Old 02-10-2019, 06:49 AM   #57
Juzzotec
Juzzotec's Avatar
Drives: Toyota 86 GTS
How many of these do you need to order?
Juzzotec is offline   Reply With Quote
Old 02-10-2019, 08:43 AM   #58
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I ordered two like the instructions in the bulletin. You need to place one on each side over here:
The Following User Says Thank You to nikitopo For This Useful Post:
Juzzotec (02-10-2019)
Old 02-13-2019, 03:16 PM   #59
JIM THEO
Drives: BRZ 2018
Anyone that did the modification could post some photos, how many plates he used, if the gap closes, procedure, how it is glued to the claw etc?
So many suffer from this issue but no one did the mod, strange...
JIM THEO is offline   Reply With Quote
Old 02-13-2019, 03:29 PM   #60
Lots have done it.
http://www.ft86club.com/forums/showthread.php?t=108535
Old 02-13-2019, 05:37 PM   #61
JIM THEO
Drives: BRZ 2018
I saw this thread but I meant fix with the new original Subaru part that should - supposedly - fits perfect.
Old 02-13-2019, 06:18 PM   #62
Pretty much the same part. Wouldn't be surprised if Subaru just ordered them from them. Classic case of the aftermarket creating the fix before the OEM.
Old 03-19-2019, 08:25 PM   #63
Enkrow
Enkrow's Avatar
Is there a Toyota US parts number for this yet?
Enkrow is offline   Reply With Quote
Old 04-14-2019, 06:01 PM   #64
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Free bump on this awesome thread 🧵
Old 05-12-2019, 04:29 AM   #65
Pineapple
Drives: Pegasus White GTS 86 w/ Aero Kit
The instructions say to just use a neutral detergent to keep the clip in place while you reinstall the bumper.
Is there any reason why I shouldn't use loctite/plastic glue to stick it in place?
Pineapple is offline   Reply With Quote
Old 05-16-2019, 09:04 PM   #66
Bones36
Bones36's Avatar
Drives: 13 Brz Jrsc
i had the same question
Bones36 is offline   Reply With Quote
Old 05-24-2019, 10:44 AM   #67
Chuckls
Moutain Runner
This won't work if the clips are destroyed, right? The area where they apply the detergent is gone.
Might just go quicklatch.
Chuckls is offline   Reply With Quote
Old 05-24-2019, 01:32 PM   #68
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Bumper countermeasure SB18-200E - SUBARU RECOGNIZES
I don't see the harm in gluing them in place with a forgiving adhesive, maybe 5min epoxy or E6000.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Tcoat (05-24-2019)
Old 05-24-2019, 01:45 PM   #69
Yep. Even Superglue. It literally is just to hold everything in one spot until clipped together.
Old 06-05-2019, 09:50 AM   #70
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
I ordered these clips last week and put them on last night. Here are some photos of the install. I didn't take the whole bumper off, I just undid the side marker and fender liner to pull the bumper away to get the clips on. I used superglue to stick the clip on the underside of the bumper. Mine was definitely not as bad as others I've seen, but wanted to do it before mine got worse.
PM me or quote this post (please delete image links in quote to save space) if anyone has any questions.
BigTuna is offline   Reply With Quote
The Following User Says Thank You to BigTuna For This Useful Post:
Clutch Dog (06-05-2019)
57722ca060 plate bmpr sd, brz, subaru, zc6
DIY - Color Code of ID plate and code of part (SUBARU) - SB18-091 Trap63 DIY (Do-It-Yourself) Guides 0 06-14-2018 05:52 AM
SB17-067 Leakage countermeasure for VALVE ASSY OIL CTRL 2013-2017 Trap63 Issues | Warranty | Recalls / TSB 10 06-04-2018 12:33 AM
SB18-077 *BRZ ALL, Flywheel assy and ball bearing Trap63 Issues | Warranty | Recalls / TSB 0 05-29-2018 04:26 AM
Someone recognizes this rear spoiler? pepe Cosmetic Modification (Interior/Exterior/Lighting) 13 08-12-2016 06:57 AM
USB flash drive for mp3's, only recognizes 61 songs per folder? Suparu Electronics | Audio | NAV | Infotainment 6 08-22-2015 03:15 PM
