#29 | |
Country Boy 4 Life
What brand are they? Interesting, 5k front 4k rear... I have not installed mine yet, (literally just ordered the roller bearings) but mine have stiffer springs on the rear. 6k front 7k rear. The OEM springs are stiffer in the rear too. Don't know exactly how this will change your car, but it has.
I LIKE TIRES! |
#30 |
A.K.A. Starlord
Drives: 2015 Series.Blue
Yeah, that's pretty soft. That's actually around the same softness as the V3s. Though I suspect that the V3s will still ride better. They'll also survive Toronto winters if he decides to drive it in the winter.
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
#31 | |
Country Boy 4 Life
They should ride better; they consistently get great reviews for aggressive street driving with some track use mixed in. And the Stainless bodies are nice too! They were my first choice.
I LIKE TIRES! |
#32 |
Wes
Can't remember off the top. Like -2?
Instagram: @gt86ws
#33 |
Wes
Oh yeah I've been driving in the winter. I have those ISC coilover socks
Instagram: @gt86ws
#34 | |
Wes
Instagram: @gt86ws
| The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | Leonardo (10-23-2018) |
#35 |
A.K.A. Starlord
If you're at around -2, you should be able to achieve that without camber plates. The V3s have a pretty bit slot for the upper knuckle bolt. When I installed mine, I pushed my knuckle to "max camber" on the strut, and initially installed the camber plates at the "zero" setting before getting an alignment, and both front wheels were right around 2 degrees of camber in that configuration. I run more than that amount of camber, so that's why I have camber plates (autocross things), otherwise I too would run the stock front top hats for a bit less NVH.
#36 | |
Wes
Instagram: @gt86ws
#37 |
A.K.A. Starlord
So do I! Two salt-covered winters later and my coilovers still literally looked like new when I peeked underneath. That rust-looking stuff on top of the metal ring behind the bottom coil was some other gunk or something that flaked right off when I touched it.
| The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post: | Leonardo (10-23-2018), StraightOuttaCanadaEh (10-23-2018) |
#38 | |
Wes
Instagram: @gt86ws
#39 |
Drives: 2013 FR-S Series 10
easiest thing would be to add more sidewall to your tire imo. if you're already on the newer springs and shocks.
#40 |
Wes
I thought about this but don't know how high I should go. Currently I'm 225/40/18
Instagram: @gt86ws
#41 | |
Weight Weenie
Drives: 15 FR-S
But, after reading what I think you want I'm not sure that's what you're really after. If you want a "tight" suspension, you could start adding more poly bushing gradually. Can you do the work yourself? If not, I would imagine bushings would get expensive. |
| The Following User Says Thank You to new2subaru For This Useful Post: | Leonardo (10-24-2018) |
#42 | |
Wes
Instagram: @gt86ws
| Save money on suspension upgrades! | AJW Performance | Brakes, Suspension, Chassis | 34 | 05-05-2016 11:05 AM |
| Save money on suspension upgrades! | AJW Performance | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-09-2015 12:06 PM |
| Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! | mothespaceman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 08-14-2015 06:06 PM |
| Wear on outside of tires - suggest suspension upgrades? | 1Cor10:23 | Tracking / Autocross / HPDE / Drifting | 43 | 06-13-2014 09:51 PM |
