86WORX
AVOturboworld
Old 06-10-2014, 09:52 PM   #2969
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
AVO Turboworld Base ROM updates
As part of our ongoing Research and Development, we will be updating our base Stage 1 and Stage 2 base maps for our new customers, and will also make them available to customers that have already received our base map for their turbocharger kits.
Changes:
1. Startup ignition retard - the default value for startup is -15 degrees. This is instituted by the manufacturer for emission reasons only, and only affects that initial cold startup. It is also rather excessive and makes a car that has had it's cats removed sound like it has an exhaust leak at startup. We have reduced it to -5 degrees only to reduce that nasty startup noise.
2. Boost cut protection on Stage 2 maps. We will include a 10psi boost cut on the Stage 2 base map. This will only work with people running the 3-bar MAP sensor upgrade. 10psi gives an acceptable margin to compensate for high load boost situations, while protecting your engine from any boost spikes due to a blown wastegate hose or other possible issues.
Customers running a Stage 1 kit with a MAP sensor upgrade, but still on a Stage 1 basemap, can contact us directly for an update as well.
3. Also included in these updates are the latest TSB updates from Subaru and Toyota/Scion, specifically in regard to Cam Sensor issues that was present on early revision cars. We know this fixes ecu related issues to exhaust cam error codes P0018 and P0019. This will not fix a mechanical, but will fix all ecu specific issues. Transient Ignition Retard is updated as well. This was done by Subaru and Toyota/Scion to correct a situation where it would cause the direct injection seals to fail.
These updates will apply only to customers running our Base Maps, if you have gotten a custom tune, you will need to talk to your tuner about implementing any of these options.
Custom tunes:
If you are running a custom tune, we do highly recommend running an EGT sensor on the exhaust manifold if you have a high boost setup. We have been seeing total ignition timing with some of these setups at about 12-14 degrees, which is causing exhaust gas temperatures at the manifold to get as high as 1700 degrees Farenheit.
Technical footnote:
If you have a mechanical issue that is causing your car to stall out when coming to a stop [error codes P0016, P0017], it is likely because of your cam sprocket. This photo illustrates the issue - the little piece on the inside left that looks like it has a spring behind it is the cause. It is actually supposed to sit flush with the back, but it will pop out and cause a oil pressure loss, which causes the cam to not respond fully. If this has happened, the cam sprocket will need to be replaced unless you can get that piece to sit flush again.
AVOturboworld is offline   Reply With Quote
The Following 7 Users Say Thank You to AVOturboworld For This Useful Post:
flippy (02-25-2015), giorgi0424 (03-22-2017), hmong337 (02-07-2015), JD86 (06-12-2014), kiichiro (06-11-2014), MFB (06-11-2014), SkAsphalt (06-11-2014)
Old 06-11-2014, 01:47 AM   #2970
aaguirre123
Drives: sti 2012 sedan
Technical footnote:
Thanks. For us that are not mechanics can you zoom out so we have a better idea of where the exact location. Its very hard when you have just one photo and its zoomin.
aaguirre123 is offline   Reply With Quote
Old 06-11-2014, 01:56 AM   #2971
sw20kosh
Drives: 2013 Black FR-S
Technical footnote:
@jamesm I wonder if my weird stalling issue when coming to a stop is related to this?
Old 06-11-2014, 07:59 PM   #2972
AVOturboworld
Here is two more shots:
This is how the back of the cam sprocket should look - the piece is fit flush with the inner surface.
The entire sprocket/cam assembly.
The Following 4 Users Say Thank You to AVOturboworld For This Useful Post:
aaguirre123 (06-12-2014), hmong337 (05-11-2015), MFB (06-11-2014), Raven604 (06-12-2014)
Old 06-12-2014, 02:26 AM   #2973
aaguirre123
Technical footnote:
What causes this problem? Force induction? Custom tune?
Old 06-12-2014, 03:07 AM   #2974
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
My guess is the tune
Old 06-12-2014, 03:09 AM   #2975
s2d4
s2d4's Avatar
Read point 3 guys.
Old 06-12-2014, 03:45 AM   #2976
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The 3rd point is referring to the codes for P0018 and 19 for the cam sensor, the loose sprocket is the cause of the engine stalling at a stop, or P0016 and 17 according to AVO.
Two different codes, or is one the cause of the other?
It seems that the if the cam sensor goes AWOL then the cam sprocket will pop out from the bad timing.
Old 06-12-2014, 04:30 AM   #2977
s2d4
s2d4's Avatar
Point 3 will solve as much as software allows, the cam sprocket would be the case that it can't fix. So the derivation would be that it isn't tune related?
Old 06-12-2014, 04:58 AM   #2978
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
why does everything come down to derivations with you lol this is the second time.
the cam sensor would chalk up some stalls at low misfiring, increasing camshaft play, possibly jarring loose the sprocket.
Old 06-12-2014, 05:35 AM   #2979
s2d4
s2d4's Avatar
It would also happen on the factory tune then? As indicated by the TSB?
Old 06-12-2014, 05:58 AM   #2980
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Sounds like it. It may have been that the cam sensors werent set within absolute parameters, allowing rare instances when DI seals would be blown, bad cam timing causing misfire, and left unchecked probably caused the cam sprocket to become ajar.
I have no idea if any of these are corrilated, it just sounds like a logical course of events.
Old 06-12-2014, 03:24 PM   #2981
AVOturboworld
We saw the issues on stock cars w/stock tune - those pictures are from a stock engine we took apart to find what was going on.
The Following 6 Users Say Thank You to AVOturboworld For This Useful Post:
aaguirre123 (06-13-2014), Astroboy (01-11-2016), cdrazic93 (06-12-2014), JD86 (06-13-2014), s2d4 (06-14-2014), SkAsphalt (06-13-2014)
Old 06-12-2014, 03:30 PM   #2982
qtwre
Drives: White FR-S
Has anybody bought the AVO 3" downpipe/overpipe/cat? I haven't seen anyone talk about it here but I'm thinking of getting it.
I imagine fitment should be perfect since it bolts directly to the turbo, but I'd like to know if anyone has experience with it.
qtwre is offline   Reply With Quote
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 10:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 03:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 02:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 08:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
