#85 | |
#86 | |
On the Subaru engines with belts, the tensioners often fail before the belts, it would not be a bad idea to discuss having those and the guides/wear surfaces replaced. |
#87 |
Depends. Do you want to be the guinea pig for how long these chains last? So far it has been a non issue but as we climb in miles it may appear. I personally wouldn't at this point but I am also the guy that waited too long to change my TOB and destroyed my clutch.
| The Following User Says Thank You to Tcoat For This Useful Post: | finch1750 (02-04-2019) |
#88 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
#89 |
Drives: FRS
My dealer is pulling the most annoying stuff right now. I dropped it off last monday and its the next week's tuesday. I called them last thursday and they said they broke something and have to get a new part. Call today, figured out it was a "holder
engine mount im guessing and they said its still not here. Isnt the dealer supposed to overnight this stuff? |
#90 |
No spec in service manual. All it references is "deformation" with no actual measurements supplied.
| The Following User Says Thank You to Tcoat For This Useful Post: | finch1750 (02-05-2019) |
#91 |
It'd be nice of them, but no. They should definitely be covering a rental if they aren't already though.
| The Following User Says Thank You to finch1750 For This Useful Post: | vladniko86 (02-05-2019) |
#92 |
Drives: FRS
#93 |
Drives: 2016 FR-S RS2.0
Dealers can't shit parts, and they cant make the supplier shit parts.
Shortages happen. As long as they are covering your rental, enjoy racking miles on someone else's vehicle. I damaged a cam sensor on one, 275 are on back order through toyota. Apparently I'm not the only one. I called a local Subaru dealer, they had 2 on the shelf. Toyota can only get a part when Subaru has them to give to them, know what I mean.. |
| The Following 2 Users Say Thank You to LunarStorm86 For This Useful Post: | Kwaziekeller (02-06-2019), Tcoat (02-05-2019) |
#94 | |
Drives: FRS
Ah gotcha makes sense. I wish they could've not broken it but that's life Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to vladniko86 For This Useful Post: | Tcoat (02-05-2019) |
#95 |
Yea man I definitely understand, we hate breaking things too,
But it does happen As long as you get taken care of, that's all anyone can ask for |
| The Following User Says Thank You to LunarStorm86 For This Useful Post: | vladniko86 (02-05-2019) |
#96 |
Drives: FRS
#97 |
Toyota for 7 years, I worked at and independent shop for about 5 years.
My bossman at the time passed away and it was just me and him, so I decided a shop with air conditioning was my kind of place Been here ever since |
#98 | |
Drives: FRS
Do you like the work you do? Sent from my iPhone using Tapatalk |
| 2013 Valve Spring recall - modified (FI) engine thread | shiumai | Forced Induction | 71 | 08-11-2020 07:21 PM |
| Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 10:32 PM |
| Valve spring recall | meadowz06 | Issues | Warranty | Recalls / TSB | 115 | 06-09-2019 12:38 AM |
| valve spring recall-engine oil leak | TYinhouse | Issues | Warranty | Recalls / TSB | 13 | 01-17-2019 12:09 PM |
| I have the valve spring recall information. | meadowz06 | Issues | Warranty | Recalls / TSB | 24 | 12-23-2018 09:44 PM |
