Old 08-26-2012, 05:47 PM   #617
LeftFootBrake
LeftFootBrake's Avatar
Drives: White 86 GTS AT
Originally Posted by Jedi1 View Post
I had an issue with my auto trans not holding 3rd gear at red line after about 15 minutes into an on track session. The dealer has ZERO clue why this is happening
If the tune will remedy this issue, I'm in!
If it helps any, the manual states that if the engine oil temperature is high it may choose to upshift even in Manual mode.
Originally Posted by carbonBLUE View Post
VSC sport AND SPORT activated at the same time in "M" mode allows an even greater angle before intervention
BTW, although we've already discussed waiting for facts, the manual contradicts this statement. It states "If sport mode is changed to while the select lever is in the M position, the SPORT indicator will come on but sport mode controls will not be carried out. Shift the select lever to the D position."
So, it sounds like the car is letting us turn it on, but it only does something once we're back in D, where it then just changes shift characteristics. FWIW, I wish they would have carried this philosophy across to when the the cruise control is set. But I don't want to hijack John's thread, so best leaving it there for now I expect.
LeftFootBrake is offline
Old 08-26-2012, 05:51 PM   #618
CharlieChaos
Drives: FRS
Going thru the list right now...
Preparing tune files in between downtime on the dyno ..
I know there is no way to express on the forum how much we all appreciate the work you are doing for us. Im sure its people being anxious more then anything.
CharlieChaos is offline
Old 08-26-2012, 08:30 PM   #619
Visconti
Drives: 05 STi
Well no more clutch and need more wastegate spring.
Gonna grab some food
Visconti is offline
The Following User Says Thank You to Visconti For This Useful Post:
cobrabyte (08-26-2012)
Old 08-26-2012, 09:18 PM   #620
Jedi1
STX build in progress!
Jedi1's Avatar
Drives: Whiteout FRS. Just Gorgeous!
So, there are theories as to why my auto trans upshifts in 3rd on its own, but it seems nobody knows exactly why its doing this. It holds redline and bounces off the limiter in 1st and 2nd, but 3rd seems to have a mind of its own.
Jedi1 is offline
Old 08-27-2012, 12:43 AM   #621
LeftFootBrake
Was [reduced AT -vs- MT power] on the stock tune?
The picture's back and according to the comments, yes (but it's nigh on impossible to assume all other things equal, such as oil temp and the mystery of any sports mode impact, we can't forget): http://www.facebook.com/photo.php?fb...type=1&theater
Old 08-27-2012, 11:39 AM   #622
Visconti
Drives: 05 STi
Still getting those tunes done.
50% of them are ready to be emailed
Visconti is offline
The Following 5 Users Say Thank You to Visconti For This Useful Post:
dabocx (08-27-2012), SkAsphalt (08-27-2012), vubaru (08-27-2012), xjohnx (08-27-2012), Yruyur (08-27-2012)
Old 08-27-2012, 12:18 PM   #623
Visconti
Drives: 05 STi
There is absolutely no reason to email, txt or call me about your STG1 flash right now.
Updates about the flash and deployment info will be in this thread.
I was preparing all the flashes but keep getting interrupted
John
Visconti is offline
The Following 2 Users Say Thank You to Visconti For This Useful Post:
dabocx (08-27-2012), tripjammer (08-27-2012)
Old 08-27-2012, 01:24 PM   #624
vubaru
Now with Boost!
vubaru's Avatar
Drives: 2013 SWP BRZ Ltd.
John
Word, thanks for the update man.
Will be giving you radio silence until I hear back so you can get shit done.
vubaru is offline
Old 08-27-2012, 03:25 PM   #625
Visconti
Drives: 05 STi
First page has been updated screen shots on HOW TO flash your car after installing EcuTek ProECU software.
Please let me know if anything looks confusing.
John
Visconti is offline
brichard0625 (08-27-2012), civicdrivr (08-27-2012), JPxM0Dz (08-27-2012), Opposed (08-27-2012), vubaru (08-27-2012)
Old 08-27-2012, 03:35 PM   #626
Visconti
Drives: 05 STi
Just emailed out the first tune of the day... oh and it's a automatic !!
Check your email......................
Visconti is offline
Old 08-27-2012, 04:31 PM   #627
DSTL
Drives: 2013 BRZ Limited 6MT
John
Thanks John. Do we need to back up our factory tunes prior to flashing the new one? Is that a simple process if we were wanting to do that?
DSTL is offline
Old 08-27-2012, 04:42 PM   #628
Visconti
Drives: 05 STi
You dont need to - but you can.
After your Query the ECU you will want to 'Read Rom'
-John
Visconti is offline
Old 08-27-2012, 04:45 PM   #629
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
And btw if anyone is in the tristate area and needs help loading the software come by Prime! And if you need convincing on an e85 tune I can do that as well
PrimeMotoring is offline
The Following User Says Thank You to PrimeMotoring For This Useful Post:
Old 08-27-2012, 04:48 PM   #630
xjohnx
Grip>Slip
xjohnx's Avatar
-John
And if we didn't do that before flashing? What are our options then?
xjohnx is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 03:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) -- General Topics 0 05-24-2012 11:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 08:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) -- General Topics 130 09-01-2011 02:42 PM
