#85 | |
Drives: frs
I wouldn't trust the service manager. He will say all the right things but when things go wrong, they are super quick to shift blame. The service manager at my dealer never picks up phone calls and don't call back but when i went in to see him, he was just playing on his phone. |
#86 |
Drives: 2013 Scion FRS
Dealership says tech found the ecu codes were recently deleted when they took the car from me. I told them I don't know what's going on. They say, based on that, they are not paying. I'm screwed.
#87 | |
#88 |
Note to self, get the valve recall done before my battery needs to be replaced because replacing your battery means voiding the recall warranty.
The Following User Says Thank You to ermax For This Useful Post: | bfrank1972 (03-04-2019) |
#89 |
Drives: 2013 FR-S Argento
#90 |
Drives: frs
I flashed mine to stock tune from stage 1 OFT. And mines at the dealer right now for knocking noise. They better not pull sh** like that on me.
#91 | |
ECU codes can be deleted and ecu reset by a simle loss of power to ecu ie wie when you remove battery terminal or battery goes flat. Seems unreasnoble that reset of ecu or deleting of codes coyld be used to deny warantee on its own, even if you did delete codes with a scanner it seems unreasnoble to deny warantee. |
#92 | |
So the "codes" got deleted when the disconnected the battery to complete the recall? ![]() |
The Following User Says Thank You to ka-t_240 For This Useful Post: | why? (03-08-2019) |
#93 | |
Drives: 2013 BRZ 6MT
Elevate to corporate (SOA -as high as possible), and write into 7 On Your Side. So sorry to hear the crap being flung at you by that dealer. Sent from my iPhone using Tapatalk |
The Following User Says Thank You to PWBRZ For This Useful Post: | why? (03-08-2019) |
#94 |
First 86 Driver Baby!
Drives: FR-S, Flex
I got my car back from the dealer last Friday. On my way home white smoke started coming out of the hood when I stopped in traffic. When I got home it wasn't smoking anymore, but I noticed the coolant level was below low (hot), so I filled it up. It's now back down to just below the full level (hot). Obviously some coolant was probably spilled when they filled it up and it had soaked into the downpipe wrap. I've checked every day and always find a couple of drops of coolant on connectors under the top radiator hose. I've checked the hoses haven't been able to find a leak, though. I'm going to take it back to the dealer this week for them to verify the engine isn't leaking coolant. Also, the coolant is only visible on the passenger side, and there are visible signs of dried coolant drops in the same area. No pooling under the car while parked.
#95 | |
Drives: Crapcan
Sent from my Moto E (4) Plus using Tapatalk
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#96 | |
Drives: frs
This is from the Toyota corp to their dealers. img|https://imgur.com/a/Ky71g2I |
#97 |
Drives: 2013 Scion FR-S, Hot Lava
doing a quick search on youtube:
https://www.youtube.com/results?sear...n+bearing+fa20 It's amazing how common this issue is!, and also amazing there's no recall for it...
#98 | |
In these cases, its likely caused by careless technicians. You don't see many BRZ's having this failure after the recall(or the 3 other subaru models having the exact same issue completed). |
Tags |
brz, failure, frs, i cant even, j02, recall, so much glue |
Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 03:46 PM |
Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 10:12 PM |
CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 06:18 PM |
BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 03:44 PM |
Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 09:21 PM |
