Old 03-09-2021, 01:04 PM   #169
AreteAuto
Racing Enthusiast
AreteAuto's Avatar
Drives: Bone stock 2019 BRZ manual
Always nice to hear someone knows that ride height is not directly correlated to body roll. Seems like quite a raise, though, a whole inch. Interested to hear the feedback.
“$20 per diddle? I can diddle myself for free and do a fine job”
AreteAuto is offline   Reply With Quote
Old 03-09-2021, 02:16 PM   #170
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
TCE Tarmac 2s recommend dropping only an inch from stock height for the same reason. With a roll center kit you can go more, but honestly I have found it not necessary and am planning to remove the RC kit completely. I had started mine about 2" lower than stock originally, but since switching to 1" I have found the compliance to be more agreeable. It's also nice not scraping as much, and allows the rear sway bar to not lift the rear wheel as much in certain scenarios since you will get better droop travel.
I would love to also see data on removing the fiber cover behind the metal pan.
captain awesome is offline   Reply With Quote
Old 03-09-2021, 04:25 PM   #171
AreteAuto
Racing Enthusiast
AreteAuto's Avatar
I ran the Whiteline RC kit with Hotchkis springs many years ago, 1 inch drop. It was a wonderful combo. Still recommend keeping the RC kit with the RCE springs, because assuming it is similar to the kit I had, it corrects for approximately 1 inch drop anyway.
At the time, my thoughts were that with RaceSeng camber plates (for both camber and max caster), the handling would be impeccable.
... then someone ran a redlight and I had to start over ��
Old 03-09-2021, 05:03 PM   #172
captain awesome
Wears Pants
It costs vital points to run corrective ball joints or offset bushings with my TT class, so I'd rather just deal with whatever minimal consequences at that height I'll have to deal with. They are recommended for anything under 20mm height drop from stock if I remember correctly which is pretty damn close to where I'm at. Unless there is some crazy data to justify keeping them I really need to kick them to the curb.
Old 03-10-2021, 01:30 AM   #173
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Dyno Day
I feel pretty good about things after the dyno time. I think the new front pipe and injector cleaning was worth it. Especially knowing that the new "skinny" restrictor would cost me 2hp.
I was at 194 prior to the runoffs w/ thick restrictor.
Today, my base line run was 191.4. We tweaked fuel pressure on the DIs, AVCS timing and oddly enough, pulled out a degree of timing and finally peaked at 197.8 whp.
Not bad for stock engine with a drop in filter, 3" exhaust, 100 octane and a 55mm restrictor plate. I'm very much looking forward to getting back on track.
SCCA T4 - FRS
The Following 4 Users Say Thank You to rice_classic For This Useful Post:
captain awesome (03-10-2021), DarkSunrise (03-10-2021), Rampage (03-13-2021), solidONE (03-23-2021)
Old 03-10-2021, 03:54 AM   #174
e21jason
Drives: GT86 TRD Cup
from the OZ/NZ gr86 regulations
Ride height can be adjusted provided a minimum front ride height of 140mm (the bottom of the front bolt on the brace that goes from the chassis to the front mount of the lower control arm)
and a minimum rear ride height of 295mm (from the bottom of the rear bolt that holds the sub frame)
Ride height measurement shall be taken with the vehicle in ‘Race Trim’ and may be measured at any time during qualifying sessions and/or races. For the purposes of ride height measurement the tyres shall be set to 30 psi and the measurement shall be taken on the official flat pad.
e21jason is offline   Reply With Quote
The Following User Says Thank You to e21jason For This Useful Post:
rice_classic (03-10-2021)
Old 03-10-2021, 02:24 PM   #175
rice_classic
Their ride height then, is rules constrained and not necessarily an identified optimum that was adopted en-masse. Nonetheless, it's great information and shows that their min height is basically 1/2" below factory which probably enough of an allowance for corner balancing.
140mm = ~5.5"
295mm = ~11.6"
I just check the right side and my rear is 10.65" and front is ~4.6" So I'm roughly 1.5" below stock ride height and roughly 1" lower than the Aussies.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post:
dsc_pat (03-14-2021)
Old 03-23-2021, 12:05 AM   #176
rice_classic
Miatas are gonna 'Miata'
The update on the changes:
They were a net positive from the perspective of feel, compliance and the ability to not get upset when using curbing. In terms of overall lap time I'm not sure since I was at a new track. The only thing I know is that I do need the rear to settle just a bit.
Unfortunately, my weekend was cut short by Miata driver, who licked the stamp and sent it when he shouldn't have, and now I have to visit a frame shop and rebuild the front end and probably a couple suspension components.
It's going to be tough but I'm hoping to have the car race ready in 6 weeks but I may need some help from y'all in find parts quickly so I can start slapping this back together.
SCCA T4 - FRS
Dzmitry (03-23-2021), NoHaveMSG (03-23-2021), Pat (03-23-2021), strat61caster (03-23-2021)
Old 03-23-2021, 01:08 AM   #177
Turfer
Drives: Scion
Fuck...That sucks...Couldn't you have driven off the track to into the grass to avoid being rear ended by a clearly superior Miata that was behind you! :sarcasm:
Turfer is offline   Reply With Quote
Old 03-23-2021, 09:54 AM   #178
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Damn that sucks. I don’t think I have many spares that could be useful to you, but you are welcome to what I do have. Post up what you are looking for.
Old 03-23-2021, 01:38 PM   #179
rice_classic
Caution: swear words.
SCCA T4 - FRS
Old 03-23-2021, 01:43 PM   #180
rice_classic
I appreciate it man. The list I have so far is:
Front core / radiator support structure
Front crash bar / impact beam
Bumper skin
Headlight driver side
Corner light inserts (Both)
Fenders (both)
Fog inserts
Front plastic Undertray.
Radiator
Rear bumper skin
Brake duct hose
Maybe rear control arm or rear suspension
Maybe front control arm or tie rod
Driver side door
I'm calling the frame shop(s) now to see if I can get the left rear sheet metal tugged out and then I can get it close enough to align and be ready for new rear skin.
SCCA T4 - FRS
Old 03-23-2021, 02:02 PM   #181
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I may have tie rods and ends, I have stock rear LCA's though you are probably using the SPC's. I'll keep a look out for stuff in my area.
Old 03-25-2021, 12:23 AM   #182
jflogerzi
jflogerzi's Avatar
Dude that sucks man.
2013 Series 10 FRS #553
Search this Thread:
Advanced Search
SCCA T4 Race Car Build - Suspension ccdrift Tracking / Autocross / HPDE / Drifting 10 11-11-2018 01:50 PM
Daryl Harr's FR-S SCCA Race Car Build driver71 Member's Car Journals 39 05-28-2016 05:50 PM
VADERR's Tie Fighter (C Street SCCA Build) VADERR Member's Car Journals 49 02-10-2016 01:31 PM
My SCCA National budget RTR build SeanRTR Tracking / Autocross / HPDE / Drifting 69 09-05-2014 01:49 PM
Bad Panda Motorsports - SCCA Solo STX BRZ Build BadPanda Member's Car Journals 7 06-13-2013 02:08 AM
