#211 | |
Connection issues
Drives: '15 ultramarine
I would think a fire under the hood that is coming out the wheel wells would do a number on the traction and ABS sensors? Need a "holy shit" button for that one. |
#212 | |
Video is worth a thousand words. Notice the tire smoke before the fire.: [ame]https://www.youtube.com/watch?v=mpZsZimnwtg[/ame] |
| The Following User Says Thank You to ermax For This Useful Post: | Sapphireho (03-13-2019) |
#213 | |
1st86 Driver!
I'm not saying it wasn't the valve issue, but I'm just asking what evidence there is that it was. The "popping" sound heard was down the list of events, and could have been anything. In both cases where I had a blown engine, the noise comes first, then the other issues. If it was the work done on the recall, then that needs to be discovered, but we also don't need to assume that is the cause.
![]() Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#214 |
1st86 Driver!
Even in the video the rear wheels did not stop rotating, it looks like they ended up in the oil, which caused a skid.
#215 |
Or give them an excuse to try and say it isn't their problem!
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#216 |
Ya but he had traction issues well before he said the engine blew. I think there were several factors at work there not just a bearing spinning.
| The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (03-13-2019) |
#217 | |
I'll try to do better - ![]() humfrz |
#218 |
I see tire smoke, hook then explosion. If you are in gear and it blows then the wheels will decelerate rapidly. Not all engine failures would be as dramatic though. A spun rod bearing for example isn't going to seize the engine but some people may still call that a blown engine. A valve spring braking, dropping a valve, hitting a piston, throwing a rod, putting a hole in the block, dropping oil and then exploding is probably what Toyota/Subaru wanted to avoid though.
| The Following User Says Thank You to ermax For This Useful Post: | Dadhawk (03-13-2019) |
#219 | |
Whether the recall caused the engine to blow is the only thing debatable IMO. |
| The Following 3 Users Say Thank You to ermax For This Useful Post: |
#220 |
Only users lose drugs.
Drives: All the time
In the case of the car fire, I suspect the engine didn't blow at all. I'd be much more suspicious of shoddy assembly work causing an oil or fuel leak, eventually resulting in the underhood fire which likely started miles earlier, and eventually destroyed the wiring harness enough to cause the ECU and associated braking systems to start freaking out and their subsequent failures. At any rate, another case of poor dealer workmanship.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#221 | |
| The Following User Says Thank You to ermax For This Useful Post: | Rampage (03-13-2019) |
#222 | |
1st86 Driver!
#223 |
I disagree. With a catastrophic engine failure, the first hint at trouble would have been a whole lot of bad noise, followed by the rest of his symptoms, not the other way around. The FRS owner describes the event as the first time he'd taken the car on an extended drive (3+ hours) since the recall work had been done. A slow leak might not get hot enough to the point of combustion on a daily highway commute, but certainly could on a spirited extended ride through canyon country.
#224 | |
Nothing saying that the braking issues and the engine blowing were the same thing even if they did happen at the same event. But... The downshift may have been the last straw for the engine. All the other reported failures were far less dramatic with just spun bearings. None of them were lifting hoods. If he spun a bearing at the beginning of the events and then down shifted he could very well have thrown a rod and caused the engine to blow, spew oil and burn. THAT I have seen happen at the strip more than once.
| Tags |
| brz, failure, frs, i cant even, j02, recall, so much glue |
| Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 03:46 PM |
| Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 10:12 PM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 06:18 PM |
| BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 03:44 PM |
| Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 09:21 PM |
