Drives: Toyota GT86
Suspension position sensors
I am planning to install a set of four suspension position sensors on my GT86. My suspension is all stock. Any idea what length should I get and were are they best mounted ?
#2 | |
![]() Oh, sorry, I must ask - why do you want to do that, since the GT86 has a passive suspension? humfrz |
#3 | |
Because compromise ®
Drives: Red Herring
Do you mean non-adjustable suspension? To me active suspension means the damping is controlled from external source like Audi's Magnetic Ride and passive is what most cars use which is different from adjustable damping. [/pedant]
[insert cool phrase here]
Drives: BRZ Premium
What?
For shits and giggles could you post a picture of these "sensors" you want to install? Or a link to where you bought them?
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
OP is gonna have to be a lot more specific in what he's asking. I assume the OP is referring sensors that track the movement of suspension components under load. My question is, why does the OP need to be measuring his suspension in this way?
Whatever the reason, the cost can be...uh...exorbitant. |
| The Following User Says Thank You to BlueWhelan For This Useful Post: | humfrz (01-15-2019) |
#6 | |
Drives: Legacy GT
You can use them to do things like calculate downforce, measure body roll, tell you if you're bottoming out the suspension, if they sample fast enough they can help you make damper adjustments, etc. Could probably even derive things like cg and roll center heights. I'm not sure what you'd get from putting them on a car with stock suspension. It has some sort of a data aq system but stock struts and springs? I suppose it would give you a baseline before changing things. But if you're going to be adding these, you can't take the wheels off and stick a measuring tape on a few things to decide what to get and where to put them? Last edited by jamal; 01-14-2019 at 01:31 AM. |
| The Following 3 Users Say Thank You to jamal For This Useful Post: |
https://www.ft86club.com/forums/showthread.php?t=26661
Suspension Travel: Bump Travel = 2.5 in or 0.1 m Rebound Travel = 3.5 in or 0.15 m I'd get around 6" of travel on the sensors, find someone who can weld a tab on the upper spring perch and the lower spring perch, allow the sensor to rotate and such to account for the strut movement but it's pretty simple standalone and you're getting true shock motion out of it which can easily be extrapolated to wheel motion with some of the other parameters in that thread. Good luck. |
Drives: Toyota GT86
Thanks everyone for input. What I am after is something like jamal posted. they are on the market with various lengths and stokes. Just need to choose the correct size for front and rear. They are not cheep actually but I would like to be able to log how the suspension is behaving. It gives you an idea also when a wheel is lifting and loosing traction or just grip.
Jamal is that an FR-S suspension? I prefer if I can mount them without having to weld to the suspension arms. I am afraid that the welding will create a stress point from where the arm may fail. |
#9 | |
Drives: Toyota GT86
#10 |
Not sure, ultimately getting your car in the air taking the springs off and measuring for yourself is the absolute best solution as mentioned above, it's understandable to want to minimize downtime for your car but in this case taking the longer path to make sure you do it right will pay off when it comes to science experiments.
#11 |
Drives: 2014 Subaru BRZ Ltd.
GSpeed did this on their track car. Here's the post from their journal thread.
https://www.ft86club.com/forums/show...7&postcount=26
*question everything*learn something*answer nothing*
| The Following 4 Users Say Thank You to lamawithonel For This Useful Post: | kch (01-15-2019), Racecomp Engineering (01-15-2019), strat61caster (01-14-2019), wparsons (01-17-2019) |
#12 |
Drives: Toyota GT86
Thanks again for input. Now I have a clearer idea of way forward.
#13 |
You're referring to linear shock potentiometers. Depending on how accurate you need your data and how much resolution you need, you could also choose to run shorter shock pots and mount them slightly more inboard rather than trying to get a 1:1 measurement. This could open up some more mounting options. Also depending on what you want the data to be displayed, you'll just have to account for the installation to shock/wheel travel ratio.
Where are you getting your sensors from, and what setup are you using for datalogging? |
| The Following 2 Users Say Thank You to AFRichZC6 For This Useful Post: | Racecomp Engineering (01-15-2019), wparsons (01-17-2019) |
#14 |
Drives: Toyota GT86
AFRichZC6,
I have not decided yet which sensors to use. They are a bit expensive so better think twice. For data logging I have built my own. All other inputs come from CAN apart from an IMU and GPS for which I have a module incorporated on the PCB with external antenna. This will be the first analog inputs. |
| The Following 2 Users Say Thank You to Mikefarr For This Useful Post: | AFRichZC6 (01-16-2019), Racecomp Engineering (01-15-2019) |
| Tags |
| sensors, suspension |
| Recaro Pole position | timandytimandy | Interior Parts (Incl. Lighting) | 1 | 08-30-2017 12:40 PM |
| Recaro Pole Position | Gliderx | Tracking / Autocross / HPDE / Drifting | 1 | 04-06-2016 08:07 PM |
| What position do you sit in FR-S/BRZ??? | cry7670 | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 05-09-2015 01:08 PM |
| Throttle Position question | NoFear99 | Engine, Exhaust, Transmission | 8 | 06-07-2013 09:25 AM |
| Headrest position | Sigh-on-Rice | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-15-2012 02:28 PM |
