86WORX
Old 01-13-2022, 11:00 AM   #239
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Originally Posted by Erroneous View Post
Ah, so the Toyota guy lied when he said the DI ECU isn't removed during the valve spring replacement.
I do get the argument that 10,000 miles is a long time to go without seeing problems, but if it wasn't attached properly (per the other Toyota service guys), it had to be the last person to remove it that was responsible. And that's the service guys on the valve springs.
Thanks for your input. Not sure where I go from here. I only asked Toyota to reimburse like $150 for the fix and that was the response I got. Pathetic from a customer service standpoint.
If anyone is in NC, I'd avoid Toyota of Charlotte.
DI ECU and ECU are two different things.
You stated that the service tech said they didn't have to remove the ECU which is true.
You need to specify.
And I'm sure you asked about them removing the ECU and not the DI ECU.
10k after the recall and it could have been a number of things. which is why they aren't helping you.
Like was said above if it was something they did it should have started way sooner.
Bolts do work themselves loose sometimes. Mine did.
The Following User Says Thank You to x808drifter For This Useful Post:
Erroneous (01-13-2022)
Old 01-13-2022, 02:46 PM   #240
Erroneous
Drives: Mitsubishi Eclipse
No, I sent him the service invoice that literally said the direct injection ECU was not bolted on correctly. So either he didn't look at what I sent him or he was incorrect/dishonest (assuming you are indeed correct). I didn't specify in the thread here, so sorry for the confusion.
My issue is that the DI ECU was fine for 60k miles. Then it was removed, reattached, and failed within 10k miles. If it failed within 10k miles from factory, it wouldn't be acceptable. That said, I don't think their work is warrantied for that long so ultimately if they don't want to take responsibility, whatever.
BUT it's pretty terrible customer service to shift blame and not acknowledge the reality that they probably didn't tighten the DI ECU properly, especially when a Toyota service center said as much. A simple reimbursement of the cost to correct their error seems like a small ask, IMO.
Erroneous is offline   Reply With Quote
The Following User Says Thank You to Erroneous For This Useful Post:
x808drifter (01-14-2022)
Old 01-13-2022, 03:29 PM   #241
TommyW
TommyW's Avatar
Drives: '13 Whiteout
You got off easy. While nursing my car back from Laguna Seca with rod knock after the recall blunder, my clutch went out in heavy traffic on the freeway leaving me stranded out in the middle. Cause of clutch failure? Toyota dealer forgot to tighten down the clutch fork. Insult to injury
Old 01-13-2022, 03:38 PM   #242
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It is also possible he misunderstood you since it is not called a DI ECU. It is an injector driver module. It basically takes the signal from the ECU and does the work so that the ECU is not handling those loads. Kind of like how you use a switch with a relay to activate something so that the switch is not taking the load.
Valve spring recall - where did you get it done? satisfied with the work? fiveoneoh Northern California 105 09-25-2020 03:10 PM
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 10:32 PM
valve spring recall/ additional work performed when engine is out swfrs Issues | Warranty | Recalls / TSB 172 07-31-2019 01:10 AM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-09-2019 12:38 AM
Valve Spring Recall venturaII New England 13 02-25-2019 08:41 PM
