#281 |
949Racing Support
Drives: 1999 Mazda Miata Turbo
The street and track versions are simply different spring packs. We specifically selected the adjustment range to span both spring packs. So if you want a better-than-stock ride but with improved handling, get the street pack. If later on down the road you feel like chasing lap records, swap the springs, turn the knobs, and have at it.
#282 |
949Racing Support
I'm realizing that perhaps you don't know about this thread: https://www.ft86club.com/forums/show...97#post3265697
#283 |
FT86Club Official Vendor
Drives: Miata, GT350, FR-S
Not sure I understand you. How does the Xida we have been describing with Street or Race spring packs not match your need?
#284 |
Drives: 14 brz
how are rebuilds handled? What is the turn around time roughly?
#285 |
949Racing Support
See Xida thread linked two posts up.
#286 | |
Drives: 2013 BRZ Limited 6MT
My understanding based on previous comments was that there was going to be two different dampers, one street and one track. I guess I misunderstood. No sweat. |
#287 |
Ah, yes. One shock valving spec. Your choice of either spring pack. Same shock either way.
#288 |
Drives: None
Question for the 949 folks b/c you're fast drivers...
![]() I know general consensus is that the stock brakes are sufficient for the platform. I'm thinking about doing TT eventually, and I'm wondering if you guys have any experience, or better yet, data, on the impact of BBKs from purely a lap time performance perspective (not longevity, cost, consistency, etc.) with race tires (either on 86 or Miatas, or anything else). My thinking is that with BBKs one should be able to generate higher decel Gs, and thus brake deeper into the braking zone and thus save time, but I don't know if that's actually the case or not (vs. people just going deeper b/c they *feel* like they could with BBKs, not because BBKs actually slow down the car more, or alternatively the brakes may not be the limiting factor and rather it's the tires, or other reasons). Would appreciate any insights. Thanks!
#289 |
If you are not fading the OEM based brakes, you don't need a BBK. The right BBK, implemented properly can improve braking feel. Improved braking feel can improve precision of brake release on corner entry.
As grip or power increases, the total thermal energy put into the brakes increases sharply. We use a 328mm (12.88") Wilwood kit on all four wheels of Blub. We faded OEM brakes despite having a very high MOT (max operating temp) race pad and Castrol SRF. An ancillary benefit is reduced sprung mass and it's effect on grip. That is the least important reason to install a BBK and not the best bang for the buck when tuning you car for performance.
| The Following User Says Thank You to 949 Racing For This Useful Post: | Clutch Dog (10-16-2019) |
#290 | |
Drives: None
Thanks for the quick response!
I'm basically getting brake fade toward the end of my sessions now, on 200tw tires (Federal 595 RS-RRs), with ST43 pads and SRF. Going to a race tire will tax the system even more, though for TT I would only need one clean lap, so net net I'm not sure what that means. Hence my question of whether a similar setup OEM brakes vs. BBK will improve braking distance on race tires. Would the following be a fair representation of your view, phrased in another way: BBK will not improve braking distance vs. OEM brakes on a similar setup (pads/fluids/tires), but the BBK will provide better feel, and that's where improvement in lap times will appear. Thanks again! PS - what tires do you guys run on your car? Quote:
#291 | |
We run a wide variety of tires on Blub. More importantly, what are your needs, classing restrictions, etc?
#292 | |
Drives: None
If I may perhaps ask the question in a different way for a yes / no answer... Imagine you need to do one flying lap in Blub for best time and the car is warmed up, which below do you think will produce a faster lap time: 1) race pads / SRF / race tires & OEM brakes 2) race pads / SRF / race tires & BBK Thanks again. Hopefully not making this complicated. Just trying to get an opinion from someone who's skill level is high enough to have exceeded the stock system. |
#293 |
JHerbert Racing
Drives: 2013 Scion FRS
Run Verus brake cooling. Problem solved. I overheated my OEM brake system pretty easily at Watkins Glen.
With DTC60, Castrol RTF and the verus brake cooling system that problem was completely gone. And no points added for TT. FYI the kit is SO GOOD that I was able to "downgrade" from DBA rotors to centric premiums without issue. Now back to 949 Racing's build thread
#294 | |
Drives: None
My apologies everyone, did not mean to derail the thread. |
| Tags |
| 6ul, 949 racing, blub, xida |
| LED Blub Diffuser? | Chimera | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 07-07-2016 01:24 PM |
| Project Mu Racing 999 brake pads | CSG Mike | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 11-15-2013 04:55 PM |
| Project Kics R40 racing lug nuts | HighbreadEH3 | Wheels and Tires | 0 | 09-03-2013 02:49 PM |
| The Enjuku Racing Project FR-S! | Enjuku Racing | Announcements, Contests, Giveaways | 12 | 07-19-2012 12:54 PM |
