#15 | |
Drives: 2018 BRZ tS black and 2007 impreza
#16 | |
Drives: 2017 Toyota 86
Every once in a while! Only way to make it pop all the time is with a tune I believe. Black tips will definitely fit your car. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to HachiRokuX For This Useful Post: | zac8 (02-14-2019) |
#17 | |
Dismember
Drives: 2013 Red Scion FR-S
#18 |
Cannonball Record Guy
Drives: Series.Yellow, 4C, Fit
Love my Corsa! Especially the black tips.
![]() It does pop from time to time on the overrun. I wouldn't do a header since it makes the exhaust brutally loud, adds rasp, and defeats the no-drone RSC technology. [ame]https://www.youtube.com/watch?v=sl_kiPX58GU[/ame]
| The Following User Says Thank You to dhuang For This Useful Post: | zac8 (02-15-2019) |
#19 | |
#20 | |
Panda Trueno
Drives: No twin now.
You need to do research, man. In to your states emissions, in to what people are saying. In your specific case with your concerns a supercharger kit sounds like a MUCH better option for what you're trying to do. Maintain all factory emissions and 02 placement, make reliable power, have a decent powerband. It all adds up. Look at @CounterSpace Garage and their greddy equipped car. Just another example. Tap in to the resources around you and take off the blinders, lol. If it's what you really want and it meets your needs, great!! It just sounds like you're rushing in to a decision without due diligence. |
#21 |
Drives: 15 BRZ LTD, 05 FXT
Tuning is far more important than low numbers for a turbo kit. The WORKS kit is a big compromise to retain CARB certified capable packaging. Do you want a turbo kit that is a compromise right out of the gate?
JDL meets your needs better. WORKS is for people who need to retain the factory header for classing restrictions, or need CARB compliance. https://jdlautodesign.net/shop/ft86-...urbo-kit-v2-1/
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
#22 | |
#23 |
Drives: 2018 BRZ tS
I just did a JRSC C30 Kit on my tS. I have flex fuel as well, but flex fuel is totally unnecessary for what you are looking for. I couldn’t be happier with the outcome. Plenty of streetable and trackable power. The car revs high, and wants to be revved high, so sure, there is more power there, but it still has plenty of grunt down low.
The JRSC is proven reliable, simple, light, and won’t interfere with your emissions at all! I understand your brother has installed turbo kits, but this will be a simpler install that the Works Turbo Kit, so he shouldn’t have an trouble with it. With that said, and I’m biased towards PTuning because they do all my work and are down the road from me, but their turbo kit is easier the best out there. There’s a used 1 on sale on the forums right now, for about $3800. Granted it’ll make more power, but it’s definitely the most comprehensive set up turbo-wise. I ran through all of this to find the best kit for my tS and settled on the JRSC, and powder coated the piping red to match. I highly recommend! |
| The Following User Says Thank You to J1Avs For This Useful Post: | zac8 (02-15-2019) |
#24 | |
#25 | |
Drives: 2018 BRZ tS
Sounds awesome, you definitely get a lot of intake noise, even at idle, and a pretty cool sound out of the rotrek as it revs out. I also chose to upgrade the BPV with a Forge BPV (the stock one works, but has had a history of failing - not a huge deal and the Forge was pretty cheap), so it has a cool "whoosh" sound when coming off the throttle similar to the BOV. With the JR kit w/o e85 or the high boost pulley, you'll be fine on the stock injectors, fuel pump, and clutch as well. Others have mentioned the Edelbrock Kit, and I was very close to that kit as well, but the warranty wouldn't have applied to me since I already did a full exhaust and couldn't run their tune. The one big perk of the Edelbrock Kit is that it comes with a 3 year/36K mile powertrain warranty ONLY IF you use their stock CARB tune that also requires you to maintain the stock header/front pipe/and cats. Downside, I heard the stock tune doesn't run so great - so there is that, and its most expensive. Just wanted to put it all out on the table for you! Glad to see another Black tS getting boosted!! |
#26 | |
Drives: 17 Asphalt 86
If you really like the corsa sound, I'd suggest a SC kit to retain the factory exhaust. I would be interested to hear a corsa on a turbo car, as it would most definitely sound different. Corsa doesn't use conventional methods when tuning sound in the exhaust, as such it relies on the factory header/front pipe to cancel drone, and keep noise levels in check.
It pops all of the time on overrun In -20c temps. I have the back seats down most of the time just to hear it burble and pop. ![]() As far as headers go, the only one I've heard that works is the FT86SF catted UEL, without ruining all of corsa's R&D. It has more equal length runners compared to most UEL's on the market, and the cat keeps the noise levels in check. |
| The Following User Says Thank You to RToyo86 For This Useful Post: | zac8 (02-15-2019) |
#27 |
pessimistic skeptic
If it is turbo that you want for sure, Greddy T518Z kit is the one I would choose for the power level you mentioned. Otherwise, JRSC was my choice. And I would choose it again after two years and more than 20K miles.
For the turbo though, I would budget header wrap or ceramic coating plus oil cooler. And the tune, yes the tune, the best tune. Don't even think saving money on tune. The beauty of JRSC is that it is a total package including a very good tune from the factory. Just install and drive. I would wait for the catback. I recommend making sure the FI is done and working reliably first. Then you can check the sound and decide on the catback later. |
#28 | |
| The WORKS 2017+ Stage 2 Turbo Kit is here! | WORKS | Forced Induction | 11 | 02-09-2019 05:27 PM |
| Subaru BRZ 2013 WORKS Stage 2 Turbo | hough927 | Cars for Sale/Trade | 0 | 04-21-2018 03:06 AM |
| Experience with Works Stage 1 Turbo Kit | aaguirre123 | Forced Induction | 33 | 09-18-2015 09:16 PM |
| My Experience with Works Stage 1 Turbo Kit | aaguirre123 | Member's Car Journals | 9 | 06-09-2015 08:47 PM |
| WORKS Stage 1 Turbo Kit Pre-Release Offer | WORKS | Northern California | 31 | 11-11-2014 08:24 PM |
