Old 01-22-2019, 07:56 AM   #1
atomicalex
Drives: 2018 BRZ Limited Perf Pack
Expectations from factory block heater?
What is realistic to expect in terms of coolant temps?
I plugged mine in yesterday for about 3 hours at 15°F outside, and there was not a really noticeable decrease in the warmup time (about five minutes driving).
www.atomicalex.com
2018 BRZ Limited Perf Pack 6MT, a couple of motorcycles, and a stick shift station wagon
atomicalex is offline   Reply With Quote
Old 01-22-2019, 08:15 AM   #2
Any blocker heater only warms the oil itself up enough to keep it a bit thinner than when really cold. None will have any noticeable effect on overall engine warming time.
atomicalex (01-23-2019)
Old 01-22-2019, 09:49 AM   #3
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
If it's an actual "block" heater, aren't those installed by removing a welch plug from the engine block and inserting the heating element into the water jacket? It likely doesn't warm the oil as much as the slight thermal expansion loosens up the piston bores a little to allow for easier cranking. When we were having to use block heaters, we didn't care about how long it took to warm up, we were just thankful it started at all! I don't recall that the engine warmed up much faster. They were all cast iron with very little aluminum. Not quite the same as our boxers.
LimitedSlip is offline   Reply With Quote
The Following User Says Thank You to LimitedSlip For This Useful Post:
Old 01-22-2019, 10:33 AM   #4
gravitylover
If it's the same as the one Subaru puts in the FB motors it should make quite a difference in warm up time. I had one installed in my Crosstrek at the dealer before I picked it up and that thing was fantastic. I'd plug it in at night when I got home from work and the car was warm and it would keep the water circulating all night. You could hear it and feel it moving through the upper rad hose. Even if it was below 0(F) I could get in the car in the morning and it was ready to go and the heat would come up immediately, the blue light on the dashboard wouldn't even come on.
The Following 2 Users Say Thank You to gravitylover For This Useful Post:
atomicalex (01-23-2019), JoeC (01-23-2019)
Old 01-22-2019, 10:44 AM   #5
maslin
Benz Tech
Drives: 2017 BRZ Premium
The ones that circulate the coolant do a pretty good job. The heaters that are just an element help, but not enough to start your car and have heat.
The Subaru heater for the BRZ is just an element, A091SCA001. The description says "Warms engine coolant to promote easier starting in extreme cold conditions". I wouldn't expect much more than that from it.
maslin is offline   Reply With Quote
The Following 2 Users Say Thank You to maslin For This Useful Post:
atomicalex (01-23-2019), lamawithonel (02-01-2019)
Old 01-22-2019, 11:10 AM   #6
Yes. I gave a horrible description by trying to keep it too short.
Old 01-22-2019, 11:34 AM   #7
Sasquachulator
Pavement Grey
Yeah I thought all the block heater does is just make the car easier to start.
The Following User Says Thank You to Sasquachulator For This Useful Post:
Old 01-22-2019, 12:31 PM   #8
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
They're definitely worth it once the temperature dips below -15c.
On my old SX4 with the battery in the condition that it was, it would be the difference between the car starting normally in two cranks, versus the world's slowest crank and the battery dying out.
It's been below -20 the last few days in Ottawa and I definitely wish I had a block heater for days the car isn't I'm the garage.
The Following User Says Thank You to RToyo86 For This Useful Post:
Old 01-23-2019, 09:17 AM   #9
atomicalex
Thank you all. It's just the one that goes into the freeze plug holes. It definitely made for easy starting at ridiculous cold.
www.atomicalex.com
The Following 2 Users Say Thank You to atomicalex For This Useful Post:
RToyo86 (01-24-2019), Tcoat (01-23-2019)
Anyone installed a block heater? jonboy99 Scion FR-S / Toyota 86 GT86 General Forum 24 05-08-2016 10:01 PM
Is there an OEM block heater? KevinBRZ BRZ First-Gen (2012+) — General Topics 1 08-22-2013 01:18 PM
Engine block heater project d CANADA 17 03-11-2013 12:04 PM
Has anyone installed a block heater? empower-auto Scion FR-S / Toyota 86 GT86 General Forum 14 11-20-2012 04:21 PM
1st Oil Change & Block Heater JPxM0Dz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 11-09-2012 11:20 AM
