Old 03-22-2019, 10:40 AM   #1
rct269
EMPTY HOLES
Are there any caps or fillers available to cover the holes in the 2019 BRZ deck lid after removing the wing---or perhaps a small lip spoiler that can be installed in its place?
RT
rct269 is offline   Reply With Quote
Old 03-22-2019, 11:23 AM   #2
Interlocker
Drives: 2017 Toyota 86 860
RT
If you end up wanting to plug the holes rather than getting a small lip spoiler, these might work well (depending on the size of the holes):
https://www.bumperplugs.com/index.ph...gory&path=1_11
I ordered a pair to fill the drilled holes in my front bumper since I don't have or need a front plate. Color match was perfect.
Interlocker is offline   Reply With Quote
Old 03-22-2019, 12:23 PM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Trunk swap.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 03-22-2019, 03:23 PM   #4
Thunder86
Thunder86's Avatar
Drives: 2018 Toyota 86 GT trim (Thunder)
From what I understand, there are currently no readily available “lip spoilers” that will cover the holes left from removing wings off the 2017+ models. Not only are there 2 holes per mounting spot, but also a clip for each side.
Look up some of the “Drambeenie spoiler riser” install threads/videos to identify the holes.
Also, if one was to find tasteful lip spoilers that do cover the holes, I’d be interested.
[insert poor quality, phone-taken picture here]
Thunder86 is offline   Reply With Quote
Old 03-22-2019, 06:44 PM   #5
Guest
Drives: 2017 BRZ PP
At the moment I'm pretty sure your only option would be a trunk swap. Those listed in the link above wouldn't cover the forward most holes left from the clips on the spoiler.
Guest is offline   Reply With Quote
Miles to empty on 2017 86? tukai Scion FR-S / Toyota 86 GT86 General Forum 73 09-09-2018 12:28 AM
How best to empty gas tank pcguru2000 Issues | Warranty | Recalls / TSB 80 08-27-2018 03:50 PM
Does anybody know any empty fields in LA? Tofu-86 Southern California 2 09-13-2015 12:06 AM
OFT Tuner Help, Empty Zip Files? mopar591 Software Tuning 7 03-24-2015 01:57 PM
