86WORX
Old 11-01-2018, 09:24 PM   #155
BRZnut
Drives: BRZ DGM Limited
Originally Posted by ermax View Post
Yeah, probably right. Mine is on the list but I’m not sure I’d want the dealer working on it. If it was a whole new engine I’d be down.
What is odd is I don’t recall anyone here complaining about failed valve springs. So it sort of shows how many people there are out there with these cars that have problems and aren’t posting about them on this forum. How many people are spinning bearings that also don’t post about it here?
I'm in the recall and really don't want them opening my engine up. Too many stories about dealership techs using too much sealant and then the next thing you know you have oil starvation issues from blocked oil passages.
It seems odd that this is such a big issues but I have never heard of it before!
Old 11-01-2018, 09:40 PM   #156
There are 400,000 cars across several different models that the recall impacts. The one report says there were 94 reported issues across all those cars. I don't think this fits into your standard "the sky is falling" classification.
Dadhawk (11-02-2018)
Old 11-01-2018, 09:42 PM   #157
gravitylover
I'm just not sure what to think at this point. If it needs to go in I'll have to give it some serious thought at that time. It might be nice to know that the top end of the engine has been gone through (if they do it right). It would also be a great time to get the plugs changed, the serpentine belt and tensioners replaced and maybe whatever else I've been putting off because it's a hassle.
Old 11-01-2018, 10:12 PM   #158
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
My FRS was built in June 2013, but the VIN isn't bringing up any recalls. Guess I dodged a bullet? The idea of my local dealership tearing apart my engine doesn't give me warm fuzzies.
smg1138 is offline   Reply With Quote
Old 11-01-2018, 10:18 PM   #159
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by incriminati View Post
I'm in the date range, but my vin is 60XXXX. Am I understanding this right that it's not affected?
The car was manufactured in 9/2012.
Originally Posted by gravitylover View Post
Yeah I'm in the date range too but the last 6 digits of the VIN starts with 61....
Originally Posted by ChrisGeezy View Post
Yeah my vin isn't there either in the range but my MFG date is 8/13. Let's see what happens.
My VIN is also outside the range, but the build date is within the range. mine states it was manufactured on 4/12, but my VIN is JF1ZCAC13D16009XX
How could it be that the first 2000 cars that rolled off the line are fine, but ones after that aren't?
Old 11-01-2018, 10:19 PM   #160
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Different lines?
Old 11-01-2018, 10:57 PM   #161
incriminati
Put your VIN in the NHTSA site posted earlier.
My understanding is that the valve springs are failing, which would indicate bad valve springs. The fact that it's just certain engines and not all from a certain point in time to another indicates that there's something different between these engines. The difference, seemingly without thinking too deeply, are either the springs themselves or the installation of the springs. If it was installation I'd imagine they'd fail much more frequently and quicker and across more models. Just 94 have been reported so far. So I'm lead to believe certain valve springs from a certain supplier are failing due to how they were made or what they were made out of. Just me trying to figure it out, though, with what makes sense.
incriminati is offline   Reply With Quote
Old 11-01-2018, 10:58 PM   #162
Lantanafrs2
Drives: 2013 frs red
Toyota was fantastic to me when my engine went. Aftermarket tune and pulley and they still warranteed it. Don't want to push my luck with having it messed with again though.
Old 11-02-2018, 02:32 AM   #163
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by beezee View Post
The VIN for my FR-S is outside the range mentioned in these posts (7XXXXX) but when I input it on both the NHTSA and Toyota recall sites, they say its affected by the recall. Wait and see I guess.
Would be interesting to see if others get the same results.
Originally Posted by DarkSideFRS View Post
i thought the same, but my VIN is showing up as affected on the NHTSA site....
Same here. But I also don't get how my production number could be 70xxxx when my car has a 4/2012 build date. There must be something different with the vin they we realize (edit: It seems like the last 5 are production numbers, the other number is line related).
IDK if I'll do it though. at 151k miles right now no issues. If for some reason they have to pull the timing cover I may just do it since that leak is getting a bit worse. Could also get the spark plugs done if I hold out another 30k miles lol
Old 11-02-2018, 04:15 AM   #164
kr
kr's Avatar
Drives: GT86
What I wonder is that, the spring number SU003-00204 haven´t been changed, its actually same starting year 03/2012 to now days.
So, if they change valve springs, are they better than the old one´s
kr is offline   Reply With Quote
Old 11-02-2018, 06:21 AM   #165
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
maybe the initial set provided was faulty (other producers after 2013)?
Trap63 is offline   Reply With Quote
Old 11-02-2018, 06:37 AM   #166
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Put my vin in and found nothing , called Subaru and they said no recall for my vin, should I try again later ?
mswbrz is offline   Reply With Quote
Old 11-02-2018, 06:39 AM   #167
mswbrz
mswbrz's Avatar
Sounds like we will get the official report on November 5th. It will be interesting to see if the Zenki models are affected too
Where did you research that more info will be avail nov 5 if I may ask ? Who will be posting more details ?
Old 11-02-2018, 06:44 AM   #168
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
The specifications of the springs weren't changed, it was a batch of springs out of which a few had production defects, so they're recalling any cars that have springs from the batch they deemed at risk.
The Following 2 Users Say Thank You to RZNT4R For This Useful Post:
Tcoat (11-02-2018), Trap63 (11-02-2018)
Search this Thread:
Advanced Search
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 05:20 AM
Valve spring swap rcmf5525 Engine, Exhaust, Transmission 6 05-19-2018 04:12 PM
Jrsc replacement diverter valve issue Brzxton Forced Induction 6 12-08-2017 10:39 AM
GSC FA20 Valve Spring Kits MAPerformance Engine, Exhaust, Transmission 41 07-20-2015 11:22 AM
Skunk2 Dual Valve Spring and Titanium Retainers limitedblkwrx Engine, Exhaust, Transmission 0 01-05-2015 12:12 AM
