Old 10-18-2012, 02:58 PM   #2829
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by cobrabyte View Post
This is how I thought it worked from the get-go. Obviously, that's not the case.
You'd have to set it up to where individual vehicles could have certain tweaks but that's just a case of deltas off the base map.
Sigh... wish I worked at ECUtek. Lazy people always come up with the best time-saving ideas.
sysadmin too?
xjohnx is offline
The Following User Says Thank You to xjohnx For This Useful Post:
cobrabyte (10-18-2012)
Old 10-18-2012, 02:59 PM   #2830
rainmonkey
Drives: BRZ - Dark Grey
'efficiency is intelligent laziness'
-Bloomberg quote of the day
rainmonkey is offline
Old 10-18-2012, 03:01 PM   #2831
SkullWorks
Drives: SSM LT MT BRZ
Originally Posted by xjohnx View Post
One other option that could make it even easier, depending on how far ECUTek wants to take it, rather than automatically emailing the maps to the user, it could be setup so that the updated maps are sent to ECUTek. Then the next time that dongle ID runs ECUTek update it would automatically downloaded any new maps associated with that ID.
Just spitballing, but there's a ton of opportunity for time savings in there somewhere.
BRB, running to the patent office.
...I have never been a fan of auto updating on any system where it isn't paramount to the security of the device...(microsoft products)
you would want to know what features are enabled/disabled with each update and any conflicts since these cars are becoming more and more individual...just my .02 tuning shouldn't be taken so lightly as a firmware update to a directTV box...if there is a conflict you may be notified by a cacophony of bad noises, or an unfamiliar driving experience, I would never opt for my ECU to be auto updated....heck i dont even like upgrading the firmware on a Standalone...once it works and is setup and tuned...leave it alone is a good way to keep it together.
SkullWorks is offline
Old 10-18-2012, 03:03 PM   #2832
xjohnx
Grip>Slip
xjohnx's Avatar
I'm sure it could be made to display any release notes and prompt you before applying any updates.
besides, the cable isn't going to sneak out with your laptop in the middle of the night to go update your ECU when you're not looking.
xjohnx is offline
Old 10-18-2012, 03:05 PM   #2833
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
OK - I have responded to everyone that filled out my Request Form.
Going to Lunch, then picking up my new shipment of cables.
Then some auto tunes
John
Sweet!!! For those who added on your e85 map I'm assuming that will be one of the four maps. Also since the autos do not have as many features as the manuals what will our map layout look like? Something like this would be cool for those with Stge 1 and e85. Thoughts? Though I could do without the A/F reading and Fuel Tank % if it's causing the fuel gauge to act up. I'm already using Torque for A/F readings. I would be good with just simple stge1 to e85 map switching.
Map 1 - e85 Tune + 8000RPM Rev Limiter in 2nd Gear + A/F Reading
Map 2 - e85 Tune + 8000RPM Rev Limiter in 2nd Gear + Fuel Tank %
Map 3 - Stge 1 Tune + 8000RPM Rev Limiter in 2nd Gear + A/F Reading
Map 4 - Stge 1 Tune + 8000RPM Rev Limiter in 2nd Gear + Fuel Tank %
Area86 is offline
Old 10-18-2012, 03:15 PM   #2834
DSTL
Drives: 2013 BRZ Limited 6MT
I'm excited for the flex fuel tune. Then all maps could adjust to fuel AND once it's refined enough could add a few gallons of pumpgas to the tank for better startups and cold weather performance. Guessing it will adjust to actual ethanol % once in its final form?
DSTL is offline
The Following User Says Thank You to DSTL For This Useful Post:
Area86 (10-18-2012)
Old 10-18-2012, 03:18 PM   #2835
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
So i guess I do need to fill out the form again, will do tonight I guess.
SkAsphalt is offline
Old 10-18-2012, 03:19 PM   #2836
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Curious to hear about the E85 stuff, too. Gonna pull the trigger on that functionality soon. You know... for the track.
cobrabyte is offline
Old 10-18-2012, 03:24 PM   #2837
cobrabyte
cobrabyte's Avatar
I hear you. To do this right, each 'generated' tune file would be passed through a verifier to make sure all variables are within a set of limits. Our ECUs are pretty awesome as far as what's possible. Definitely approaching set-top box reliability/programmability.
Old 10-18-2012, 04:24 PM   #2838
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Form filled out!
Old 10-18-2012, 04:26 PM   #2839
Foobar
SLO NO MO
Foobar's Avatar
You didn't get the sentient cable version from John? Maybe it was only the first so many purchasers of the groupbuy...
Anyway, be afraid. The cable is alive.
Foobar is offline
Old 10-18-2012, 05:11 PM   #2840
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Auto updates can be bad. Look what happened in I, Robot to Will Smith. Your DTRL will turn red and your evil Toyoburu will try to kill you.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline
Old 10-18-2012, 05:12 PM   #2841
cmss2000
Drives: 2013 BRZ Premium 2012 Acura TSX
Fill out my request form
Another form to fill out??? Where's this one??
cmss2000 is offline
Old 10-18-2012, 05:25 PM   #2842
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
here you go buddy
http://www.ft86club.com/forums/showp...postcount=2617
The Following User Says Thank You to SkAsphalt For This Useful Post:
cmss2000 (10-18-2012)
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 03:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) -- General Topics 0 05-24-2012 11:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 08:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) -- General Topics 130 09-01-2011 02:42 PM
