Old 03-25-2019, 11:33 PM   #1
Flash02
Drives: 2017 Subaru BRZ Limited
Pioneer 2300NEX, Maestro iDatalink
I just installed a Pioneer 2300NEX in my 2017 BRZ Premium Limited.
What’s needed
Maestro RR to keep steering wheel controls as well to get some decent sensor output
IDatalink SU2 harness. From what I’m hearing the new SU2 harness does not require any mods if used with a factory amp. It’s best to call Tech support to confirm, I don’t think their instructions have been updated.
Satellite Radio antenna adapter AutoHarnessHouse.com p/n AHH-XM1
Four pin USB adapter
Axxessinterface.com
p/n AX-SUBUSB
AM/FM antenna adapter
Metra p/n 40-LX11. Note: my 2017 BRZ does not have a power boosted antenna so there’s no need to connect the power wire that comes with this adapter.
Note: if you’re retaining the factory Aux pot than the Maestro audio cable is not required.
Regardless if your BRZ has a factory amp or not the BNC audio ends may need to be cut. Wire the harness into the the new head units main connector. It seems that there isn’t sufficient power in the BNC connections to get decent sound. This is what I found, other head units may be different.
I hope this helps
Flash02 is offline   Reply With Quote
Old 03-29-2019, 05:38 PM   #2
mroberge7@gmail.com
Drives: 2017 Subaru BRZ INAZUMA EDITION
I just did a similar install last weekend and I did follow the directions to cut the brown/red wire and join it to the remote turn on blue white wire as the directions stated. I also have the OEM Audio Plus system so I am not using the stock amp but I assume the remote turn on would still be needed to run the OEM Audio amps. Everything did work for me though so I would say you do need to cut the brown/red wire. You can try just as it is and see what happens. It’s easy to make the wire changes after.
mroberge7@gmail.com is offline   Reply With Quote
The Following User Says Thank You to mroberge7@gmail.com For This Useful Post:
Flash02 (04-08-2019)
Old 04-08-2019, 10:40 AM   #3
Flash02
By chance have you noticed if you are unable to dim the instrument lights?
Installing Pioneer HU and Maestro RR NCtoBRZ Electronics | Audio | NAV | Infotainment 56 05-20-2019 09:16 AM
Pioneer W8400 with Maestro RR? STI-ish Electronics | Audio | NAV | Infotainment 13 02-11-2019 01:07 PM
AVIC-8201NEX without iDatalink Maestro? sgh Electronics | Audio | NAV | Infotainment 7 04-19-2018 02:42 PM
IDATALINK AVAILABLE FOR 2017 BRZ 007BRZ Electronics | Audio | NAV | Infotainment 3 09-25-2017 03:36 PM
Maestro idatalink test dummy tofurun Electronics | Audio | NAV | Infotainment 30 10-18-2016 02:01 PM
