86WORX
Old 11-02-2018, 07:16 PM   #225
ermax
ermax's Avatar
Originally Posted by Lantanafrs2 View Post
No, that tool compresses spring to remove keepers as well.
Found a video on YouTube. I’m picturing someone pressing it by hand with the tool but in the video they hit it with a hammer and it sets. So if you can get enough compression in the cylinder then I bet this technique would work. Still can’t avoid taking the cam subassembly off which is were you get into all the packing mess. Maybe they will remove the cam caps without removing the sub assembly first but they would risk warping the head.
It will be interesting to see what their game plan is.
Old 11-02-2018, 07:19 PM   #226
ermax
ermax's Avatar
Seal, seats, I forget. It was 1979. You get my point. Burned oil like crazy, then didn't burn a drop.
I was just commenting on how they keep the valves closed...Air.
Then yeah, seals. Can’t do a seal without removing the spring so you prove you can do a spring without access to both sides of the head.
Old 11-02-2018, 07:20 PM   #227
EXCellR8
FR-S Driver (MT)
EXCellR8's Avatar
Drives: 2013 Whiteout FR-S
I think I'm alright... my car was manufactured 7/13 but the VIN is well outside of the range at 734630. Damn they built a lot of these sum bitches... I'll keep a look out for a recall notice though but the full VIN didn't bring up any open recalls yet.
EXCellR8 is offline   Reply With Quote
Old 11-02-2018, 07:22 PM   #228
ermax
ermax's Avatar
Here is a thread where someone reported a broken spring. Pictures and all.
http://www.ft86club.com/forums/showthread.php?p=2553857
The Following 4 Users Say Thank You to ermax For This Useful Post:
Bonburner (11-02-2018), funwheeldrive (11-03-2018), nikitopo (11-03-2018), notout86 (11-16-2018)
Old 11-02-2018, 08:05 PM   #229
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
That guy is due a big refund and an apology from Toyota/Subaru. His activity shows that he has not logged on here for a couple years so he probably no longer has a twin but he definitely has a case anyway because they made him pay for that repair out of his own pocket.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
The Following 2 Users Say Thank You to Rampage For This Useful Post:
ermax (11-02-2018), funwheeldrive (11-03-2018)
Old 11-02-2018, 09:10 PM   #230
Lantanafrs2
Drives: 2013 frs red
Subaru is looking not so Japanese right now. You expect this shit from europe. My next car will have the valve train on top.
Old 11-02-2018, 11:10 PM   #231
dragelements
Drives: 13 frs
Well looks like myCARFAX app has my 13 FRS on the recall.
dragelements is offline   Reply With Quote
Old 11-02-2018, 11:17 PM   #232
dragelements
Drives: 13 frs
valve spring issue?
Any known one know if I would have any problems with a salvage rebuilt title getting the recall?
Old 11-03-2018, 12:55 AM   #233
nico_rsx
Drives: BRZ 2017 Pure Red, MT
You absolutely can data log IAM in Techstream.
PM sent.
I have looked at every value in techstream 3 times in 2 different version. Took like 2 hours. I'd be happy to be proven wrong, but it's not there.
nico_rsx is offline   Reply With Quote
Old 11-03-2018, 02:04 AM   #234
highway7
Drives: FRS 2013
I don't think the VINs are linear. My car is manufactured a month after yours at 08/13 and final 6 is 733602.
My car is not in the recall, but who knows what will happen in the future, the recall could be expanded.
Currently at 142 000 km (Bought at 118 000 km). No problems yet, used Toyota 0W20 and OEM filter it's whole life.
highway7 is offline   Reply With Quote
The Following User Says Thank You to highway7 For This Useful Post:
EXCellR8 (11-05-2018)
Old 11-03-2018, 03:00 AM   #235
humfrz
Drain oil and coolant, evacuate the AC, pull the engine, remove the accessories, pull the manifold, remove the harnesses and coolant lines, remove the timing cover and clean up all the packing material, pull the timing chains, remove the valve covers and clean the packing, remove the cam subassemblies and clean the packing, remove the heads and clean the surfaces, replace the springs, put it back together and reapply the packing for the cam subassemblies, check the valve clearance, pull it back apart and clean the packing again, replace shims and then reapply the packing, reapply packing for the valve covers, reinstall the timing chains, reapply packing and install timing cover, install accessories, reinstall the engine, recharge the AC, refill oil and coolant.
I'm recalling off the top of my head and obviously leaving out a lot of detail. But it's a lot of work.
Now what could go wrong there -
humfrz
Old 11-03-2018, 03:16 AM   #236
humfrz
Now, THAT (39 years ago) is considered "long term memory" - you are in trouble -
humfrz
Old 11-03-2018, 03:49 AM   #237
humfrz
Hells bells - it looks like my FR-S is due to be recalled. -
Maybe I'll just ride it out and if the engine blows, before I do, I'll just do a V-8 swap.
Yep, something simple, something dependable, something I can work on.
humfrz
Old 11-03-2018, 08:30 AM   #238
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
At least one broken valve spring here:
http://www.ft86club.com/forums/showp...1&postcount=41
Thanks ermax.
Search this Thread:
Advanced Search
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 05:20 AM
Valve spring swap rcmf5525 Engine, Exhaust, Transmission 6 05-19-2018 04:12 PM
Jrsc replacement diverter valve issue Brzxton Forced Induction 6 12-08-2017 10:39 AM
GSC FA20 Valve Spring Kits MAPerformance Engine, Exhaust, Transmission 41 07-20-2015 11:22 AM
Skunk2 Dual Valve Spring and Titanium Retainers limitedblkwrx Engine, Exhaust, Transmission 0 01-05-2015 12:12 AM
