#15 | |
Drives: 2015 Subaru BRZ Series.blue
That's what I told them. They should recoup at least half of the payment. I meant $4000 for a coil over (assuming that's all that bumped it up by 4k after replacing the coil over). They said they were gonna check if it was ruined, and after alignment said it was ruined and bought a new one. From there the quote went from 5k to 9k. I will call Geico once again and let them know the shop did such a bad job that I refuse to go back. Their work was a polished turd...I don't need another polish job, thanks. Thanks everyone. I will start with Geico again. Also, allegedly they replaced the LCA, and I don't see damage on it, but I wouldn't be surprised if it was the wrong LCA, or I suspected the sway bar was bent and not replaced, but not 100% certain there.
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks. |
| The Following User Says Thank You to Strife26 For This Useful Post: | Tcoat (01-15-2019) |
#16 |
Just an update. I still assume the sway bar is bent. I found that the rubbing I'm hearing is the tire rubbing on the back of the wheel lining. So it's not rubbing on metal on the inside. The passenger side doesn't rub anywhere still.
I'm going just get the white line front and rear sway bar combo and see if it helps since I want that upgrade anyhow. Sent from my ONEPLUS A6013 using Tapatalk
#17 |
I would quit trying to fix this thing on your own and force the insurance company to make it right. All you are doing is killing the value of your car by doing your own bandaids. Let a pro fix it.
| The Following 5 Users Say Thank You to ermax For This Useful Post: | soundman98 (02-25-2019), Summerwolf (02-25-2019), Tcoat (02-25-2019), vladniko86 (02-25-2019), wparsons (02-26-2019) |
#18 |
Benz Tech
Drives: 2017 BRZ Premium
Sway bars just loosely connect the left and right suspension to help corner flatter. They do nothing to the suspension geometry. If something is rubbing (other than the sway bar itself) it isn’t the sway bars fault.
I replace subframes all the time. They’re made to take a hit and dissipate energy. If anything in the suspension is bent you can almost guarantee the subframe is too. |
#19 | |
I'll call insurance again. See what they say. Sent from my ONEPLUS A6013 using Tapatalk
#20 |
Drives: Crapcan
If I were you I would be finding out what my rights are and going at the insurance company to have it corrected. Just some very brief searching shows they can not force you to use any specific shop and the insurance company must stand behind the repairs of the recommended shop if the repairs are not done properly. It is also very easy to file a complaint with the state. I have threatened that in the past and it tends to move things along in the right direction.
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#21 |
ProCrastinationConsultant
you need to be bringing all of your complaints to your insurance company. all insurance repairs are typically guaranteed for life, if you're not happy, you need to make it known. you needed to make it known the first week you picked it up.
when my eclipse was t-boned, because of the age of the car at the time of the incident, the insurance company insisted on using aftermarket parts. i brought it to a trusted family friends auto body shop, and he was adamant that the fitment was going to be poor. i brought up those concerns with the adjuster, he reassured me that the fitment was going to be just as good, and that the work would be guaranteed for life. so i went with it, they installed the aftermarket parts, and as expected, the shop did a great job, but nothing lined up the same because of the inferior parts. i then showed the adjuster the major issues with the lack of fitment, and they agreed to re-do the entire job with oem parts. the lesson here is firstly, you need to find a shop that YOU trust. the second lesson is that insurance companies will do whatever to just 'get it done'. if it's not up to your standard, don't back down, don't accept the work, and be a pain in the ass until it's done correctly. it's fair to bring it back to the same shop a few times to allow them to correct their mistakes. but after repeated attempts, it should also be fair of you to discuss with your insurance company about allowing you to take the car somewhere else to be properly repaired after the original shop fails to meet satisfaction. finally, there are no 'sports car repair shops'. body work is body work, whether it's a 20 year old f-150, a brand new cherokee, or a 4 year old subaru. there are entire binders for repair procedures for all of these vehicles, the difference in repairs is who's paying for them, the standards of the shop/people doing the work, and the level of acceptability of the vehicle owner.
| The Following 4 Users Say Thank You to soundman98 For This Useful Post: |
#22 | |
If the wheel is rubbing on the back of the fender liner, you have a serious geometry issue. Sway bars aren't going to do anything at all to fix this, you're just wasting time and money. I'll bet a lot that the subframe (or even the frame itself) is bent, that's the only way the wheel would be shifted backwards enough to rub like you're saying it is.
| The Following 2 Users Say Thank You to wparsons For This Useful Post: | ermax (02-26-2019), Icecreamtruk (02-26-2019) |
#23 | |
#24 |
JHerbert Racing
Drives: 2013 Scion FRS
My bet would be on a bent control arm. They bend easily in the event of an impact. A bent control arm could also potentially allow the wheel to hit where OP is saying if bent just right.
Ask me how I know... http://www.ft86club.com/forums/showp...&postcount=310
#25 | |
Drives: Track preped NA FRS
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | wparsons (02-26-2019) |
#26 | |
The sigh is for thinking new sway bars is going to fix anything. IMO, hold off on them until you actually have it fixed. If your wheel is that out of position it could end up bending your new sway bars if you install the front one before you have the rest fixed.
| The Following User Says Thank You to wparsons For This Useful Post: | Strife26 (02-26-2019) |
#27 | |
It was inspected and "fixed" by pros so idk, man. Thanks for the info again. Sent from my ONEPLUS A6013 using Tapatalk
#28 | |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | wparsons (02-26-2019), x808drifter (02-27-2019) |
| Got into a wreck with a e36 328i | SUB-FT86 | Scion FR-S / Toyota 86 GT86 General Forum | 40 | 06-27-2016 07:05 PM |
| Looking for a place to get repairs done | discretion | Mid-Atlantic | 1 | 11-28-2015 06:38 PM |
| My first wreck, ever. | Brndn704 | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 09-13-2013 10:44 AM |
| Another Wreck | SocalBurt | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 17 | 09-02-2012 01:19 PM |
| firestorm wreck | kendalldwhite | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 14 | 08-29-2012 12:39 PM |
