Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 11-30-2018, 01:22 PM   #15
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by FRSBRZGT86FAN View Post
Do you not have the Big brake kit on your thread? That would absolutely help the effectiveness of the tcs system.
Big brake kits won't help the car much. The larger rotors and calipers help to dissipate heat more than anything, which wouldn't have been a factor in that brief moment on a wet day. My semi-metallic pads may even have less bite in the wet than organics, but if they do have better bite then the pads may have helped the most, but extreme braking wasn't at play; it was more like calculated braking to individual wheels at a low to medium brake intensity.
I believe multiple systems could have been involved, but this was probably mostly the VSC system. I had already released the accelerator the second I lost traction, so TC wasn't at play as much.
https://en.wikipedia.org/wiki/Electr...bility_control
ESC estimates the direction of the skid, and then applies the brakes to individual wheels asymmetrically in order to create torque about the vehicle's vertical axis, opposing the skid and bringing the vehicle back in line with the driver's commanded direction.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
FRSBRZGT86FAN (12-01-2018), Tcoat (11-30-2018)
Old 11-30-2018, 03:36 PM   #16
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The only thing that helps with effectiveness of any traction control system are brake pads that are same as stock in terms of initial bite.
The more you stray away from OE performance parts, the less effective the TCS will be because the system is programmed for a set parameter of parts from the factory. It's why things like aggressive alignment causes TCS to kick in when you are driving under normal conditions.
The Following 4 Users Say Thank You to mav1178 For This Useful Post:
FRSBRZGT86FAN (12-01-2018), Irace86.2.0 (12-01-2018), Spuds (11-30-2018), Tcoat (11-30-2018)
Old 11-30-2018, 04:50 PM   #17
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Lightbulb
Meanwhile traction control and vehicle stability control starts doing their thing. I’m not sure if the electronic steering will move the wheel too, but regardless, I felt individual tires breaking in pulses, as the car almost magically straightened out.
I didn't think our cars had electronic steering. It's hydro steering, correct?
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline   Reply With Quote
Old 11-30-2018, 04:52 PM   #18
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
Negative. It’s an EPAS system. The electric motor is on the steering column, not on the rack like a hydraulic system would be.
BlueWhelan is offline   Reply With Quote
The Following 2 Users Say Thank You to BlueWhelan For This Useful Post:
Adam_L (11-30-2018), Irace86.2.0 (11-30-2018)
Handling saved me from a crash SmileyMe BRZ First-Gen (2012+) -- General Topics 79 06-29-2016 08:37 AM
Bluetooth Volume not Being Saved AmonReviled Electronics | Audio | NAV | Infotainment 0 07-17-2014 04:29 PM
DCH Toyota saved my ass Asian Delight Southern California 3 02-14-2014 11:36 AM
Saved ~ My Child, Myself, and My FR-S Texas BRZ Scion FR-S / Toyota 86 GT86 General Forum 35 08-29-2012 02:28 PM
How much do you have saved up for the FT-86? iff2mastamatt Scion FR-S / Toyota 86 GT86 General Forum 59 03-19-2011 06:37 PM
