |
#214 |
Drives: Scion FR-S | 6MT | Ultramarine
I tried white lithium grease since I figured that it'd be longer lasting. I have a 30 mile drive to do soon. I'll report back ASAP.
| The Following User Says Thank You to Jidonsu For This Useful Post: | Sigh-on-Rice (10-01-2012) |
#215 | |||
Waited 5 years for this
Drives: '18 MX-5 Club
After I got rid of the popping noise, I noticed the "other noise" #5 I posted in my first post. -- 5 -- The rattling noise caused by the white plastic clips under the foam layer below the trunk liner. LINK I played around with the foam layer once (push it up, down, left, right, and etc.) and the noise was gone. |
#216 |
Drives: BRZ (soon)
Took mine into the dealer to get it fixed.
They told me SOA is instructing dealers to use lubricant to fix this issue. I'm a little concerned that this is a patch and not a real fix; but we'll see how it goes. |
| The Following User Says Thank You to shaofis For This Useful Post: | Sigh-on-Rice (10-01-2012) |
#217 |
I agree. If it lasts for the life of the car, then it's perfectly fine. But if the dealer needs to be lubing it every so often, then it's definitely not a "real" fix. Maybe SOA is somewhat confident that this patch fix would work for a long enough time, which is a good news in a way.
#218 |
White lithium grease did the trick and should last for some time.
#219 |
#220 |
I used the spray type that has a straw attachment. I just bought a canister of it by Liquid Wrench at the local Harbor Freight. I'm pretty sure the amount I sprayed in there was overkill. Haha. The car will need to air out.
#221 |
Wow. Who would have thought it: two squirts with white lithium grease and a good wipe down and suddenly I don't have a single complaint. Life is good!
| The Following User Says Thank You to whaap For This Useful Post: | Rayme (04-05-2013) |
#222 | |
| The Following User Says Thank You to Sigh-on-Rice For This Useful Post: | whaap (10-01-2012) |
#223 | |
Drives: BRZ(sold), STI
#224 |
Drives: BRZ (soon)
Went to pick my car up after the dealer's fix and on the test drive the noise was still very much so there.
They kept the car and will be center punching a few welds. |
| Odometer Functions - "S" & "G" What are they? | kablammo | BRZ First-Gen (2012+) -- General Topics | 59 | 12-01-2013 01:28 AM |
| NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! | Speed Element | Wheels and Tires | 19 | 07-19-2012 03:27 PM |
| Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) | Hachiroku | BRZ First-Gen (2012+) -- General Topics | 67 | 11-09-2011 06:58 PM |
| May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" | JDMinc | Scion FR-S / Toyota 86 GT86 General Forum | 76 | 04-17-2010 04:58 AM |
