#15 |
Drives: Car
Based on responses here, I'm going to give drilled rotors a try. Ill log data brake pressure vs wheel speed before and after rotor install if anyone is interested. Thanks again!
#16 |
Drives: Car
stock wet
time brake psi wheel slip wheel speeds
6.316 0 159.5 255 22.6 0.62 22.4 22.5 22.6 22.6 6.349 0 159.5 255 22.4 -0.16 22.4 22.5 22.6 22.6 6.379 0 188.5 255 22.4 -0.16 22.3 22.3 22.3 22.3 6.41 0 232.1 255 22.4 0.7 22.2 22.2 22.3 22.4 6.441 0 232.1 255 22.4 0.63 22.2 22.2 22.3 22.4 6.475 0 304.6 255 22.2 0.63 22 22 22.2 22.1 6.505 0 362.6 255 22.2 0.48 21.7 21.7 21.8 21.8 6.536 0 362.6 255 21.7 0.89 21.7 21.7 21.8 21.8 6.565 0 406.1 255 21.7 0.89 21.6 21.3 21.7 21.6 6.596 0 406.1 255 21.7 1.22 21.6 21.3 21.7 21.6 6.627 0 449.6 255 21.3 1.22 21.4 21 21.5 21.4 6.656 0 507.6 255 21.3 1.41 21 20.4 21 21 6.689 0 507.6 255 20.9 0.17 21 20.4 21 21 6.72 0 536.6 255 20.9 0.17 20.6 20.4 20.5 20.6 6.755 0 536.6 255 20.5 0 20.6 20.4 20.5 20.6 6.785 0 551.1 255 20.5 0.52 20.4 20.2 20.3 20.3 6.816 0 580.2 255 20.1 0.52 20.1 19.8 20 20 6.849 0 580.2 255 20.1 0.89 20.1 19.8 20 20 6.882 0 580.2 255 19.5 0.89 19.5 19.2 19.5 19.5 6.914 0 594.7 255 19.5 1.01 18.9 18.7 19.1 18.9 6.947 0 594.7 255 18.9 1.58 18.9 18.7 19.1 18.9 6.979 0 609.2 255 18.9 1.58 18.5 18.3 18.7 18.6 7.011 0 623.7 255 18.5 1.23 18.2 18.2 18.4 18.4 7.043 0 623.7 255 18.5 1.07 18.2 18.2 18.4 18.4 7.076 0 638.2 255 17.9 1.07 17.8 17.5 17.9 17.8 7.106 0 638.2 255 17.9 1.01 17.1 17 17.3 17.2 7.138 0 638.2 255 17.3 1.04 17.1 17 17.3 17.2 7.169 0 638.2 255 17.3 1.04 16.7 16.6 16.9 16.8 7.201 0 638.2 255 16.5 0.74 16.7 16.6 16.9 16.8 7.234 0 638.2 255 16.5 0.33 16.3 16.3 16.5 16.4 7.264 0 638.2 255 15.9 0.33 15.9 15.7 16 15.7 7.297 0 638.2 255 15.9 0.34 15.9 15.7 16 15.7 7.327 0 652.7 255 15.3 0.34 15.4 15 15.4 15.2 7.357 0 652.7 255 15.3 1.17 14.9 14.6 15 14.8 7.386 0 652.7 255 14.8 0.6 14.9 14.6 15 14.8 7.415 0 652.7 255 14.8 0.6 14.5 14.5 14.6 14.5 7.445 0 652.7 255 14.2 0.25 14.5 14.5 14.6 14.5 7.476 0 667.2 255 14.2 0.25 14 13.8 14 13.9 7.505 0 667.2 255 13.4 0.13 13.4 13.3 13.4 13.3 7.536 0 667.2 255 13.4 1.74 13.4 13.3 13.4 13.3 7.565 0 667.2 255 12.8 1.74 12.8 12.8 13.1 12.9 7.597 0 667.2 255 12.8 1.53 12.8 12.8 13.1 12.9 7.626 0 667.2 255 12.1 1.53 12.4 12.3 12.6 12.5 7.659 0 667.2 255 12.1 0 11.9 11.9 12 11.8 7.689 0 667.2 255 11.5 -0.77 11.9 11.9 12 11.8 7.719 0 667.2 255 11.5 -0.77 11.4 11.3 11.4 11.1 7.748 0 667.2 255 11.5 0.32 11.4 11.3 11.4 11.1 7.779 0 667.2 255 10.9 0.32 10.9 10.8 11 10.8 7.809 0 667.2 255 10.9 0.5 10.5 10.4 10.6 10.4 7.841 0 667.2 255 10.1 -3.93 10.5 10.4 10.6 10.4 7.876 0 652.7 255 10.1 -3.93 10.2 10.2 9.8 9.8 7.905 0 652.7 255 9.5 0.37 9.3 9.2 9.4 9.2 7.935 0 652.7 255 9.5 1.96 9.3 9.2 9.4 9.2 7.967 0 652.7 255 8.9 1.96 8.7 8.7 9 8.8 7.999 0 652.7 255 8.9 3.12 8.7 8.7 9 8.8 8.029 0 638.2 255 8.2 3.12 8.1 8.1 8.4 8.3 8.058 0 638.2 255 8.2 6.65 7.2 7 7.7 7.5 8.087 0 638.2 255 7.4 0.25 7.2 7 7.7 7.5 8.119 0 623.7 255 7.4 0.25 7 6.9 7.1 6.9 8.149 0 623.7 255 6.6 -0.79 7 6.9 7.1 6.9 8.18 0 623.7 255 6.6 -0.79 6.7 6.6 6.6 6.5 |
#17 |
Drives: Car
stock dry
time brake psi slip wheel speeds
17.714 0 0 255 21.8 0.56 21.6 21.6 21.9 21.9 17.745 0 87 255 21.8 0.56 21.6 21.7 21.7 21.8 17.776 0 116 255 21.4 0.48 21.4 21.6 21.6 21.6 17.81 0 116 255 21.4 0.9 21.4 21.6 21.6 21.6 17.841 0 217.6 255 21.4 0.9 21.1 21 21.2 21.2 17.87 0 304.6 255 21 2.36 20.2 20.2 20.8 20.6 17.9 0 304.6 255 21 2.71 20.2 20.2 20.8 20.6 17.93 0 420.6 255 20.3 2.71 19.4 19.3 19.9 19.9 17.962 0 420.6 255 20.3 2.17 19.4 19.3 19.9 19.9 17.994 0 449.6 255 19.3 2.17 19 18.8 19.4 19.2 18.026 0 507.6 255 19.3 1.68 18.5 18.2 18.8 18.5 18.059 0 507.6 255 18.1 2.26 18.5 18.2 18.8 18.5 18.091 0 536.6 255 18.1 2.26 17.6 17 17.9 17.6 18.121 0 580.2 255 17 3.46 16.3 15.8 16.8 16.4 18.153 0 580.2 255 17 5.63 16.3 15.8 16.8 16.4 18.186 0 609.2 255 15.8 5.63 15.1 14.7 16 15.6 18.219 0 609.2 255 15.8 12.46 15.1 14.7 16 15.6 18.251 0 623.7 255 14.7 12.07 13.8 12.9 15.5 15 18.281 0 652.7 255 14.7 12.07 13 10.9 14.4 12.7 18.314 0 652.7 255 13.2 5.66 13 10.9 14.4 12.7 18.348 0 696.2 255 13.2 5.66 11.3 13.7 13.2 13.2 18.379 0 681.7 255 12.7 17.66 7.9 12.9 12.4 12.9 18.411 0 681.7 255 12.7 23.31 7.9 12.9 12.4 12.9 18.444 0 638.2 255 11.9 23.31 8.1 10.6 12.3 12.1 18.474 0 652.7 255 11.9 -4.42 11.7 11.2 11.5 10.4 18.507 0 652.7 255 11 2.68 11.7 11.2 11.5 10.4 18.538 0 609.2 255 11 2.68 9.7 10.5 10.6 10.2 18.57 0 580.2 255 10.1 9.96 8.5 9.1 10.1 9.5 18.602 0 580.2 255 10.1 0 8.5 9.1 10.1 9.5 18.632 0 594.7 255 8.8 0 9.6 8.6 9.3 8.9 18.66 0 594.7 255 8.8 5.57 9.6 8.6 9.3 8.9 18.691 0 580.2 255 7.9 5.57 8.1 7.2 8.5 7.8 18.721 0 507.6 255 7.9 13.9 7.1 6 7.9 7.4 18.754 0 507.6 255 7.5 2.39 7.1 6 7.9 7.4 18.784 0 435.1 255 7.5 2.39 7 7.3 7.4 7.2 18.816 0 435.1 255 7 2 7 7.3 7.4 7.2 18.85 0 348.1 255 7 0.27 6.8 6.9 7 7 18.882 0 232.1 255 6.5 0.27 6.4 6.5 6.5 6.5 18.913 0 232.1 255 6.5 1.15 6.4 6.5 6.5 6.5 18.945 0 174 255 6.1 1.15 6 6 6.1 6.1 |
#18 |
Drives: Crapcan
More or less proves nothing. Especially with ABS doing work for you.Your limiting factor is always going to be the available traction of your tires.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Tristor (03-03-2019) |
#19 |
Drives: Car
Abs wasn't coming on. I'm not trying to prove a thing to you folks. Data is data. We'll see if it changes after new rotors. All of your answers convinced me drilled rotors weren't a bad idea. I hate the way they look but who cares if they help out.
#20 |
Drives: Crapcan
They actually are not a good idea and previous comments look like trolling to me. There is no benefit and they are prone to cracking under very hard use.
#21 |
Drives: 2014 GT86
If friction of brakes is sufficient to lock brakes, it's always traction of tires that will change braking distance. And do you trust yourself being that consistent of a driver to always tresholdbrake to exact same extent/friction and press brake at exact same rate for that to not to not be variable affecting results? I'd probably would trust ABS assisted locked brakes to be more consistent/repeatable then that of braking legwork of most drivers (of course if other variables are taken care of as much as possible too, eg. ambient temps, brake temps, tire temps & wear and so on ..).
+1 to no for drilled rotors for heavy use. |
#22 |
Drives: Car
I'm not trolling. I got the feeling you folks just had no idea what I'm talking about. I didn't see anyone with a similar issue. If I apply light brake pressure, brakes won't respond when soaked for a few seconds. I apply more pressure they work but not nearly as responsive as warmed up dry brakes. I'm not hard enough on my brakes to crack them. I agree that drilled rotors aren't ideal for normal use, less surface area for pads to bite on. I ended up doing some more research on some other forums and using drilled rotors isn't uncommon for wet conditions. Neither is tapping them every once in a while to keep them dry. Brembo's website specifically lists use of drilled rotors for better wet weather performance. Same with porsche and some other ones. They can't all be wrong. I figured since the performance package has larger pads and rotors, that's less psi on the disk per an amount of braking compared to non pp brakes. Sorry to anyone who got offended in internet land. I'm done with this thread so don't worry bout it.
#23 | |
Drives: Crapcan
I've never noticed a change in braking due to weather conditions, even on track. You'd have to splash the brakes with water pretty hard to have to deal with what you are describing. Sent from my Moto E (4) Plus using Tapatalk
#24 |
Dismember
Drives: 2013 Red Scion FR-S
I want a rainy day woman.
#25 |
I would replace my pads with something fit for purpose temp and conditions wise, by conditions I mean street or track, and good tyres.
I had drilled rotors on a Skyline I purchased, they cracked up after a few track days. Drilled rotors are more about weight saving IMO. Solids are fine, I'm still out on wiper slots, I understand their principle but have never noticed a difference.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#26 |
fabulous
I need to tap dat ass every once in a while.
#27 |
Why don't you just brake hard enough to slow down to the desired speed?
Drive upgrades. Don't buy them.
| The Following User Says Thank You to fatoni For This Useful Post: | ermax (03-04-2019) |
#28 |
| Rainy weekend, drive carefully | doggieboy09 | Northern California | 4 | 02-10-2014 04:42 PM |
| Rainy Day Hooning With A Local FRS And New VR Rareness!! | vividracing | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 7 | 03-01-2013 01:21 PM |
| This car hates winter & rainy season? | tintumz22 | Issues | Warranty | Recalls / TSB | 12 | 11-17-2012 05:36 PM |
| a rainy day at gingerman | sickmint79 | Great Lakes | 5 | 10-31-2012 11:58 PM |
