#449 | |
Driving Coach
Jon did not have a replacement to offer me. |
| The Following User Says Thank You to ATL BRZ For This Useful Post: | chanomatik (08-15-2013) |
#450 |
Ted
Drives: Raven FR-S
Wow.....very, very disappointing.
#451 |
Driving Coach
Perrin Oil Cooler Kit just arrived:
![]() There was a long delay after I ordered on June 26th since Perrin were having some issues with their core supplier, Mocal. These cores have all been pressure tested to ensure there are no leaks. As you can see the kit is comprehensive and includes pre-cut lines with 10AN fittings as well as a thermostatic sandwich plate so I can run it year round without worrying about the oil getting too cool in the winter. I wanted a complete thermostatic kit that was plug and play with support and Perrin delivered just that; even a new oil filter.
#452 | |
Snow Don't Hurt!
| The Following User Says Thank You to chanomatik For This Useful Post: | ATL BRZ (08-15-2013) |
#453 |
Drives: '13 BRZ
One of my favourite brz on this forum. Very clean!
| The Following User Says Thank You to tinma For This Useful Post: | ATL BRZ (08-15-2013) |
#454 | |
Driving Coach
Since I'm already running Millers Racing 300+ brake fluid and Millers CRX 75w90 NT Trans & Diff fluid, I decided to finish things off with 7 liters of Millers Nanodrive CFS 0w30 NT from Performance Racing Oils.
![]() That should cover the sump plus the cooler capacity with about 1/2 liter to spare. Millers have dyno'ed a stock GT86 with the same in 20 weight and measured 6 WHP over the factory fill in a dyno. Here's the write up with charts: http://www.millersoils.co.uk/news/20...Power-Test.asp I may see marginally less gains with the 30 weight but based on @Dave-ROR 's experience with oil pressures being uncomfortably low with 20 weight while running an oil cooler I thought I'd go with the 30 weight. Some more info on the Millers Nanodrive oil: Quote:
| The Following User Says Thank You to ATL BRZ For This Useful Post: | chanomatik (08-16-2013) |
#455 |
Drives: 13 BRZ Sport Tech WRB
Great looking ride! Love those rims for the brz, I might be picking them up sometime early next year!
Also good thing I read about your front lip, was about to buy one also from Jon. Might just have to go with the HTauto set
| The Following User Says Thank You to dxero For This Useful Post: | ATL BRZ (08-16-2013) |
#456 |
Clean BRZ and it's great to see you're having fun with her!
| The Following User Says Thank You to Llyon V2 For This Useful Post: | ATL BRZ (08-16-2013) |
#457 | ||
Drives: '13 brz, and soon electric '90 crx
Thanks for sharing. This forum is like crack because of people like you.
| The Following User Says Thank You to automowdown For This Useful Post: | ATL BRZ (08-16-2013) |
#458 | |
Driving Coach
Based on these pics, it looks like it will provide plenty of speedbump and driveway clearance. I'm waiting to see what the black powedercoating option looks like and I'll probably not be able to resist ordering one. |
#460 |
Driving Coach
It was nice and cool last night so I thought I'd see what the Dynomaster app had to say during my drive home.
I should have done more than just 1 pull but it was getting late and I was tired. A real dyno would be more accurate with rpm-based power and torque read directly from the rear wheels. The Dynomaster app calculates horsepower at the wheels from GPS speed data, elapsed time and a user defined weight of 2922lb (2762 + 160 for me), 15% drivetrain loss as measured by Perrin, .28 coefficient of drag, and 17.5 sq ft frontal area. Anyways here it is; the pull was WOT from a 1st gear roll through 3rd gear letting off in 4th on a flat, empty road ![]() Power mods include Moto-East E85 tune, VMS Cold air intake, and the WORKS AB-M axleback. Still the stock header/over/front/mid pipe. My 235's out back were losing traction going into 3rd gear on dry pavement. This car is FUN now and will be an absolute riot once the JDL UEL header is installed and I flash an optimized tune for it. Thanks again @moto-mike , I applaud your tuning work!
#461 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Glad you're enjoying it! The puddle of drool is getting deeper here too as we await the header.
| The Following User Says Thank You to Xero-Limit For This Useful Post: | ATL BRZ (08-16-2013) |
#462 |
Driving Coach
I was recently invited to become a coach with Hooked on Driving who offer free track time so this fall I'll be getting more track time than I had originally planned for!
If all goes according to plan I'll be driving/instructing at:
Needless to say I'm provisioning the brake pads again since the car will be consistently faster than before with the recent power mods. The Project Mu HC+800s I'm currently running are a great hybrid pad that offer quiet-ish street operation and 0-800C range for fade-free track usage but the fronts wore a little too quickly for my admittedly aggressive driving style on track. Since I'll have a lot more track time than expected this year it doesn't make sense to keep burning through hybrid pads and leaving them on for the street, so I just ordered a set of these from @CounterSpace Garage ![]() and will be swapping them on exclusively for track duty going forward. I still have my old StopTech Street Performance pads and I'll just swap back to those after each event.
| The Following User Says Thank You to ATL BRZ For This Useful Post: | chanomatik (08-22-2013) |
| Tags |
| jdl turbo, mazworx, racecomp engineering, track build, verus engineering |
| Wnt3d's 86 - Turbo E85 Daily/Track Build | wnt3d | Member's Car Journals | 77 | 07-17-2017 04:35 PM |
| No Limit Motorsport Full Blown BRZ Build | No Limit Motorsport | Member's Car Journals | 16 | 07-08-2014 01:46 PM |
