86WORX
Old 11-02-2018, 05:51 PM   #211
BRZnut
Drives: BRZ DGM Limited
Ok, my BRZ was purchased Nov 2012 and manufactured 9/12, but when I put my vin in the Safercar.gov and the MySubaru site, both show no recalls for my BRZ. Are these sites up to date on this issue or is it too early???
Old 11-02-2018, 05:53 PM   #212
PWBRZ
PWBRZ's Avatar
Drives: 2013 BRZ 6MT
I’m thinking it’s still too early and would keep checking
PWBRZ is offline   Reply With Quote
Old 11-02-2018, 06:08 PM   #213
HotRodPA
So my car is within the manufacture date and VIN# range but neither NHTSA nor Subaru are showing any recalls on my particular VIN#... Did I just get super lucky or is the database not fully updated yet? Anyone else experience the same?
Edit: So reading fail... two posts above me with same story, oops!
HotRodPA is offline   Reply With Quote
Old 11-02-2018, 06:09 PM   #214
vladniko86
vladniko86's Avatar
Drives: FRS
Try again, mine's up.
vladniko86 is offline   Reply With Quote
Old 11-02-2018, 06:28 PM   #215
Lantanafrs2
Drives: 2013 frs red
Originally Posted by ermax View Post
That would keep the valve from dropping but still not sure how you would get it compressed. Lets just say there is a way to replace the springs without pulling the head, your hardly saving time. The only steps you would be saving would be unbolting the heads and then cleaning up the head surface which is fairly insignificant in comparison to the rest of the job. You can't get to the springs until the cams come off.
Yamaha had a factory tool made of Teflon that would do it. I used it on a bike head. It was amazing.
Old 11-02-2018, 06:37 PM   #216
Lantanafrs2
Google lisle valve keeper tool. You'll get the idea.
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Ultramaroon (11-03-2018)
Old 11-02-2018, 06:38 PM   #217
Sapphireho
Connection issues
Sapphireho's Avatar
Drives: '15 ultramarine
Originally Posted by Lantanafrs2 View Post
Use a leak down fitting and pump air into cylinder.
Yep. Pressurize cylinder. Volkswagen replaced my valve seats in my GTI under warranty without removing the heads.
Old 11-02-2018, 06:55 PM   #218
Bonburner
Purchased 6/22/12
Bonburner's Avatar
Originally Posted by KL View Post
So if you're confirmed to have this recall done at a Subaru dealership, is there anything else you would recommend doing at the same time, either in the way of preventative maintenance or mods, while they've got the heads/timing cover/whatever apart replacing the valve springs? If I'm gonna have this work done for free, I wouldn't mind chipping in another few hours of labour out of pocket if there's a benefit to be had.
For context, I'm at 100k km on the BRZ, spark plugs already done 6k ago (dammit).
Thoughts?
New throwout bearing.
That's my plan, the part is ~$20. Install shouldn't cost much more since they already pulled the engine lol
Consider Velox's clutch fork and billet clutch fork pivot
The Following 2 Users Say Thank You to Bonburner For This Useful Post:
humfrz (11-03-2018), KL (12-29-2018)
Old 11-02-2018, 06:55 PM   #219
gravitylover
I ran mine this afternoon and it still shows not affected. I figured with it being a late '12 build it would be. I'll try again tomorrow.
Old 11-02-2018, 06:57 PM   #220
Lantanafrs2
Seals. Seats are pressed into the head. Necessity is the mother of invention lol
Old 11-02-2018, 07:01 PM   #221
ermax
ermax's Avatar
Seals maybe. The seats are in the combustion chamber.
Old 11-02-2018, 07:04 PM   #222
Sapphireho
Connection issues
Sapphireho's Avatar
Seal, seats, I forget. It was 1979. You get my point. Burned oil like crazy, then didn't burn a drop.
I was just commenting on how they keep the valves closed...Air.
Old 11-02-2018, 07:05 PM   #223
ermax
ermax's Avatar
That’s for setting the keepers though. You still need to compress the spring. Hell you can use a socket and a light wack of a hammer to pop the keepers. Vaseline helps with putting them back on but this tool is magnetic which would keep the keepers on the stem while releasing the spring compressor.
Old 11-02-2018, 07:09 PM   #224
Lantanafrs2
No, that tool compresses spring to remove keepers as well.
Search this Thread:
Advanced Search
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 05:20 AM
Valve spring swap rcmf5525 Engine, Exhaust, Transmission 6 05-19-2018 04:12 PM
Jrsc replacement diverter valve issue Brzxton Forced Induction 6 12-08-2017 10:39 AM
GSC FA20 Valve Spring Kits MAPerformance Engine, Exhaust, Transmission 41 07-20-2015 11:22 AM
Skunk2 Dual Valve Spring and Titanium Retainers limitedblkwrx Engine, Exhaust, Transmission 0 01-05-2015 12:12 AM
