Old 03-14-2019, 03:14 PM   #267
maslin
Benz Tech
Drives: 2017 BRZ Premium
We had a recall a few years ago to reseal and retorque a timing chain tensioner. 4 cyl twin turbo diesel, timing components on the back of the motor.
The tensioner is on the right rear of the engine, above and behind both turbochargers. The catalyst/DPF is behind and below. You would have to move some serious oil to reach either one.
Here's the explanation from the recall, fire is on there, but down the list.
"Over time, this might lead to loosening of the chain tensioner, as well as an ineffective sealing ring seal for engine oil. As a consequence, leakage of engine oil onto the road might pose a threat to traffic. Should the oil leakage reach a certain amount the engine might stall. Oil leakage in the presence of an ignition source could also increase the risk of a potential fire. "
maslin is offline   Reply With Quote
The Following User Says Thank You to maslin For This Useful Post:
Tcoat (03-14-2019)
Old 03-14-2019, 03:34 PM   #268
Chimera
Drives: FRS
So I have my car in the shop now. But I'm concerned as well, very seriously considering trading for a corvette or possibly a 124 spider
The Following User Says Thank You to Chimera For This Useful Post:
Summerwolf (03-14-2019)
Old 03-14-2019, 03:38 PM   #269
ermax
ermax's Avatar
You'd be going down the same route though wouldn't you? Fiat working on a Mazda.
Old 03-14-2019, 03:46 PM   #270
Chimera
Drives: FRS
nothing quiet like makings todays problems tomorrows problems.
ermax (03-14-2019)
Old 03-14-2019, 04:05 PM   #271
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
31 emails and 54 calls later, Toyota has agreed to repair my engine. They are not replacing the gone with a new one. Comes with a 12mo warranty. I'll update as I learn more, they said I'd receive I receipt for all parts when I pick up the car.
Better than nothing just wish it wasn't so hard to get them to take action, and it ruined my relationship with this dealership. Keep fighting guys!
The Following 12 Users Say Thank You to DarkPira7e For This Useful Post:
caus (03-15-2019), Chimera (03-14-2019), Dadhawk (03-14-2019), ermax (03-14-2019), humfrz (03-14-2019), maslin (03-14-2019), PWBRZ (03-15-2019), qcbaker (03-14-2019), Rampage (03-14-2019), srt4evah (03-14-2019), Summerwolf (03-14-2019), Ultramaroon (03-14-2019)
Old 03-14-2019, 04:17 PM   #272
ermax
ermax's Avatar
Nothing is stopping them from making the same mistakes all over again though. I know they have been playing dumb with you but hopefully they know where they went wrong and will learn from it when doing your rebuild and others going forward.
Good luck!
The Following User Says Thank You to ermax For This Useful Post:
DarkPira7e (03-14-2019)
Old 03-14-2019, 04:20 PM   #273
1st86 Driver!
Congrats! Didn't the initial repair come with a 12mo warranty? I know mine did.
Old 03-14-2019, 04:37 PM   #274
DarkPira7e
DarkPira7e's Avatar
Good luck!
Yeah, I feel this way too, but it's better than nothing. If it happens again, I'll likely just buy a new built block and be done with the heartache.
It did. This ended up being a key fighting point for them. Because it wasn't a VALVE SPRING that broke, the warranty was effectively useless. In their eyes, the warranty is only for the exact part, and has nothing to do with work involved in the remedy.
The Following User Says Thank You to DarkPira7e For This Useful Post:
Old 03-14-2019, 04:55 PM   #275
Ichima
Drives: 13' Lightning Red Brz
Hey guys,
Long story short, dealership says my valves are shot and says it is not covered under warranty with the valve spring recall. I am unsure what to say right now as they are stating it will be $1500 in parts alone. Any suggestions?
Ichima is offline   Reply With Quote
Old 03-14-2019, 05:39 PM   #276
Originally Posted by Ichima View Post
Hey guys,
Tell them to do the recall work only and to go to hell with the valves.
Dadhawk (03-14-2019), Rampage (03-14-2019), strat61caster (03-14-2019)
Old 03-14-2019, 05:45 PM   #277
ka-t_240
Hey guys,
Can you tell us more on how they know they are shot? Do you have details on what is bad, etc
ka-t_240 is offline   Reply With Quote
Old 03-14-2019, 05:48 PM   #278
ermax
ermax's Avatar
Kind of reminds me of tire shops saying, "we can't align your car unless you get new tires" even though your tires aren't even close to the wear bars and even if they were corded it has literally no impact at all on the alignment or ability to do the job. Always looking to make a buck.
The Following 5 Users Say Thank You to ermax For This Useful Post:
akyp (03-14-2019), DarkPira7e (03-14-2019), Leonardo (03-14-2019), Rampage (03-14-2019), strat61caster (03-14-2019)
Old 03-14-2019, 06:17 PM   #279
Ichima
They couldn’t even tell me. They just said i need new valves, rockers, cams, etc. they also said they didn’t touch my valves at all durig the process of the recall.
Old 03-14-2019, 06:22 PM   #280
Ichima
Sorry i wasn’t specific. They already performed the recall service. They were able to tell me my headgaskets were bad prior to completing the work. So i said with 90k miles go ahead and replace it. But how would they not know my valves were bad prior to working on the valve springs? Like i said, i don’t know too much about motor work but i was already told they ripped me off with the hg replacement and don’t wanna get ripped off again.
brz, failure, frs, i cant even, j02, recall, so much glue
Search this Thread:
Advanced Search
Registry Thread: Failure After J02 Recall DarkPira7e Issues | Warranty | Recalls / TSB 489 05-26-2023 03:46 PM
Is the fad threads ruining our fad threads? Andrew025 Off-Topic Lounge [WARNING: NO POLITICS] 12 10-04-2017 10:12 PM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 06:18 PM
BRZ or FRS (yes, another one of those threads) lisaaaxo FR-S / BRZ vs.... 19 04-11-2015 03:44 PM
Vs. threads.... TwinscrollGT35R FR-S / BRZ vs.... 34 05-22-2012 09:21 PM
