#15 |
Drives: 2017 BRZ
Random thought: Megan control arms makes me wonder if this was drifted, and possibly has more steering available than stock. I only say this because I rarely see Megan parts on track cars, but often in drift builds. Could be way off.
#16 | ||
Drives: Asphalt '16 FRS
. I'll attach some pictures of what I was able to get, if anyone cares for a look.
| The Following User Says Thank You to Pizzachicken For This Useful Post: | qcbaker (12-04-2018) |
#17 |
Drives: 2014 GT86
From what i notice aftermarket in these pic, red swaybar, camberbolt in lower hole (and hard to make what bolt in upper. If i see right, it looks of similar size to lower bolt (14mm), thus possibly OE 14mm bolt relocated to top (16mm) hole) and steel braided brake lines. But i might be wrong)
But there are several things i cannot tell from these pics, eg. what are bushings in control arm, what is alignment, what is max steering angle, if some part isn't modified in place i don't see (eg. slotting of strut, cut/rewelded something). And also i'm not too skillful to tell for sure about other parts i see here, if those are stock or not. Imho worth to take to dealership, tell about rubbing issue & ask them to check alignment AND geometry (in case if car had been in frontal accident and has something bent out of shape in front/front suspension). |
#18 |
Drives: 2015 Scion FRS
Check that you con't have any missing or loose plastic rivets on your inner fender liner. I had the exact rub marks caused by the thin plastic liner blowing back at highway speeds and rubbing the wheel.
| The Following User Says Thank You to bdtbdtbdt For This Useful Post: | qcbaker (12-04-2018) |
#19 |
Drives: 2014 GT86
Oh. bdtbdtbdt's post above sounds very possible. Somehow didn't thought about such possibility
. Actually have higher chance of probability then suspension mods for higher steering angle or unrepaired frontal crash damage imho.
| The Following User Says Thank You to churchx For This Useful Post: | qcbaker (12-04-2018) |
#20 | |
Shitpost Generator v8.6
Thanks mate, appreciate the info. I'll probably get these and replace them at some point soon.
#21 |
There are camber bolts in both strut holes BTW, not a bad thing you'll get good front camber out of it.
Not sure I would take it to a dealer, you'd probably lose all the awesome front camber you have, try to keep it at -2 no matter what dealer you go to. I believe I've heard that the front subframe can shift causing a camber mismatch and other issues, maybe a good alignment that knows how to check that is all you need. |
| Help with tire size please! Too much rubbing | Itssrayyxd | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 12-15-2016 07:24 PM |
| Fender rubbing issues | amaciose | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 11-29-2016 01:30 PM |
| 17x9 +45 rubbing fender liner with coilovers | nomis | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 05-13-2016 01:41 AM |
| Rubbing fender. | dito | Southern California | 34 | 05-15-2015 02:12 AM |
| Tire rubbing sound, Please Help | dco107 | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 01-11-2013 11:05 AM |
