86WORX
Old 10-16-2012, 01:50 PM   #2633
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Originally Posted by xjohnx View Post
i was going to but then someone else said they were on it.
Originally Posted by LeavingNormal View Post
Hawaiian said he's got a video already just needs to put it together and post it.
Thanks Guys
2URGSE
JPxM0Dz is offline
Old 10-16-2012, 01:53 PM   #2634
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
John's watching the form for updates. No need to post here after completing it.
But it does give me a good idea of how many people are ahead of me
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline
Old 10-16-2012, 01:56 PM   #2635
boris
Drives: 2013 white scion frs
Hi guys. Just want someone to confirm with me that we can flash the car now. The only catch is we have to update the program once a day right? Thanks
boris is offline
Old 10-16-2012, 01:58 PM   #2636
LeavingNormal
FRS2DTH
LeavingNormal's Avatar
Drives: Hot Lava 2013 Scion FRS
yep if you got your tune file within the past day or so you should be good to go now. Enjoy!
LeavingNormal is offline
Old 10-16-2012, 02:04 PM   #2637
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Originally Posted by JPxM0Dz View Post
I'm gonna keep harassing you post a video flash how to
Warning, I have a voice for print media. This is also just a quickly put together video.
[ame="http://www.youtube.com/watch?v=OcNC8zao8m8&feature=youtube"]ecutek - YouTube[/ame]
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline
The Following 8 Users Say Thank You to Hawaiian For This Useful Post:
BAE (10-21-2012), Jayp (10-22-2012), JPxM0Dz (10-16-2012), LeavingNormal (10-16-2012), Sambosis (10-17-2012), serial gixxer (10-16-2012), Subynewbie (10-16-2012), zkubidu (10-21-2012)
Old 10-16-2012, 02:04 PM   #2638
Opposed
Drives: 2013 Asphalt FR-S
You don't have to update the software every day. Just once. You will only have to update it again when they have made changes. It usually prompts you every 30 days to check for updates.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline
Old 10-16-2012, 02:19 PM   #2639
cnk
Drives: '13 DGM BRZ Limited
Nice vid. You're using an Asus X401a laptop aren't you? I bought the same one just to use on the car. LOL. I upgraded to 8GB RAM and an SSD though which made a big difference in performance.
cnk is offline
Old 10-16-2012, 02:21 PM   #2640
xjohnx
Grip>Slip
xjohnx's Avatar
John has recommended that you check every time you're about to flash the car.
xjohnx is offline
Old 10-16-2012, 02:22 PM   #2641
Visconti
Drives: 05 STi
Another busy day - Thanks for filling out this new form.
This form really makes it easier to track orders and issues.
Visconti Tuning Request Form
I have a few hours of work to do before I can get cracking at this form.
But quickly looking I see lots of small issues that I can resolved right of way.
Thanks
John
Visconti is offline
Old 10-16-2012, 02:24 PM   #2642
Hawaiian
That guy
Hawaiian's Avatar
Thanks.
Yeah. It was cheap, It's a little slow, but I don't need the performance for it.
Ultramarine mt FR-S
P&L stage 1 turbo
Hawaiian is offline
Old 10-16-2012, 02:28 PM   #2643
cnk
Thanks.
It's definitely a little slow, but if you keep an eye out you can pick up memory and a nice SSD for around $200 and it speeds things up nicely. I picked up a Samsung 830 256GB SSD and 8MB Kingston memory for that price. There's a youtube video on how to do the upgrade if you choose to go that route. A side benefit of the SSD is no moving parts so if you're data logging and hit some bumps in the road, you don't risk having the HD needle bounce around and damaged the disc.
cnk is offline
Old 10-16-2012, 02:34 PM   #2644
Jidonsu
Drives: Scion FR-S | 6MT | Ultramarine
The only real issue is that the stock fuel gauge would read zero out of the blue. I filled out the form. Tune seems pretty good so far. Thanks!
Jidonsu is offline
Old 10-16-2012, 02:47 PM   #2645
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by Calum View Post
Ok, I did some playing and here's my findings.
Flat Foot shit work if you have the gas matted. Lift even the tiniest bit and you bounce off the rev limiter.
Map switching works. Pull lever back toward driver, wait until tach points to number corresponding to map I'm presently running. Push lever up or down to change maps, and pull lever toward me again to set the map.
Auto blip is not rev matching, as I understand it. I've had the car blip once and I wasn't paying full attention to where my feet were so I don't yet know what I'm doing wrong. I've tried many times to do what I've seen in the video. Feelin' a little stupid about this one.
Launch control doesn't seem to work. I've tried in all four maps and every time I just bounce off the rev limiter. I'm wondering if there's more to this, such as some way to turn it on within the map. But that doesn't seem to fit with everything else.
A/F and tank % are working, just not correctly. My cluster reads in liters/100 kilometers. If I do the conversions from L/100km's to mpg(US)the numbers work properly. As it is, I just filled up and I'm showing 2.4 which would equal 98% fuel in the tank. Under WOT I'm showing 18.4-18.8 which is 12.7-12.5 air fuel ratio.
@Visconti, if you or if ECUTEK needs a Canadain cluster, to test conversion software, shoot me a PM.
Update
I was playing with the auto blip on the way home, it's working fine. The problem was my driving habits. I always disengage the clutch before I press the brakes.
To get auto blip to work while driving let go of the gas, press the brake and then push in the clutch. I don't know yet if it's rev matching or just giving a blip but I have noticed the revs going to different rpms at the end of the blip.
I didn't have time to try anything else with the launch control.
Calum is offline
The Following User Says Thank You to Calum For This Useful Post:
Old 10-16-2012, 02:52 PM   #2646
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
Hey guys the dongle id is on the little key and it also shows the same number on proecu correct?
Lee358 is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 03:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) -- General Topics 0 05-24-2012 11:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 08:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) -- General Topics 130 09-01-2011 02:42 PM
