#435 |
Drives: 2019 Mazda Miata RF
Pull engine, remove valve cover, they are in the cam carrier. Technically they are OCV screens. Page EM-31 in the service manual.
https://www.slideshare.net/kokkat/20...service-manual |
#436 | |
Benz Tech
Drives: 2017 BRZ Premium
![]() Seriously though. If there's loose sealant in the engine there is no reasonable way to get it out. The easy way would be not to drop sealant in the engine in the first place. |
| The Following User Says Thank You to maslin For This Useful Post: | why? (03-23-2019) |
#437 |
Yep, and avoiding that is tough, when you are removing something the size of the front timing cover, which exposes the oil pan, and various other passages, with old sealant able to flake where ever.
#438 |
fabulous
If I was remotely thinking about having a dealer perform this recall, I would pay for an extra day's labor of an experienced tech and personally ask her to:
1. Remove both of the valve covers at the same time.The only thing affected by clogged AVCS filters is AVCS.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | ybotspawn (03-22-2019) |
#439 | |
![]() humfrz for Bubba |
#440 | |
![]() humfrz |
#441 | |
Benz Tech
A wink wink plastic razor blade works best, but can damage the aluminum parts. Actual plastic razor blades work, but they take much longer. It’s one of those things. Its easy to do it right, it’s even easier to do it wrong. |
| The Following 4 Users Say Thank You to maslin For This Useful Post: |
#442 |
fabulous
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (03-23-2019) |
#443 |
fabulous
Equally legit. Part of mine is an excuse to inspect the screen regardless.
#444 | |
Connection issues
Drives: '15 ultramarine
#445 |
fabulous
I've modified the tricorder to emit an inverse paraphasic field using stone knives and bear skins.
#446 |
Drives: 13 Subaru BRZ
| The Following User Says Thank You to ybotspawn For This Useful Post: | Ultramaroon (03-23-2019) |
#447 |
fabulous
#winning
| The Following User Says Thank You to Ultramaroon For This Useful Post: | ybotspawn (03-23-2019) |
#448 | |
Regardless, removing that timing cover does expose the oil system to FOD. |
| Tags |
| brz, failure, frs, i cant even, j02, recall, so much glue |
| Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 03:46 PM |
| Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 10:12 PM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 06:18 PM |
| BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 03:44 PM |
| Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 09:21 PM |
