#323 |
Drives: LR BRZ Ltd, 06 STi
Let the car sit for awhile then check again, you want the oil in the pan not the engine when measuring. If it still reads low I would add more oil.
| The Following User Says Thank You to R L Newb For This Useful Post: | bizintine (05-28-2015) |
#324 |
Drives: 2013 whiteout frs
Thanks RL. I let the car sit overnight and the dipstick reads slightly above the bottom hole.
#325 |
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Make sure it's level too. That can make it weird.
#326 |
My analysis for the last set of dealer oil:
#329 |
Drives: BRZ Limited
Yes, the Mazda 0W-20 GF-5 with moly can be purchased from the dealership for around $7.00 per quart. Adding the M1 0W-40 makes a slightly heavier 0W-20 and increases the HTHS for greater high temperature protection while maintaining a high VI. Search "Caterham blend BITOG" for more information.
| The Following User Says Thank You to fstlane For This Useful Post: | sato (06-21-2015) |
#330 |
Sleep Chomper
1st uoa from blackstone. Was using Amsoil and I am running a turbo
| The Following User Says Thank You to rixter145 For This Useful Post: | R L Newb (08-13-2015) |
#331 | |
I definitely wouldn't extend the interval, and would possibly cut back on it, until you've absolutely confirmed that the wear metals are still from the break-in process. Yes TBN is great showing the oil can be run longer, but what good is a high TBN if you have high wear? |
#332 | |
Sleep Chomper
Thanks for the insight Last edited by rixter145; 06-28-2015 at 04:30 PM. Reason: Got the oil brand and model |
#333 |
Sometimes break-in wear metals linger around for 10-18k miles, depending on driving style and probably other factors (number of oil changes, how long you ran the factory fill, etc.). If everything drops on the next oil change it is likely just break-in metals.
| The Following User Says Thank You to bluesubie For This Useful Post: | rixter145 (06-29-2015) |
#334 |
Drives: 2014 Argento FR-S
Well, I am one of those FRS owners that decided to wait until the first oil change interval and to take advantage of the dealer Toyota "free maintenance" offer.
Gotta say, the dealer seemed to have done a good, clean job. From the factory, the oil level was a scosh higher than the top mark, it didn't move any lower in 6500 miles, and the refill is exactly at the same level. The old oil still appeared to be very clean prior to refill, and the new oil is almost impossible to read on the stick. For me, I am happy to stick with TGMO synth. Have to admit, it feels great to have fresh oil in there. 13,000 miles/7.5 months is the next interval. |
#335 |
Drives: GBS BRZ
4th oil change, Toyota 0w-20 and OEM filter
#336 |
Drives: MDX, Camry
Has anybody seen Blackstone produced any negative report for BRZ? If I have to use one sentence to summarize the results, my choice would be:
Any 0w20 works just fine! LOL |
| DIY BRZ / FR-S Oil Change | RallySport Direct | DIY (Do-It-Yourself) Guides | 169 | 09-01-2018 03:42 AM |
| First Oil Change | Jehuty77 | CANADA | 14 | 08-10-2012 12:54 AM |
| When to do your first oil change, and why... | MrBodyMassage | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 07-17-2012 08:43 PM |
| Do you change your own oil? If so, why? | SteelReign | Other Vehicles & General Automotive Discussions | 77 | 04-16-2012 11:12 AM |
