| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: my18 brz
2018 brz fogs on with high and low beams
Good afternoon everyone! OK, heres my question: how do i rewire my fogs so that they stay on even when i have the high beams on? I want to simply by-pass whatever it is that causes them to turn off when I switch to the high beams. I do quite a bit of early morning driving in a very rural area with a ton of deer. Every single little bit of extra light that i can get to the ditches is extra time to be on my brakes when i see them. I'd appreciate any help i can get towards this issue.
22R
Drives: 2012 Camry SE 2017 Toyota 86
Unsure if it can be done on our cars but I did it by jumping a diode at my BCM in my 2014 GMC Sierra. Maybe someone will chime in.
22R |
| The Following User Says Thank You to 22R For This Useful Post: | SmaxxSmith (04-26-2019) |
Drives: my18 brz
Hmmm...from the lack of any replies I'm guessing that its not as simple as I had hoped. I'm sure im not the only one to want to do this. I guess the electrical engineering community must either not use fog lights for anything but fog OR they just don't drive nice cars like we do!
Thanks for the info on the chev.
| The Following User Says Thank You to SmaxxSmith For This Useful Post: | 22R (04-26-2019) |
Drives: Supra, Viper, Z06, GT350 and GX460
Most people would want to turn their dog lights on with just the parking lights on. I’m sure that can be done easily. But never heard someone wanting to have the dog lights on along with the high beams. Hopefully you’d find a way...
IG: @vipraz 94 Supra Turbo // 15 Viper GT // 16 Corvette Z06 // 18 Shelby GT350 // 19 BRZ LTD // 18 GX460 Premium // 13 Vrod Muscle
| The Following User Says Thank You to Jdmuscle For This Useful Post: | atomicalex (05-07-2019) |
Drives: my18 brz
Really?!?! Who wouldn't want as much light as they can get? I guess I can understand that if you're only ever in the inner city, but otherwise...
ThisGuyLoves86's
Drives: 2013 Scion FRS
I have considered doing this also. My planned approach is to tap into the energized part of the high beam relay and jumper it to the trigger terminal on the relay for the fog light.
2013 Scion FRS (current car)
1991 Mazda Miata MX5 (current car) 2003 Nissan Pathfinder (R50) (current car) 2018 Lexus GX460 (current car) 2023 GR86 Neptune M6 Premium (Leased) |
| The Following User Says Thank You to Prodigalson For This Useful Post: | SmaxxSmith (05-07-2019) |
Drives: my18 brz
Thank you for the info! I'm certainly no electrical engineer, so is there any chance you might know where i could find a schematic for the the lights? The difference between hi and low is just a moving flap and not an actual change of the lighting element, correct? Still wondering if the the low being on is triggering something or if its the hi beam being switched on that is the trigger to disable the fogs. Breaking a ground circuit maybe? If that was the case, it could be as simple as cutting the trigger wire from the hi beam. I hope, I hope, I hope! lol! If i find anything, Ill be sure to post it!
Drives: my18 brz
I did just find this. Looks like I have a little research material after all! This forum is awesome!
| The Following User Says Thank You to SmaxxSmith For This Useful Post: | Prodigalson (05-07-2019) |
Drives: '13 BRZ
Try asking here as well: Got a headlight or foglight question? ASK here.
| The Following User Says Thank You to tobin For This Useful Post: | SmaxxSmith (05-07-2019) |
| Fix for dim high beams | zombieite | Software Tuning | 5 | 07-28-2016 05:06 PM |
| How to use fogs as daytime lights instead of high beams? | itsAlex | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 07-21-2016 10:46 AM |
| High beams always on | DayV | Issues | Warranty | Recalls / TSB | 7 | 10-29-2015 06:03 AM |
| High beams | DjDATZ | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 09-10-2014 07:49 PM |
| High Beams | DC-FRS | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 01-12-2013 10:44 PM |
