86WORX
Old 09-07-2012, 11:28 AM   #155
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Originally Posted by Draco-REX View Post
Did the dealership use a punch with a flat end or a pointed end?
I used one with flat end -- pointy-style may actually punch through and that's not what you're wanting to accomplish.
cobrabyte is offline   Reply With Quote
Old 09-07-2012, 02:35 PM   #156
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Originally Posted by travace View Post
first off is it just me or did they mix up the cause for E and F ?
and a fit kit for rear suspension? i asked him and he said it came straight from Toyota. I dont know whats going on with this dealer BUT... as of now i get no rattle under shifter at 4000 rpm and up and i have not heard that pop tap noise in the back. i haven't got to drive a lot so i will post if it comes back.
Yes, they definitely got E and F mixed up.
I have no idea what that fit kit for rear suspension is, but at least, your noise is somehow gone now.
Sigh-on-Rice is offline   Reply With Quote
Old 09-07-2012, 03:25 PM   #157
jeebus
Drives: 2015 Mustang GT (on order)
I just noticed this noise. Thanks for the tips!
jeebus is offline   Reply With Quote
Old 09-07-2012, 03:57 PM   #158
Sigh-on-Rice
Originally Posted by Dooq View Post
Hi, sorry for the late reply. Yes, he just center punched all the welds around the seat back and right beneath the rear deck. I tried to zoom the pix out a bit, but at a relatively short distance the punch is barely visible. The foam is stuffed right beneath the 3rd brake light; see attached pix. I firmly believe the root cause are the welds, not some loose component underneath the 3rd light. Like someone mentioned, the noise sounds exactly like a plastic bottle popping back into shape after you've pressed it in. Two days in, and the noise has not returned.
This one is a good description of the noise. I added this description to my original post. Thanks.
Old 09-07-2012, 06:49 PM   #159
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I used a pin punch and it didn't seem to work. So I went over them all with the bluntest center punch I had and on the initial spin around my apt building where I could usually get it to make the noise the car was silent. More miles are necessary to be sure, but I'm hopeful. So you may want to go over everything with a pointed center punch. You won't punch through the sheetmetal.
Old 09-08-2012, 04:37 PM   #160
xcelir8brz
Drives: 2013 BRZ Limited
I ended up using a sledge hammer mallet and a 1/8" solid/flat center punch tool and banged hard on the same welds everyone else talked about. I do believe the sound is gone. More driving will tell.
xcelir8brz is offline   Reply With Quote
Old 09-10-2012, 08:26 AM   #161
xcelir8brz
Smack five times each with solid flat center punch on every single weld from left to right where all others listed and now the sound is gone. Where is a good place to pick up BRZ white touch up paint?
Old 09-10-2012, 09:18 AM   #162
cobrabyte
cobrabyte's Avatar
Pretty much anywhere that sells auto paint. I purchased a small bottle of DGM on Amazon but I'm sure you could find some SWP. It's not a new color mixture so it's readily available.
Old 09-10-2012, 09:23 AM   #163
hyper4mance
hyper4mance's Avatar
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
UPDATE: So I brought my car in for a few issues:
1) popping/clicking noise - they stated they did not hear the issue. I will personally drive with them this Friday since I need to go back in for a new taillight.
2) Driver side speaker rattle - FIXED!!!
EDIT: Oh I should also note that with the speaker fix, they changed something (I need to go back and double check exactly what) but now the volume needs to be raised about 5 more to hear everything at the same volume. I used to turn music to around 25 but now needs to be around 30.
3) tail light condensation - need to go back in Friday for them to replace, I guess they needed to put an order in.
4) Passenger Window double click down doesnt always work - they noted the issue and stated many other cars have the same problem. Service manager basically just said to click it down again or hold it longer... great fix huh?
5) car shudder / vibration - I mentioned it might be the LSD on cold start and they pretty much ignored it.
Now onto the gripes... dealers and their technicians (IMO) don't give a sht about your car. I had ~30 miles on this tank with 29.2 avg mpg before I brought it in. Sure with idle and testing it will drop a bit, but they only drove it for 3 miles and dropped 3 mpg. Someone had a great time AGAIN. Well, maybe you might have heard the popping/clicking if they weren't revving the engine to hell. TBH I'm not that suprised and I didnt note it to the service manager this time but if its not a warranty issue, I will continue to never bring in my car to any dealer.
I also find it a bit rude that a service manager tells a customer to just push the automatic window button down harder and longer. Seriously? I am not an idiot... I have a degree in engineering and a MBA, I'm pretty sure I can figure that out. The point is there is an issue that obviously is more common, maybe bringing it up with subaru and have the issue fixed? I guess that's too much work for them.
hyper4mance is offline   Reply With Quote
The Following 2 Users Say Thank You to hyper4mance For This Useful Post:
Marrk (09-10-2012), Sigh-on-Rice (09-11-2012)
Old 09-10-2012, 09:29 AM   #164
Draco-REX
Corner Junkie
Draco-REX's Avatar
So far so good. I did manage to get one faint "click" the other day on a bump that really twisted the car, but it hasn't happened since. I think I'll call this fixed. *knock on wood*
Old 09-11-2012, 06:29 PM   #165
mact
Drives: 13 GTI
I heard a pop while pulling into a parking lot with a curb (left tire went up curb first, then right tire). Is this the same scenario that everyone is hearing the pop?
mact is offline   Reply With Quote
Old 09-11-2012, 10:03 PM   #166
Sigh-on-Rice
Mine doesn't pop when pulling into a parking lot with a curb in an angle. It's a periodic pop anytime when the car is moving at any speed (5 mph or 50 mph) and on any type of road (smooth or rough). It makes the noise at a random pace too. Anywhere from once every five seconds to once every five minutes.
Old 09-11-2012, 10:07 PM   #167
xcelir8brz
It's gone. Banging the hell out of the rear deck from left to right on every single circular weld did it!
Woo Hoo! So happy!
The Following User Says Thank You to xcelir8brz For This Useful Post:
civicdrivr (09-11-2012)
Old 09-12-2012, 12:06 AM   #168
mact
Drives: 13 GTI
Interesting. My car has been quiet in that regard so far.
Search this Thread:
Advanced Search
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) -- General Topics 59 12-01-2013 01:28 AM
NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! Speed Element Wheels and Tires 19 07-19-2012 03:27 PM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) -- General Topics 67 11-09-2011 06:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 04:58 AM
