86WORX
Old 03-03-2019, 11:10 PM   #43
fatoni
How much water are we thinking gets stuck to the rotor as it spins at 4000 rpm? How much pressure would a pad require to displace this seemingly insurmountable volume in relation to the pressure to stop a 3000 lb vehicle? How long would that pad take to clear the rotor in one revolution?
Drive upgrades. Don't buy them.
The Following User Says Thank You to fatoni For This Useful Post:
NoHaveMSG (03-03-2019)
Old 03-03-2019, 11:24 PM   #44
86MLR
86MLR's Avatar
I have the PP Brembo's, running the OEM pads, my car brakes fine, wet or dry, I like the OEM pads due to their initial bite when cold.
The only issue I have in the wet is my Hankook RS4's, so when it rains, I drive to the conditions.
The way I look at it, in every racing series and track day I go to, no one, and I mean no one uses drilled rotors.
Actually thats incorrect, I have seen them used, only to be replaced soon after.
And yes, when it rains here it pours.
But, in the end, spend your money how ever you can justify it.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 03-03-2019, 11:50 PM   #45
Sapphireho
Connection issues
Sapphireho's Avatar
Drives: '15 ultramarine
I spray mine with WD40 when it rains.+1 for fish oil!
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
fuddbutter (03-04-2019), NoHaveMSG (03-04-2019), wparsons (03-04-2019)
Old 03-04-2019, 12:00 AM   #46
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Solid rotors + ventilation on the perimeter = best braking. Crossdrilling is largely for poseurs. Jhooks on some ap racing discs for clearing debris.
https://www.brembo.com/en/company/ne...008-vs-f1-2018
https://www.apracing.com/Info.aspx?I...&ProductID=976
Old 03-04-2019, 12:04 AM   #47
Sapphireho
Connection issues
Sapphireho's Avatar
Sure.
Old 03-04-2019, 07:22 AM   #48
djezlee
Drives: 2017 BRZ Limited
Originally Posted by remhex View Post
Vacuum mode to the seat engages when nothing happens...lol. I mash the brakes harder until they grab. Usually I pre-emptively ride them to dry them off. Only happens in certain spots where road is covered in standing water or pooled up in the frost heaves. Pads are stock performance package. Brakes are amazing to me when its dry out.
Dude, I am experiencing the same thing... and I was thinking the same as you about the rotors. Let me know how it works out. I might not get around to working my brakes until I hit 7500 miles.
djezlee is offline   Reply With Quote
Old 03-04-2019, 09:59 AM   #49
cjd
cjd's Avatar
Drives: 2017 BRZ
I can't say I ever noticed this on the OE Brembos. Nor on the AP Sprint. But I do find that the brakes get cold awfully fast, and cold braking feel is never quite as good.
60mph is about 830rpm at the wheel... or brake rotor. 4000 is nearly 300mph.
Old 03-04-2019, 11:57 AM   #50
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
I've honestly never experienced what you guys are describing. The closest is a general feeling of "soggy" pads after my previous vehicle got sat in a puddle during a rainstorm for awhile. Organic material brake pads tend to intensely dislike sitting in standing water. Otherwise, I can't imagine what would cause what you're describing. I don't have PP Brembos, though.
Tristor is offline   Reply With Quote
Old 03-04-2019, 12:20 PM   #51
reebis
reebis's Avatar
Drives: 2017 WRB BRZ w/PP
Originally Posted by ZDan View Post
My theory:
It's the PP Brembos… They're great, but the the fixed caliper holds the pads nearly perfectly parallel with rotors at all times. When there's a lot of water, there becomes a thin uniform film between pads and rotors that isn't easily displaced with pressure. You press on the brake pedal and get very little response for a very short but very noticeable amount of time.
Sliding calipers will have the pads a bit cocked relative to the rotors, so there's a wedge of water that is easily immediately squeezed out with pressure applied.
I got this phenomenon in a big way on my FD with ST40 Stoptechs. And now I get it with my BRZ PP. Particularly when exiting the carwash! Rotors have to be "cleared" of water before the brakes operate normally.
Very noticeable, very real phenomenon.
I've experienced the exact same with my PP Brembos as well. I posted about it last summer, and have it happen every so often when it's extremely wet out. I mentioned it to the dealer when I was getting a service done, but they told me everything looks fine down there. I attributed it to a combination of brake design and pad material and just make sure to give them a little stab every now and then so I have a pedal if needed. Carwash is a great example as I get it every time as well. Regardless, it is a very unsettling feeling for sure!
reebis is offline   Reply With Quote
Old 03-04-2019, 01:17 PM   #52
fatoni
Yeah I didn't think I needed to be all that accurate to get the point across. My bad.
Old 03-04-2019, 01:20 PM   #53
strat61caster
strat61caster's Avatar
Clearly this is a design flaw covered up by big brake disc manufacturing!
Do what's right for your car, switch back to drums! These new disc type brakes just aren't tested well enough, drums were good enough for my grandpappy and they're good enough for me and my kids!
ineedyourdiddly
The Following 6 Users Say Thank You to strat61caster For This Useful Post:
churchx (03-04-2019), fatoni (03-04-2019), fuddbutter (03-04-2019), humfrz (03-04-2019), NoHaveMSG (03-04-2019), soundman98 (03-05-2019)
Old 03-04-2019, 04:44 PM   #54
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
If water layer is a problem a slotted disc should fix the problem.
If it doesn't then
The Following User Says Thank You to x808drifter For This Useful Post:
Old 03-04-2019, 05:39 PM   #55
GrantedTaken
Here's a better idea.
Don't drive like a moron in the rain.
Notice that like 50% of FTS cars are salvage title.
That's because these cars are owned by idiots
GrantedTaken is offline   Reply With Quote
The Following User Says Thank You to GrantedTaken For This Useful Post:
Tristor (03-04-2019)
Old 03-04-2019, 06:01 PM   #56
Leonardo
Country Boy 4 Life
Leonardo's Avatar
So using that logic... If I haven't crashed my car, then I'm part of the 50% of owners that are not idiots?
Makes sense to me.
I LIKE TIRES!
Search this Thread:
Advanced Search
Rainy weekend, drive carefully doggieboy09 Northern California 4 02-10-2014 04:42 PM
Rainy Day Hooning With A Local FRS And New VR Rareness!! vividracing FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 03-01-2013 01:21 PM
This car hates winter & rainy season? tintumz22 Issues | Warranty | Recalls / TSB 12 11-17-2012 05:36 PM
a rainy day at gingerman sickmint79 Great Lakes 5 10-31-2012 11:58 PM
