Old 01-29-2019, 02:32 AM   #1
Drake_93
Drives: 10-Series Turbo FR-S #2483
Fury, 10-series revival DD | AutoX
I'm Drake, I study Digital Science at Kent State, and I drive a boosted 10-series FRS.
Suppose now is a good time as ever to start the build journal.
This is Fury, my daily-driven, boosted, 10-series, FR-S.
I bought her January 7th '18, with 56,000mi. and a lot of mods already done:
SBD 400x Turbo (7.5lbs)
Perrin 3" non resonated Catback
FBM Oil cooler
Radium Auto Dual Catch-Can
ACT 6 Puck
20/25mm Spacers
Swift R Spec Lowering Springs
I was looking for an 86 over winter break last year and this one happened to be 3 hours away, my only leads on the car?
It was previously registered in Maryland, repod, and the kit was probably installed at Moto-East, from an old blog post about an SBD install on a 10-series.
I landed a job for the coming semester and decided to pull the trigger. Drove down to look at the car, inspecting everything with a fine lens to spot any failures, and mistakes.
After test driving and inspecting the car for almost an hour, I decided to sign the papers on the possibly the biggest used car gamble ever.
Not to be too cliche but the rest is pretty much history, over the past year I've put nearly 20k on the pavement and only really done standard maintenance.
Now I'm looking to start pushing the envelope and making Fury, more my car, not just something I found.
Incoming mods include:
Varis Arising II front bumper (needs paint)
Nur spec Wing (pending trunk swap)
Knowledgeable Tune (searching for Ecutek hardware)
Enkei Compe 16x8 Wheels (saving)
Firehawk Indy 500 225/50
DRIVER MOD
I am part of Kent State University Car Club (KSUCC), and spend a bit of my free time trying to AutoX.
Last season was my first ever with only 2 events, this year I'm trying to make it monthly.
I'm really excited to start documenting the build, and of course making this a little cleaner.
Pointers are welcome.
Instagram: @FRS_Drake
I do post more often over there, but I want to make a more official journal here.
Drake_93 is offline   Reply With Quote
The Following User Says Thank You to Drake_93 For This Useful Post:
Boomerang (02-07-2019)
Old 01-29-2019, 12:30 PM   #2
Lonewolf
Lonewolf's Avatar
Drives: Moped
Welcome! Looking forward to your future posts!
The Following User Says Thank You to Lonewolf For This Useful Post:
Drake_93 (02-10-2019)
Old 01-30-2019, 01:00 AM   #3
andrew4554
Drives: 2015 Scion FRS
what size were those tires on your stock wheel? 225?
andrew4554 is offline   Reply With Quote
Old 01-30-2019, 01:09 AM   #4
Drake_93
Those were 215/45 Cooper RS3-As which I can't tell enough people to stay away from. (Unless you want an all season that sucks in every category but longevity)
andrew4554 (02-06-2019)
Old 02-07-2019, 02:33 AM   #5
Drake_93
Late Night Update
So, the trunk swap fell through. But, the polar vortex cancelled our classes,
and I'm fortunate enough to know someone with a heated-ish garage.
(when the windchill is -40, is anything really heated?)
So we spent the whole day working on our cars and doing oil changes
As it would turn out, the TRD deck spoiler was secured with rather overkill methods.
6 bolts, and about a meter of 3M adhesive tape.
Removing the bolts was relatively easy, the tape was an enormous PITA that took nearly 3 hours.
We went through methods, rags, razors and eventually settled using brake cleaner.
I didn't really take a lot of photos of the process as it was really grueling, annoying, and still cold.
But, we got through it.
Fortunately enough, this Nur Spec wing actually bolts up to the two outer holes from the TRD spoiler.
We did a little test fit and ran with it.
Originally we were just going for it, trying to see where we'd end up with the spoiler off of Fury.
I was totally planning on just covering the holes and then redrilling the trunk at a later date.
Well, the bolts lined up so we went for it.
I ran out to grab some 3M tape and we moved the car around to set the trunk and wing in front of the heater.
After prepping the surfaces and waiting for everything to heat up,
we ran a few pieces of tape on the deck plate of the wing and mounted it up.
As for the holes, they're currently covered with some electrical tape....
I'm scheduling the front bumper work soon and I'll have the trunk welded and painted as well.
And of course, she's naturally already dirty as all hell in this lovely climate.
Old 02-07-2019, 06:48 AM   #6
ermax
ermax's Avatar
That looks really nice. Is that the stock ride height for the 10 Series? If so I am guessing the 10 Series comes with the TRD springs? I see you list spacers but nothing about springs.
BTW, all but your very first image have broken links.
The Following User Says Thank You to ermax For This Useful Post:
Drake_93 (02-09-2019)
Old 02-07-2019, 06:52 PM   #7
Drake_93
Aw crap, thank you for saying something. I'll fix the links tonight. The springs are Swift R specs. 4.4k -1.1" in the front 5.3k -1" in the rear.
Old 02-09-2019, 12:38 AM   #8
Drake_93
Image links have been fixed
Old 02-09-2019, 06:30 AM   #9
ermax
ermax's Avatar
Hard to find good images of Pro-Kit/TRDish like drops on OEM rims with 20/25 spacers. It looks perfect. I think I’ve made my decision to go with Pro-Kits and 20/25 which would be compatible with SCCA SSC if I ever pursued that.
Old 02-10-2019, 02:11 AM   #10
Drake_93
Nice!, I highly recommend the SCCA spec coupe setup, there's a guy in my autoX club that just recently switched from a 370z to an SSC frs and he just throws it everywhere.
The guy is amazing and the setup / availability of the build just makes the platform shine.
I can't praise these things enough in that aspect. I'll be in SM, but I've seen some SSC cars put down seriously ridiculous times.
Kung Fury chaoskaze Off-Topic Lounge [WARNING: NO POLITICS] 0 05-29-2015 04:45 PM
BRZ seen in 'Road Fury' ???! Breeeep Off-Topic Lounge [WARNING: NO POLITICS] 16 05-18-2015 03:42 PM
Possible 2015-16 RX-7 Revival Wise Other Vehicles & General Automotive Discussions 12 11-01-2012 11:29 AM
