#15 |
Drives: UK GT86
The overwhelming response is negative but the only actual tuner (from Cosworth I might add) has said it will be fine. I'm with him by the way and I've also spent time tuning on this platform. The rest are correct that to make the most from the car you need a custom tune but the car will run fine and not be dangerous on a tune designed for the stock exhaust. If anything it should be more conservative.
.: Stealth 86 :.
#16 | |
Drives: 2013 Scion FRS
#17 |
Drives: '14 SSM BRZ Premium
If you still have the stock exhaust, you could always re-install that until you're ready to tune it. That gives you a little safer route as well.
"To be without silver is better than to be without honour." - Norse Proverb
#18 |
Drives: 2013 BRZ Limited 6MT
I ran this exact set up for about a month before I put my car away for the winter. It does indeed run really rough, throttle is not smooth, and idle is all over the place. I will be getting a delicious tune as soon as I take it out in the spring.
#19 | |
Drives: UK GT86
It's amazing how many people think a tune changes massively on a setup like this for different exhaust setups..... The ECU has ways of maintaining fuelling and controlling knock, things would have to be pretty different for it to not be able handle the changes.
.: Stealth 86 :.
#20 |
I believe the only effect it will have is timing won't be optimized and fuel trims will be adjusted up. I think the ECU supports up to 15% fuel trim adjustment either way if I remember right? Anyone remember? Barely more dangerous than throwing a header on the stock car without tuning, which is no big deal.
#21 | |
| Help! Tank full of E85 2017 Stock BRZ what OFT tune to use? | D4FD | Software Tuning | 41 | 10-30-2017 05:06 PM |
| Edelbrock Supercharger w/ Tune *1 left in stock* $5399.99 Shipped! | Kami Speed | Forced Induction | 3 | 03-13-2017 04:11 PM |
| Can I run a full exhaust without a tune | Scion1738 | Engine, Exhaust, Transmission | 5 | 11-23-2015 11:03 AM |
| Full Stock Exhaust - Anyone content with full stock & NEVER planning for aftermarket? | fooddude | Engine, Exhaust, Transmission | 39 | 12-15-2013 03:05 PM |
| T1R Full Exhaust re-dyno x DRIFT OFFICE TUNE !!!! | AJ PwR | Engine, Exhaust, Transmission | 19 | 04-25-2013 06:10 PM |
