#2059 |
Driving Coach
![]() Manifold mounted, Verus radiator and fans wired up. Several other odds and ends connected/secured |
| The Following 5 Users Say Thank You to ATL BRZ For This Useful Post: | aimforapex (08-24-2018), DustinS (08-14-2018), mistople (08-14-2018), TheStig85 (08-23-2018), VerusEric (08-15-2018) |
#2060 |
Driving Coach
Ordered a new intercooler yesterday!
![]() ![]() ![]() JDL are now custom making these with a Garrett high density core that will support over 500hp sustained. Fitment is the exact same as the original. I opted for this because I want a more efficient intercooler without sacrificing room under the bumper cover, since I will need it on the passenger's side for the Blitz oil cooler and duct. The Greddy/Zage tube and fin intercooler that I have is barely rated for 400hp and at that point my turbo becomes a hair dryer with all the heat soak, so this new core should really help with IATs on track! Should have it in a few weeks. Last edited by ATL BRZ; 08-15-2018 at 11:22 AM. |
| The Following 8 Users Say Thank You to ATL BRZ For This Useful Post: | aimforapex (08-24-2018), DustinS (09-04-2018), Irace86.2.0 (08-15-2018), jflogerzi (08-16-2018), JonAvalon (08-15-2018), jubella2 (08-16-2018), MCTeeJ (08-15-2018), Racecomp Engineering (08-15-2018) |
#2061 |
Driving Coach
More progress!
Installed the turbo and Blitz oil cooler. ![]() ![]() ![]() ![]() ![]() The kit fit perfectly with the exception of the upper bracket, which is meant to be secured to the stock crash beam. The two lower brackets support the core and duct assembly very well and I have a couple zip ties on the upper mount for now. It's very sturdy. The only difference in the 2017+ bumper is the left side of the shroud has less material to clear the inside of the bumper. |
| The Following 3 Users Say Thank You to ATL BRZ For This Useful Post: |
#2062 |
Drives: 2016 Halo FRS
Does the blitz kit use banjo style fittings on the sandwich plate? Also would that almost 180 degree fitting on the core cause a pretty significant pressure drop? Just curious, been reading up on oil coolers and fittings/pressure drop before I order one. Just don’t know what kit I want to go with.
#2063 | |
Driving Coach
#2064 |
Driving Coach
New bumper is back from paint
#2065 |
Drives: '13 LAVA - lightly modded
OOOOOOH---well, don't just sit there put it on already
You are going to be condemned to live out the consequences of your taste - TM
| The Following User Says Thank You to TeutonicShift89 For This Useful Post: | ATL BRZ (08-24-2018) |
#2066 |
Drives: car
Good to see you making very good progress. Looks like it almost ready for the track.
| The Following User Says Thank You to aimforapex For This Useful Post: | ATL BRZ (08-24-2018) |
#2067 |
Driving Coach
Finished up and got it running yesterday!
![]() Was so nice to hear it rumble again after nine months. ![]() New bumper is looking good with the Verus carbon fiber canards. The brake ducts went on perfectly with the new brackets for the '17 bumper. Thinking about running without the mustache and grille piece for now. If I do install it I will probably trim the lower grille section off completely as I did before. Still need to install the new splitter and the hood and it should be good to go! Once I get the new intercooler that will go on too
| The Following 5 Users Say Thank You to ATL BRZ For This Useful Post: | aimforapex (09-07-2018), DustinS (09-04-2018), TheStig85 (09-06-2018), Tristor (09-03-2018), Zer0 (09-05-2018) |
#2068 |
Drives: pearl white eighty six
Glad to see your car is up and running again. That's a very sinister looking front end.
Did you also change the valves, or just went with the valve springs and retainer kit? |
#2069 | |
Driving Coach
Still using the stock valves, just GSC single springs with retainers. The stock heads flow pretty well for the power levels I'm looking at. |
| The Following User Says Thank You to ATL BRZ For This Useful Post: | pearlhatchiroku (09-06-2018) |
#2070 |
Driving Coach
Buttoned everything up and took it out for a short spin around the block to ensure all is well with the tune. Not too much longer now before I can get into boost again!
[ame]https://www.youtube.com/watch?v=0qe_KFIXRhM[/ame] |
| The Following User Says Thank You to ATL BRZ For This Useful Post: | DocWalt (09-10-2018) |
#2071 |
Drives: 2017 Subaru BRZ
That looks like a lot of overlap. Is that what DEI told you to do?
#2072 |
Driving Coach
It's not a DEI wrap, so no. I followed the instructions from HSP as best I could, though.
EDIT: realized that I stated it was a DEI wrap originally by mistake. I've edited my original post to correct that. |
| The Following User Says Thank You to ATL BRZ For This Useful Post: | Zer0 (09-11-2018) |
| Tags |
| jdl turbo, mazworx, racecomp engineering, track build, verus engineering |
| Wnt3d's 86 - Turbo E85 Daily/Track Build | wnt3d | Member's Car Journals | 77 | 07-17-2017 04:35 PM |
| No Limit Motorsport Full Blown BRZ Build | No Limit Motorsport | Member's Car Journals | 16 | 07-08-2014 01:46 PM |
