#2661 |
Drives: Argento 6spd FR-S
Well I messed with it more today, all the features do work I just didnt know what I was doing. To check/set LC you hold it all the way to the floor and it will bounce off what its set too. then you use the cruise to adjust up or down.
FFS is the same it only works if you have it all the way to the floor. I still dont get some stuff. like why if I have it on map 3 i think, and I have it set to outside temp, my gas gauge goes to empty. So, It would be nice to have a list of what the different stuff is. |
| The Following User Says Thank You to cruzinbill For This Useful Post: | JPxM0Dz (10-17-2012) |
#2662 | |
F Z1LLA
Drives: Lexus IS-F Series 2
Yeah I messed around with it also switching between maps, however I did not see any info anywhere on the display for remaining fuel or other info depending on what map your running ?? Sent from my GT-I9300 using Tapatalk 2
2URGSE |
#2663 | |
VehicleDynamicsSpecialist
Drives: iG FR-S
"The best track modification you can ever make is between the steering wheel and seat." - CSH |
#2664 | |
FRS2DTH
Drives: Hot Lava 2013 Scion FRS
I had the same issue, the tank went back up when i filled the tank, but i dont know if its fixed or just stuck at full. Will know when i go home tonight. |
#2665 |
Drives: 2013 firestorm FRS
I think the tune is great overall after using it for a day, but I do have one issue. Below 1.6k rpms the engine studders a good bit and it sounds like it can't decide to use direct injection or not. This gets very noticeable in traffic. I'm hoping it can learn its way through it, but it's not as good as stock was in that range..
| The Following User Says Thank You to Genomaxter For This Useful Post: | xjohnx (10-17-2012) |
#2666 | |
I could be wrong, but seems to me thats what it is, and this is on map 3 |
#2667 | |
FRS2DTH
#2668 |
Map 1 - Fuel Tank %
Map 2 - A/F Ratio + Flat Foot Shifting, Launch Control, AutoBlip Map 3 - 0-60 Timer + Flat Foot Shifting, Launch Control, AutoBlip Map 4 - 1/4 Timer + Flat Foot Shifting, Launch Control, AutoBlip Seems like the fuel gauge is getting pissed off at the 0-60 & 1/4 timer. Switch out of map 3/4 after doing your run. Ill have more updates / info tomorrow John |
| The Following 4 Users Say Thank You to Visconti For This Useful Post: |
#2669 | |
FRS2DTH
I'll fill out a form for ya when i get a chance here John, thanks for the list too, helps me make sense of the numbers now. |
#2670 |
Trident Motorsports Owner
Drives: DGM. DD for my EvoX
My maps are different I guess
Map1 AFR and if the ac is on the rpms jump back and forth from 800-1200 when I'm at idle Map2 something like 0-60 Map3 I think is 1/4 mile time and my gas gauge drops to empty Map4 I have no idea I haven't been messing with it much except when John was having me test. I am waiting to get the tune that will put me on the same page as the others.
previous cars:1998 chevy s10 2001 Prelude SH 1992 (JDM)RX7 FD Current Cars:2010 Mitsubushi Evo X GSR 2013 Subaru BRZ Sponsors:Mishimoto/Flossy/Tomei
Craig.tridentms@gmail.com |
#2671 |
Drives: Pearl 86 GT
Waiting patiently for my tune...
White GT | Visconti_TUNED
#2672 |
Ridge Racerrrrrrrrr
John, do I need to fill out the new form if I have not yet received a tune file?
I have filled out previous forms. Thanks.
| The Following User Says Thank You to SkAsphalt For This Useful Post: | JPxM0Dz (10-17-2012) |
#2673 |
When In Doubt...
Drives: Slowww
Woooooo got my new tune. Now I just have to fight the urge to leave work...
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
#2674 | |
F Z1LLA
So you have the latest tune with different map locations ?
2URGSE |
| LED Front Signals with Resistor Flash Correctors | DarrenDriven | Cosmetic Modification (Interior/Exterior/Lighting) | 38 | 09-20-2012 03:05 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 11:09 PM |
| How to embed a flash gallery? | DarrenDriven | Site Announcements / Questions / Issues | 2 | 04-24-2012 08:43 PM |
| Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors | blur | BRZ First-Gen (2012+) -- General Topics | 130 | 09-01-2011 02:42 PM |
