86WORX
Old 03-08-2019, 06:04 PM   #141
ermax
ermax's Avatar
Originally Posted by tomm.brz View Post
@ermax so he was tuned even before the recall and after:P
didn t expect the dealer to find proof on ecu other than miles count/crank cycle count reset
@Magoo did you unmarry your OFT before bringing back your broken car after the recall?
You had a lucky guess. :P
Regardless it's still a BS excuse to get off the hook for shit work.
The Following User Says Thank You to ermax For This Useful Post:
Ultramaroon (03-08-2019)
Old 03-08-2019, 06:10 PM   #142
ermax
ermax's Avatar
Originally Posted by maslin View Post
A short block is a built bottom end. That wouldn’t even address the valve spring issue the recall is for. It would need to be a long block or a complete engine.
Again, not Subaru/Toyota but.... our engines come that way. Either a long block, swap injectors, manifolds, all electronics and harness. Or complete minus accessories. Manifolds, injectors, harness all ready to go.
It’s an issue of money. The labor charge wouldn’t be much different, maybe 2 hours less to replace the engine. The parts price would be much higher. Valve springs and seal kit has to be under $500. Our engines are $10k+
I replaced an engine on a new-ish car that was $60k. The whole car was only $65k
If you do the 12 hour recall and then the engine blows you are out for the cost of the recall kit, 12 hours of labor, the cost of a short block (1800) and an additional 24 hours of labor. If you factor all that in then going directly to a full engine swap doesn't look so bad.
Old 03-08-2019, 06:52 PM   #143
tomm.brz
Drives: brz 2017 hksv2
i sure don t care if I had right or not, i d just want to understand better this thing
What Magoo wrote about what dealer said, seems to me that they found something that gives them leverage against him, but what in particular?
it would be also interesting for people who care about warranty of a new car but tune it without worrying too much
I don't have access of course to the ecu like the dealers have, i just have a friend, that has a friend , that is a tech at a Subaru dealer and he said with a software called GTS (?) they can see a hystory of everything, rpm reached, eventual rpm overrange and don't know what else, and those things shouldn't just erase by themself with just a battery disconnect..
but got nothing more to it than that
The Following User Says Thank You to tomm.brz For This Useful Post:
ermax (03-08-2019)
Old 03-08-2019, 06:53 PM   #144
Magoo
Magoo's Avatar
Drives: 2013 Scion FRS
I just put the stock tune back on the car.
They stopped short of calling me out on it, said it was consistent with what they've seen in the past with the ECU being reflashed and they were going to run with that and not take the blame.
Sent from my Pixel 2 using Tapatalk
Magoo is offline   Reply With Quote
Old 03-08-2019, 06:57 PM   #145
tomm.brz
So the best for people doing the recall is to just keep stock tune after the recall and wait a bit so if breaks like yours at least they won't have the dealer against them regarding if the ecu was reflashed or not
that s very unfortunate for you not much you can do about it..
Old 03-08-2019, 10:06 PM   #146
ermax
ermax's Avatar
Unless he can find proof they made errors on the rebuild. For example it’s hard to blame a tune for a plugged pickup screen.
Old 03-08-2019, 10:36 PM   #147
BRZBlack
BRZBlack's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by fang_gt86 View Post
So, should I ignore the recall and risk the chance of a crash. Or, take it in and risk the chance of a perfectly running car that's completely ruined..
This. I'm not sure what to do..... And I am 2 months away from paying it off.
BRZBlack is offline   Reply With Quote
Old 03-08-2019, 10:56 PM   #148
humfrz
I'd suggest you wait till it's paid off - then you won't be making payments on a non running car.
(shit - I've been reading too many recall threads - )
humfrz
NoHaveMSG (03-09-2019)
Old 03-08-2019, 10:59 PM   #149
CraigVM
Drives: Car Collector
Picked mine up this morning. Seemed to run just as before during my 15 min drive home. I checked oil finding it at normal level and clean. Guess I will check to make certain it has antifreeze and not just replaced with just water
Odd thing is the odometer did not increase a single mile between drop off and when I picked it up. No test drive needed ??? Repairs done within 48 hours after I dropped it off.
What stinks is normally the car would just sit in the garage for another couple of months waiting for dry / Spring weather. Now I feel compelled to put some winter miles in to find any recall work issues if present.
CraigVM is offline   Reply With Quote
Old 03-08-2019, 11:02 PM   #150
Ultramaroon
fabulous
Ultramaroon's Avatar
Added a quote to my sig line.
BRZBlack (03-09-2019), Teseo (03-08-2019)
Old 03-08-2019, 11:08 PM   #151
Teseo
Drives: frs
I pass that mark long time ago, even before knowing this site exist
The Following User Says Thank You to Teseo For This Useful Post:
Ultramaroon (03-09-2019)
Old 03-09-2019, 12:38 AM   #152
humfrz
I reckon that would be a good idea -
humfrz
Old 03-09-2019, 01:26 AM   #153
Ultramaroon
fabulous
I have been expressing my professional opposition to this idiotic recall since I first heard about it. All the springs that were going to fail have already done so long ago.
humfrz (03-09-2019), Teseo (03-09-2019), why? (03-09-2019)
Old 03-09-2019, 03:00 AM   #154
humfrz
That's where I'm strongly thinking about putting my money. -
humfrz
Ultramaroon (03-09-2019), why? (03-09-2019)
Valve spring recall - where did you get it done? satisfied with the work? fiveoneoh Northern California 105 09-25-2020 03:10 PM
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 10:32 PM
valve spring recall/ additional work performed when engine is out swfrs Issues | Warranty | Recalls / TSB 172 07-31-2019 01:10 AM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-09-2019 12:38 AM
Valve Spring Recall venturaII New England 13 02-25-2019 08:41 PM
