Old 02-08-2019, 12:24 PM   #43
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Did you give them the part number?
Or search it at Japan parts?
https://www.japanparts.com/parts/detail/55056
jantheo-zc6-001 mentioned in the link is me
The Following User Says Thank You to nikitopo For This Useful Post:
Tcoat (02-08-2019)
Old 02-08-2019, 04:11 PM   #44
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
I did a search with the part number and came up empty so I sent them an email via their website and am waiting for them to reply.
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 02-08-2019, 04:13 PM   #45
FLYFISHR
FLYFISHR's Avatar
I check out the link and the parts in the picture don稚 look the same as the ones in the original post.
Old 02-08-2019, 04:55 PM   #46
I searched the number and immediately came up with the parts. They are the same ones. It is the right part. Simple as that.
FLYFISHR (02-08-2019)
Old 02-08-2019, 05:55 PM   #47
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
As Tcoat mentioned. You need to find the same part number.
Old 02-08-2019, 11:21 PM   #48
FLYFISHR
FLYFISHR's Avatar
I was looking on the jp-carparts.com website which was the name on the OP痴 invoice in the first post. I will take a closer look at the other site and go from there. Thanks
Old 02-08-2019, 11:27 PM   #49
FLYFISHR
FLYFISHR's Avatar
This what I come up with when I search Japan parts.com
https://www.japanparts.com/images/im...b.php?no=54935
Old 02-09-2019, 12:02 AM   #50
I will try this one more time. Not sure what you are searching since the part number is the same even at Japan parts
https://imagizer.imageshack.com/v2/xq90/922/UOBurd.jpg
Subaru part number 57722CA030
It is the part number and picture from the service bulletin on the first post.
It is the part number from the label from Subaru
It is the part number on the Japan Parts site.
It is the ONLY part number you need.
Call Subaru and order that part number or place an order with Japan parts using that part number.
This took me 30 second of research.
FLYFISHR (02-09-2019), slizoth (03-22-2019)
Old 02-09-2019, 12:15 AM   #51
FLYFISHR
FLYFISHR's Avatar
Thanks Tcoat
I’m not sure where I’m going wrong but that is the number I’m putting in the search window and not getting the results I want. I will find a work around some how. Thanks again for the help.
Old 02-09-2019, 01:36 AM   #52
Thanks Tcoat
I知 not sure where I知 going wrong but that is the number I知 putting in the search window and not getting the results I want. I will find a work around some how. Thanks again for the help.
What results are you trying to get? What am I missing?
Old 02-09-2019, 01:40 AM   #53
FLYFISHR
FLYFISHR's Avatar
I’m beginning to think the problem is that I’m trying to do my searches on an old iPad instead of my old PC I keep getting item not found
Old 02-09-2019, 02:08 AM   #54
I知 beginning to think the problem is that I知 trying to do my searches on an old iPad instead of my old PC I keep getting item not found
Item not found where? In general?
The Japan parts link I gave you is the part.
Old 02-09-2019, 02:49 AM   #55
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
When it says about bumper being reusable... if for whatever reason it is not, my take is we’re responsible for it and must purchase another out of our pocket?
I push and pull mine (2014) every 2-3 months so that gap closes.
Packofcrows is offline   Reply With Quote
The Following User Says Thank You to Packofcrows For This Useful Post:
Old 02-09-2019, 04:41 PM   #56
FLYFISHR
FLYFISHR's Avatar
I was able to get the right link on my desktop and placed an order. Thanks Tcoat
57722ca060 plate bmpr sd, brz, subaru, zc6
DIY - Color Code of ID plate and code of part (SUBARU) - SB18-091 Trap63 DIY (Do-It-Yourself) Guides 0 06-14-2018 05:52 AM
SB17-067 Leakage countermeasure for VALVE ASSY OIL CTRL 2013-2017 Trap63 Issues | Warranty | Recalls / TSB 10 06-04-2018 12:33 AM
SB18-077 *BRZ ALL, Flywheel assy and ball bearing Trap63 Issues | Warranty | Recalls / TSB 0 05-29-2018 04:26 AM
Someone recognizes this rear spoiler? pepe Cosmetic Modification (Interior/Exterior/Lighting) 13 08-12-2016 06:57 AM
USB flash drive for mp3's, only recognizes 61 songs per folder? Suparu Electronics | Audio | NAV | Infotainment 6 08-22-2015 03:15 PM
