#43 |
12% Done with the car.
Drives: FRS
You guys are going to love my knob when i get it.usually i don't like giving away my ideas, but everyone on this forum helps out so i might as well too
#44 |
LXXXVI
Drives: Dahlia (Raven FR-S)
can these be added to the AT or only MT?
#45 |
#46 |
When In Doubt...
Drives: Slowww
I got my flossy knob today. I love it. The packaging is great, it's super heavy, and it's built well.
Only down side is that it doesn't align properly. Any non-tacky ways to fix this? Emailed the flossy shop in the mean time. ![]() ![]()
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
#47 |
Drives: car
maybe tacky, but it was quick and free - i put a little ball of paper towel in the knob. otherwise, you can use a lockout nut, but idk how it would work/fit with the reverse ring.
| The Following 2 Users Say Thank You to ducks For This Useful Post: | Laika (08-06-2012), TouchMyHonda (08-08-2012) |
#48 |
When In Doubt...
Drives: Slowww
Hey it's not tacky if I can't see it! I was thinking of a washer/spacer but that'd be tacky, Thank you for the idea this will probably end up being my solution.
#49 |
Drives: Firestorm FR-S (MT)
Get yourself a nut (M12x1.25) and some washers. I had to do this to align mine as well. The knob is sitting up higher, and you can see some white between the shifter and the knob, but that I can live with, having my knob not aligned properly was driving me crazy!
#50 | |
When In Doubt...
Drives: Slowww
Do you have any pictures Joe? I just took ducks' advice and it's sitting right but who knows for how long ![]() Did I mention I love this shift knob? And snoopyalien for designing it for me
#51 | |
Drives: '13 Premium MT BRZ
http://lathewerks.com/shop/popup_ima...ID=254&image=0 $150 justifiable? When you're 23 and have money to spend, why the hell not.
| The Following User Says Thank You to Tomzilla For This Useful Post: | 20valvewynn83 (08-21-2012) |
#52 |
Suby Specialist
Use Teflon tape to fix knob alignment. Can get it at any hardware store.
| The Following User Says Thank You to BugeyedWagon For This Useful Post: | Shagaliscious (08-06-2012) |
#53 |
Here is a close-up. No issues getting into reverse. It took a bit to find the right nut & washers, since it has to be big enough for the shifter, but small enough to fit inside the shift knob. I am going to see about that teflon tape though, sounds like a better looking solution.
| The Following User Says Thank You to Shagaliscious For This Useful Post: | Laika (08-06-2012) |
#54 |
Memphis
Drives: 1989 MR2 S/C, 2014 Scion FR-S
use some thread locker and then align it and leave it over night. It should be great in the morning. It work for me and there is no movement at all even thought it is not all the way screwed in.
"It's ok... It's not structural."- Mikey
#55 | |
WiKKiD Large Penis
Drives: 2001 Audi TT Quattro "BT 300+Whp"
That looks like shït! Flossy needs to make this right for you. |
#56 |
Drives: FRS
| << FT-86 SpeedFactory >> Shift Knobs | Cusco Cage | more soon... | FT-86 SpeedFactory | Interior Parts (Incl. Lighting) | 15 | 11-02-2012 06:25 PM |
| Kartboy shift knobs. The best! | Mach V Dan | Interior Parts (Incl. Lighting) | 5 | 10-01-2012 05:22 PM |
| Aftermarket shift knobs? | titusdrake | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 09-19-2012 11:59 PM |
| Perrin Performance Shift Knobs in Stock | IslandImportPerformance | Interior Parts (Incl. Lighting) | 4 | 08-01-2012 02:02 PM |
| Shift Knobs For your FR-S | TWMPerformance | Interior Parts (Incl. Lighting) | 19 | 06-03-2012 10:29 AM |
