Old 03-06-2019, 03:27 PM   #99
stevo_12v
stevo_12v's Avatar
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Damn, some nightmare stories in here. Jun 2012 build here. Glad I'm going for a full rebuild instead of sending it back for a 'recall'.
$8.5k for a new shortblock? You can get an Outfront with that kinda money. Did you ask them if it came with a BJ
[CENTER]
Build thread
stevo_12v is offline   Reply With Quote
Old 03-06-2019, 03:40 PM   #100
humfrz
Originally Posted by MuseChaser View Post
OK... I'll go check again. It's cold now, but hasn't been moved since I took that pic. Place your bets... ..
Now that I look closer, I agree that the level looks to be a bit above the lower hole. The upper hole doesn't look like there is any oil in it -
humfrz
Old 03-06-2019, 03:49 PM   #101
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
humfrz
Yeah, I can see why folks see that in the first pic I posted yesterday... it's just a bad shot. To be honest, I didn't even realize those were holes.. I thought they were marks! In any case, though, they were both full and then some. Look at the pics I edited into my previous post a few minuts ago.
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
Old 03-06-2019, 04:00 PM   #102
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Yeah, that's too much.
Some vinyl tubing and a dollar store turkey baster down the dip tube will get you to a less congested level.
Or a FuMoto drain valve.
Old 03-06-2019, 04:10 PM   #103
ermax
ermax's Avatar
How would you see the level with a Fumoto valve?
Old 03-06-2019, 04:12 PM   #104
ermax
ermax's Avatar
Oh yeah, that picture shows a completely different story.
Old 03-06-2019, 04:23 PM   #105
bcj
Geo Tyrebighter Esq
bcj's Avatar
Much simpler to drop out a measured quart or so without losing the whole fill.
Or you can undo the sump plug and get oil all over your nitrile gloves and the floor.
... and your elbow, and, and ...
... and this should probably be in another thread altogether.
humfrz (03-06-2019)
Old 03-06-2019, 04:51 PM   #106
Pinoy_FRS
Drives: Ultramarine
Just got mine back yesterday. I’m noticing a very faint smell of burning oil. Can that just be related from getting a new short block?
Pinoy_FRS is offline   Reply With Quote
Old 03-06-2019, 05:24 PM   #107
humfrz
edit: OK, back with two pics, one of each side of the dipstick. Another thing I've noticed the past couple times I've checked the oil is that, when I check it cold, the color is MUCH different than it does when warm. When warm, the oil looks brand new, clear, and very hard to see, but cold it looks a lot darker, especially for oil that is only 630 miles and a few weeks old. Does that indicate anything, other than that dirt has had time to settle? Wouldn't the dirt settle below the dipstick anyway?
On the first pic, one of the arrows points to one little circular dry spot. BOTH the high and low level holes are completely full of oil, and the level is clearly above the high mark, more so on one side. Soo.. close enough, or drain some? Right now, it doesn't look any higher than it does when I get it back from a dealership oil change.
I reckon it's OK, I'd leave it alone.
When your eyes get a bit older, I suggest you have someone else check the oil in your car - your track record is indicating that -
I know that when I read the oil level on my dipstick, with my macular degeneration and poor low light eyesight and wearing trifocals, I can "read" almost anything I want to see.
humfrz
ermax (03-06-2019)
Old 03-06-2019, 05:28 PM   #108
humfrz
It's most likely just some stray oil burning off, not to worry.
Just don't read anymore posts about the after action reports from some folks that have had the recall work done -
humfrz
ermax (03-06-2019)
Old 03-06-2019, 05:30 PM   #109
ermax
ermax's Avatar
Nevermind I misread your post. You were talking about draining oil not checking the dipstick. Hahaha
Old 03-06-2019, 05:48 PM   #110
Pinoy_FRS
Drives: Ultramarine
humfrz
Oh I feel like I was one of the founding fathers of catastrophic post recall work haha Spun rod bearing resulted in a new short block. Here I am a day later. Let’s see how long this holds up
The Following User Says Thank You to Pinoy_FRS For This Useful Post:
humfrz (03-06-2019)
Old 03-07-2019, 08:09 AM   #111
BRZnut
Drives: BRZ DGM Limited
Who paid for the new short block?
Old 03-07-2019, 09:06 AM   #112
Ongor
Drives: 2013 Scion FR-S, Hot Lava
Hey Pinoy,
I had the same thing when I got mine after the recall work. I also thought it was some remaining oil.
385km later, it started knocking and my engine died.
Just to be sure, keep checking, keep "being paranoid" about it for a while, and if you doubt, bring it back asap.
Ongor is offline   Reply With Quote
Valve spring recall - where did you get it done? satisfied with the work? fiveoneoh Northern California 105 09-25-2020 03:10 PM
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 10:32 PM
valve spring recall/ additional work performed when engine is out swfrs Issues | Warranty | Recalls / TSB 172 07-31-2019 01:10 AM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-09-2019 12:38 AM
Valve Spring Recall venturaII New England 13 02-25-2019 08:41 PM
