#29 | |
Brakes stop the wheels from turning. Tires stop the car from moving forward. Increasing the efficiency of stopping the wheels from turning does not make the tires more effective at making the car stop moving forward. Using summer tires a car on the same surface will stop it in a shorter distance at 80 degrees than it will at 32 degrees simply due to the change in firmness of the tires. The rotors and calipers have nothing to do with it as the resistance is transferred to the tires as soon as the brakes are applied. As stated, the special compounds of performance pads and rotors is solely to combat heat from repeated and extreme braking maneuvers. They are intended to combat fade not stop the car faster.
| The Following User Says Thank You to Tcoat For This Useful Post: | wparsons (11-06-2018) |
#30 |
Only users lose drugs.
Drives: All the time
A fixed caliper usually has better feel, resulting in better modulation. But if you're relying on ABS to do the modulation, as in a max-effort stop, pedal feel is of no real consequence.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
| The Following 2 Users Say Thank You to venturaII For This Useful Post: | Ultramaroon (11-06-2018), wparsons (11-06-2018) |
#31 |
Rust bucket enthusiast
Another perspective of this that I think most people can relate to - Why would a BIG BRAKE KIT not help you stop any sooner on ice?
It's not that it cannot help you stop sooner, it's just that those circumstances are not the first bottleneck you're encountering. Your tires usually are the first bottleneck. |
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Stang70Fastback (11-06-2018) |
#32 |
Drives: 2014 GT86
Tcoat: except cases, where tires are upgraded to point of grip increasing to level of stock or simply previous pads are unable to lock them though. I'm not sure for example, if friction of stock pads/brakes will be enough to overcome torque of race slicks. Heck, me moving up to not race slick like tires, but simply more grippier tires like PSS, made me start considering pads with higher Mu, as hybrid pads like DS2500, while still were able to lock them, but now needed much stronger brake pedal press .. and with such strong press required i found that my leg brake pedal modulation precision suffered. So even if measured braking distance with different pads won't change, in this case with better pads "braking feel" can be more pleasant/easier. People do some "feel" upgrades to steering wheel, shifter, clutch, seats .. braking also is area, where feel can be enhanced.
Funny, how many things in car handling are affected by first and mostly tire choice. Optimal suspension, optimal alignment, optimal aero, optimal brake setup. Everything is changed/depends mostly from those pieces of rubber. All aspects of handling affected, braking, acceleration, cornering, max speed, comfort, pavement type compliance. Load & wear of components, money spent. Even such handling aspect, as fun
| The Following 5 Users Say Thank You to churchx For This Useful Post: | Captain Snooze (11-07-2018), JesseG (04-22-2021), new2subaru (11-06-2018), Racecomp Engineering (11-06-2018), wparsons (11-06-2018) |
#33 |
Senior Citizen Member
If the theory doesn't fit the reality it's time to change the theory . . .
#34 | |
A.K.A. Starlord
Drives: 2015 Series.Blue
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. Last edited by Stang70Fastback; 11-06-2018 at 04:06 PM. |
| The Following 3 Users Say Thank You to Stang70Fastback For This Useful Post: |
#35 | |
fabulous
1. The pucks normally rub ever so slightly against the rotor. 2. See below how freely a brake caliper should float in its mount. If it doesn't, it needs attention. The only hysteresis designed in the system is that between the pot seal and cylinder. That's there to prevent kickback. So, no. A floating caliper does not apply braking force in some weird two-step process. [ame]https://www.youtube.com/watch?v=4xNZu18bxg4[/ame]
#36 | |
It sounds cliche, but tires are literally the foundation of the vehicle. They're the only part of the car actually in contact with the ground. And they're the front line of suspension, since they can accommodate multiple inches of road movement without anything else needing to move. And if they're bad or not up to the task, it doesn't matter what the rest of the car is like - you can't mask it. Tires can probably hide (or expose...) more bad design than any other component in the car. They're not just rim protectors...
| The Following User Says Thank You to venturaII For This Useful Post: | JesseG (04-22-2021) |
#37 | |
Drives: 18 Brz (Sold) / 22 BRZ
Porsche did prove that this is not correct. They did change the stopping distance adjusting the brake bias. Anyways, my mind when talking about system, I try to identify bottle neck and go from there. Brake bias, tire to road friction, suspension setup, brake foundation response time, brake actuation response time, brake modulation response time, unsprung mass, rotating inertia, mass transfer plays a factor on that, and will be different from platform to platform. BBK may help on bias, unsprung mass and response time. |
#38 | |
Good case is some old toyotas with dual cylinders, which had a tendency to go off the track. Also, on semis, it is very evident the difference. |
#39 | |
And to your point, always check if your calipers are sliding before a track day, getting a stuck caliper will be bad and, if you live in northen area, check regularly, as this changes quickly, and this will not always gives you warning signs (in stuck calipers, the outer pad can wear faster than inner, and mechanical wear indicator may not be activated)
| The Following User Says Thank You to Stonehorsw For This Useful Post: | Ultramaroon (04-21-2021) |
#40 |
We used to referrer to the best possible braking as threshold braking. This was the point just before the tires locked up. ABS tries to keep you at that point under panic stops. Once the tires start to skid the stopping distance increases and of course steering is lost.
We used to practice stopping at the limit both for feel but also to adjust brake bias. Our old cars (drum brakes) were able to brake (tire dependent) just as well as the new but not repeatedly. Only in a strait line with good surface. ABS is a great improvement as it takes account of tire friction at all four corners. The first ABS unit had timing pulses that were so slow that many thought the could do better but not true today. |
| The Following 2 Users Say Thank You to ls1ac For This Useful Post: | Stonehorsw (04-21-2021), wparsons (04-21-2021) |
#41 | |
For deum brakes, it was not done as the brake factor is not linear, and also very prone for changes due to drum expansion (reduced factor) or change on point of contact (heel and toe contact, that could spike the brake factor) PS: re-read your post. If you had a brake bar and adjusted the brake bias, then I would agree with your point. Last edited by Stonehorsw; 04-21-2021 at 11:09 AM. Reason: Clarification |
#42 | |
The point of the matter remains that just swapping out some bigger pads and rotors doesn’t mean you will stop quicker.
| Stopping the window half way | BirdTRD | Issues | Warranty | Recalls / TSB | 18 | 11-07-2017 05:09 PM |
| Klunks when stopping | NOHOME | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-26-2017 12:44 PM |
| FR-S - AT nearly stalls when stopping | WryGuy | Issues | Warranty | Recalls / TSB | 12 | 05-27-2016 04:04 PM |
| Distance? | Nonfacter1 | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 01-13-2015 11:17 AM |
| Distance Drive for New Car | Kundiethala | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 08-14-2012 11:56 PM |
