#253 |
It is the basic physics of how fire works. Oil is a horrible fuel when in liquid form. It creates a very low level low temperature burn with more soot and smoke than heat. It would be slightly elevated in temperature from the air movement when moving but that would be countered by the fact it would be forced back and down by that same flow. For it to get hot enough to breach the fuel system in a moving car it would have to be massive and the clouds of smoke intense. Any oil leak fire that got hot enough to cause the fuel system to explode would have burnet through the wires and shut down the car well before that point. It just is not a feasible failure mode in an explosion.
#254 | |
Only users lose drugs.
Drives: All the time
I've been a volunteer member of our local fire department since 1983, so am pretty well acquainted with how fire works, to include engine fires. Fuel system failure as a secondary source to the primary fire is absolutely possible, and possibly even likely. I've seen cars still running while fully engulfed in flames. There is no predictable way the car burns, in terms of what section of wiring melts before another, or in relationship to where in the engine bay they are located.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#255 | |
For sure there are to many damn variables to predict with certainty. My vote is still on rod through block.
#256 | |
The variables are many but so are the known characteristics of fires. And since we are attaching resumes for qualifications. Canadian Armed Forces damage control and fire fighting school Esquimalt 1976 CAF Advanced fire fighting aircraft and fuel supply Lahar Germany 1977 Navy Reserve damage control and fire fighting officer 1993 to 2004 Industrial Health and safety professional in high hazard sites 1991 to present
#257 |
Benz Tech
Drives: 2017 BRZ Premium
#258 |
Not quite there yet. Moderate at best. Need to reach Pinto levels of bursting into flame to advance.
#259 | |
Drives:
Could an oil leak in the engine bay catch fire, damage intake plastics and exposing injectors for an explosive burn? Sent from my SM-G930W8 using Tapatalk |
| The Following User Says Thank You to N234 For This Useful Post: | Tcoat (03-14-2019) |
#260 | |
And here comes the **** swinging... I'm not the one with the condescending post about 'the basics physics of fire'. This isn't a bucket of grease in the driveway with a match thrown on it...a small fire can easily progress into a large one as surrounding fuel sources are incorporated. But, you already knew that. Otherwise, car fires wouldn't happen.
| The Following User Says Thank You to venturaII For This Useful Post: | Tcoat (03-14-2019) |
#261 | |
You pulled your **** out first I just simply produced my bigger one. Yes 100% agree that a small fire can and will progress to a large one under the right conditions. Still do not agree that THIS circumstance met any of those conditions.
#262 | |
#263 |
On this we totally agree!
#264 |
The Gunshine State
Drives: '14 BRZ Limited
Time to call Mythbusters!
They're still on, right?
![]() Current DD: M235i |
#265 | |
#266 | |
Not a huge concern since many cars leak a bit of oil and it hits the exhaust but not many blow up or even burn. If every car with an oil leak exploded into a ball of flame the highways would look like a constant Michael Bay movie!
| Tags |
| brz, failure, frs, i cant even, j02, recall, so much glue |
| Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 03:46 PM |
| Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 10:12 PM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 06:18 PM |
| BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 03:44 PM |
| Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 09:21 PM |
