#15 | |||||
In my area or the northeast for that matter, no cop will pull you over for this sort of thing. Unless you interfere with your light coloring and it looks similiar to a police vehicle. There's so many situations where people have switchback LED style turn signals that change when something is engaged. Totally depends on what LEDS you get, mine are in no way blinding. Also the choice for white was simply because the entire car is using LEDs now and the matching color combo of lights between 5000k-6000k simply looks best.
#16 | |
#17 |
Drives: 2015 FR-S
Wrong color lights, loud exhaust, too dark tint, etc, just ways for police to have some dumb reason to pull you over.
Most don't take advantage of it though and even if they do, most probably won't be such a twat to give a ticket for it. If they did in FL, it would be all day long tickets for trucks that are too high with bumpers that will decapitate 99% of other drivers on the road along with no mud flaps and tires way outside the body kicking up road debris behind them, and especially lights and fog lights aimed wrong and what can only be described as extra "a-hole lights" that are there just to blind people in front of them. If they aren't getting tickets for all that then having a white instead of amber side marker is waaaay down on the radar for the police. |
#18 | |
Drives: 2014 BRZ Limited
Human eyesight gradually adjusts to darkness so that you can see better in low light the longer you're in it. However, your eyesight also responds differently to different colors of light. Light toward the blue/white end of the spectrum diminishes your ability to see into dark areas, whereas light toward the red end of the spectrum doesn't. This is why pilots use red lights in airplane cockpits at night, so that they don't diminish their ability to see into the dark outside the plane. If you look at a white light source, the unlit areas around it will appear darker (more contrast), and when you look away you will not be able to see quite as well in the dark. That doesn't happen (or not as dramatically) with red lights. This effect is why lights mounted on an automobile facing the rear and sides are required by federal law to be either red or amber. Flashes of white light coming from oncoming traffic can't be helped, but at least it isn't sustained. If you had a sustained source of white light in front of you--for example riding along behind an asshole with white tail lights--your night vision would be impaired from the moment they came into view. The effect on driving is not only that your ability to see to avoid obstacles is diminished, but it also increases fatigue because you will naturally start straining to see around the white light source. Side marker lamps are also required to be amber for this reason, because there's always a chance someone can get stuck beside and behind you for an extended period on the highway with your side marker in view. If you put a white light in there not knowing any of this, that just makes you ignorant. The cure for ignorance is knowledge. But if you keep a white light in there after you learn this knowledge, it means you simply don't give a shit about the safety and comfort of anyone else. And that certainly would make one an asshole. |
#19 | |
Drives: 2013 Scion FR-S Asphalt [Gray]
"Enjoying Performance because of it's nature not because of it's quantity''
| The Following User Says Thank You to TorontoNat For This Useful Post: | Impureclient (03-06-2019) |
#20 | |
Drives: FRS
A lot of cops with push bumpers on there cruisers and firemen and off roaders with winches, etc., etc., don't care . Neither do I. I care about the tail light chaser looking at his MDT, the off roader texting etc. Bumpers don't kill people, people do.
#21 | |
Drives: MY20 Hakone Toyota 86
#22 | |
Just quoted multiple no reason....
#23 | |
Granted, brodozers with the giant bumpers have them only for looks, but those of us who build functional offroad or overland rigs are doing it primarily for function. We also lift for ground clearance and tire clearance rather than to intimidate, and we use big fat tires with lots of sidewall on the smallest rims we can fit over our calipers rather than stupid 22" fake beadlocks with low profile tires you can't air down for traction. The responsible among us then also drive more conservatively on pavement because of the trade-offs we make to be able to leave the road. Besides that, the bumpers don't really make that much difference in an accident. If I hit you hard enough to destroy your car, it's going to destroy it whether the bumper is there or not. On Jeeps with frames like the Wranglers, the stock bumpers are already tied into the frames, so the aftermarket bumpers really don't change anything other than approach angle and accessory support. The stock bumpers just have friendly-looking plastic covers on the end to make them seem safer. On the monocoque Jeeps like my Cherokee, we have found that tying a heavy bumper into the frame rails actually does more damage to our own vehicles in a collision because the bumper remains rigid but crumples the uniframe deeper in at the end of where the bumper ties in. Even low speed collisions with that setup usually end up totaling an XJ. |
| The Following User Says Thank You to extrashaky For This Useful Post: | RFB (03-07-2019) |
#24 |
#25 |
Meow
Drives: GT86, Volvo 996
#26 | |
Drives: FRS
I guess that's why they put cow catchers on the front . ![]()
| FS: Clear Helix side markers and OEM Amber side markers | unlimited86 | Exterior Parts (Aero, Lighting, Etc.) | 15 | 07-06-2015 03:27 PM |
| JDM Clear Side Markers | LANI86 | Hawaii | 2 | 06-29-2015 12:30 PM |
| Genuine Toyota JDM Clear Side Markers / Clear Corners | MotivConcepts | Exterior Parts (Aero, Lighting, Etc.) | 5 | 04-16-2014 09:37 PM |
| FS GA: Helix Clear side markers/ OEM Amber Side Markers | 86TruenoFRS | Exterior Parts (Aero, Lighting, Etc.) | 1 | 03-21-2014 07:06 AM |
| FT: Clear side markers for smoked side markers | Red FRS | Exterior Parts (Aero, Lighting, Etc.) | 7 | 02-05-2014 06:52 PM |
