#3361 | |
Drives: Hot Lava FR-S
1. Stop the car 2.go to neutral with clutch out 3. Clutch in and go to first 4. Mash the gas HARD. You've got to be WOT 5. Revs should bounce off of 4k(or whatever you have set) 6. While revs are bouncing push the CC stalk up or down to adjust your RPM setting. I had a problem because I have a habit of shifting to first and leaving clutch in before I'm fully stopped, but I guess for LC to work it has to see 0mph and then neutral and then first. I was going to first before stopping fully. Sent using mobile Tapatalk App |
#3362 | |
I'm also working on a meth kit fails afe that's wired into the Ecu. Right now I'm sorting out the wiring, but the plan is full plug and play no cutting of anything John |
| The Following 3 Users Say Thank You to Visconti For This Useful Post: |
#3363 | ||
That Guy
Drives: 2013 asphalt FRS MT
How many inputs do you think can be added, so far you've spoken of a flex fuel sensor, boost solenoid and now a meth kit? Is there any chance of running all of these simultaneously? It would be a metric fuck ton of tuning but all three of these working in concert could make for a very flexible and safe setup. |
#3364 |
I'm not sure if I can do all 3 at the same time RIGHT now, but I can Master Phil @ EcuTek to do somethingn for me.
How I see it is if your running meth then you most likely have no e85.. which means you dont need the flex fuel stuff -John |
| The Following User Says Thank You to Visconti For This Useful Post: | Calum (10-28-2012) |
#3366 |
@Visconti did you copy my dongle id from the most recent forms or an older one. I just remembered my first tune was using a loaner from another member here but that was a long time ago.
Sent from my SCH-I535 using Tapatalk 2 |
#3367 |
Most recent..
The loaner cables tuners were labeled differently on my folder system so I know what dongle ID that is. |
#3368 |
Here is my screen shot. Is it possible my vin is wrong or is the error message only for the dongle id?
#3369 |
Drives: 2013 BRZ Limited 6MT
Mine started right up after sitting 3 hours last night. Upper 30s out. Sat overnight now and will do a cold and warm start log in the next hour.
| The Following 2 Users Say Thank You to DSTL For This Useful Post: | Area86 (10-28-2012), TyperRspec789 (10-28-2012) |
#3370 |
When In Doubt...
Drives: Slowww
This is intoxicating...
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
#3371 |
That Guy
Oh yeah. In case anyone cares about the driveability issues I mentioned a couple pages back. It seems like the ECU just didn't have all the info for those areas as it's smoothed now. I did notice it a little bit yesterday but it was gone once the car warmed up. I'm guessing it's an open loop/cold start issue but even then it seems to be sorting itself out.
#3373 |
Drives: 2018 Subaru BRZ tS
Just to get this straight, I should be getting my cable in Monday - Tuesday... If I got an older Tune file from john, can we flash that or do I need a new one?
RR-10826-FF-LL-AB-ZA1J700C-STG1 v1.07-6AC5C5.BIN 1284K Download ZA1J700C-enc.BIN 1284K Download Got them Oct 15th. |
#3374 | |
Drives: '13 DGM BRZ Limited
| LED Front Signals with Resistor Flash Correctors | DarrenDriven | Cosmetic Modification (Interior/Exterior/Lighting) | 38 | 09-20-2012 03:05 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 11:09 PM |
| How to embed a flash gallery? | DarrenDriven | Site Announcements / Questions / Issues | 2 | 04-24-2012 08:43 PM |
| Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors | blur | BRZ First-Gen (2012+) -- General Topics | 130 | 09-01-2011 02:42 PM |
